Power Commander 3 - 929RR
07-16-2007, 10:43 PM
Bike(s): Honda 929RR Posts: 65
Rep:  (10) Rep Power: 2
| Power Commander 3 - 929RR Bought this and installed before I had my full exhaust on. With just a slip on, flapper mod, and pc3 you could really tell a difference, smoothed out entire rpm range, and made the bike alot more predictable. Plus its cool to be able to tweek your fuel delivery.
After I put on the full pipe, the pc3 obviously is a must, and it has done well, loaded up the map, took it for a ride, and everything ran perfect.
Rate it 10 out of 10, Easy to install, and worth the money. |
04-12-2008, 9:59 PM
Bike(s): 01 CBR 929 rr Posts: 48
| Re: Power Commander 3 - 929RR awesome where did you get it im lookin for one?? |
04-12-2008, 11:47 PM
Bike(s): XX, RC51, '08 1000RR LE Posts: 1,680
Rep:  (51) Rep Power: 4
| Re: Power Commander 3 - 929RR Where can't you find a PC. |
04-14-2008, 4:33 PM
| Re: Power Commander 3 - 929RR just lookin for the best pricing. |
04-14-2008, 10:57 PM
Bike(s): '01 CBR929RR Age: 36 Posts: 21
| Re: Power Commander 3 - 929RR Quote:
Originally Posted by icefire just lookin for the best pricing. | 58cycle Parts & Accessories Webstore |
04-14-2008, 11:42 PM
Bike(s): Erion Racing 929 RR 2001 Posts: 59
Rep:  (16) Rep Power: 1
| Re: Power Commander 3 - 929RR I bought mine off e-bay and it's been excellent. You can even get a 954 power commander, since it's identical to the 929's, it just has different mapping. One thing to make note, for you that haven't tried it. Enable the accelerator pump, then set it up. I have mine set up for 90% sensitivity, 20% more fuel, for 15 revolutions, which is what Dynojet suggested for streebikes....and it's great. It smoothed out bottom end, especially. It squirts in extra fuel, when you first demand acceleration from the bike, so it makes it accelerate better when you first hit the throttle. |
04-15-2008, 1:45 PM
Bike(s): 01' 929 04'yzf600 not r6 Posts: 18
| Re: Power Commander 3 - 929RR stupid question but i have a pc3 and i was looking at the maps from power commander what would happen if i uploaded a european full power map on my us bike will i gain anything |
04-15-2008, 11:30 PM
| Re: Power Commander 3 - 929RR What you are shooting for is optimum fuel/air mixture. Optimum is said to be right around 14 parts air to 1 part finely atomized fuel. It must be finely atomized, or your engine will act lean, even if it is the right amount of fuel but the drops are too big to atomize correctly. Let's just say that your fuel injectors are taking care of that, for arguments sake--if that european map just so happens to give you the right mapping to give you 14:1 mixture at all RPM, then yes, you will gain efficiency, if not, you will lose. |
04-15-2008, 11:32 PM
| Re: Power Commander 3 - 929RR To add to my last statement, if you are really wanting to make sure that your enigine is tuned correctly, with the right map, bring it to a dyno shop, and have a custom map made for it. |
04-21-2008, 9:57 PM
| Re: Power Commander 3 - 929RR thanks bikePilotRR for the answer |
08-31-2008, 5:24 PM
Bike(s): Black 929 2000 Posts: 17
| Re: Power Commander 3 - 929RR Hi Everyone, I'm sure I need a Power Commander as the fuelling on my 929 is crap. Do I need to get a Power Commander made specifically for this exact model of will any Power Commander 3 be OK? Also, do I need to get it set up (I've been quoted £145 + tax!!) or will it be ok ouf of the box.
Also, maybe stupid question, but where does it plug into and will it need to be installed by a professional? I don't know a thing about bikes by the way. At the moment, this Power Commander idea looks likes it's gonna cost be about £600!!!! Can it be worth it? |
08-31-2008, 6:42 PM
| Re: Power Commander 3 - 929RR It's definately going to make a big difference in the power characteristics of your engine... that being said, only you can say if it's worth it or not. I would tend to say that if you're a novice, (which it sounds like you may be) then I would say that it probably isn't "worth it" since you probably aren't working on things, such as somoothing out you power delivery to strafe the apexes better, you're probably still working on taking off from a stop light smoothly, and not worried about maximizing lateral grip while leaned over @ 50+ degrees. But even so, I know that there is a draw to putting stuff on your bike to make it better, faster, more powerful.... so that beinthe case, the Power Comander is an easy insstall. Even anyone with minimal mechanical skills can install it. It plugs in series to your existing wiring harness , the hardest part is routing the wires, and that's not even hard to do. Since you have a 929, you can buy a Power Commander for a 929 or a 954, they are identical except for the map that is downloaded onto the module....which you can update through your PC easy enough. Hope that helps. |
