Best mod ever! Accelerator pump its free! Need powercommander
05-18-2008, 4:41 PM
Bike(s): cbr 929rr, 2008 ninja 250r, YZF 426 Age: 34 Posts: 677
Rep:  (16) Rep Power: 2
| Best mod ever! Accelerator pump its free! Need powercommander I just downloaded and installed the free program from powercommander called the accelerator pump feature.
This is the best mod that I've done to my bike (929rr). I just installed a full exhaust which made a substantial increase in power across the board, but this accelrator pump mod is amazing. Apparently it squirts a bit of extra gas when you turn the throttle. It only give the extra amount for 20 rounds, but you can adjust how long it gives it as well.
It really makes the bike more fun to ride. It changes the character of the bike. It gives that extra oomph that a muscle car gives when you step on the throttle. You know that put you back in your seat a bit feeling.
The settings that come from the download are the ones that most street riders will start with. I haven't played with the settings yet, but I'm not sure I will.
It's a night and day difference when you install it.
You must have a powercommander usb version though. This mod alone would be reason enough to shell out the bucks for a powercommander.
Anyone else try this? If so, were you as impressed with it as I am? |
05-18-2008, 7:19 PM
Bike(s): '01 CBR929 Age: 49 Posts: 7,915
| Re: Best mod ever! Accelerator pump its free! Need powercommander
06-02-2008, 1:44 PM
Bike(s): 2003 cbr 954rr w/m4 full exhaust Age: 31 Posts: 3
| Re: Best mod ever! Accelerator pump its free! Need powercommander where did you get the mod, do you have a link. im still stuck witht the lcd mapper and waiting to update to new firmware so it can work correctly. |
06-02-2008, 5:22 PM
| Re: Best mod ever! Accelerator pump its free! Need powercommander http://www.powercommander.com/downlo...PumpEnable.exe
Try that. You have to have the usb version of the powercommander.
Believe me, you'll love it!
The settings that are preset are pretty good. I haven't changed the settings at all and love it. |
06-04-2008, 3:57 PM
Bike(s): Cbr954 Posts: 51
Rep:  (11) Rep Power: 1
| Re: Best mod ever! Accelerator pump its free! Need powercommander will it work even with just a slip on? |
06-04-2008, 7:22 PM
| Re: Best mod ever! Accelerator pump its free! Need powercommander yes the mod will work as long as you have a powercommander III usb. The powercommander completely changed the character of my bike when I had just a bolt on. It made the power delivery electric. It erased all of the dips in the powerband. You'll need a map for your slip on to get the effects. The accelerator pump mod will also work well. |
06-05-2008, 4:58 AM
Bike(s): CBR954RR Posts: 13
| Re: Best mod ever! Accelerator pump its free! Need powercommander Odd. It didn't seem to do anything at all on my 600RR. That was with a Micron slip-on and PCIII. Don't get me wrong, the slip-on helped and the PCIII and mapping helped more. It's just the AP mod didn't change anything. |
06-05-2008, 8:14 AM
| Re: Best mod ever! Accelerator pump its free! Need powercommander Are you sure it is activated on your bike? Check again and make sure it is on. It can be loaded and turned on or off. It was very obvious that the mod was working on my bike. 15% extra fuel for 20 revolutions should do something. If not, the powercommander wouldn't do much either since it only controls fuel. |
06-05-2008, 8:23 AM
| Re: Best mod ever! Accelerator pump its free! Need powercommander Yeah, maybe I wasn't doing something right. I didn't experiment for very long. If I pick up a PCIII for the 954 I'll try it again. |
06-05-2008, 2:10 PM
| Re: Best mod ever! Accelerator pump its free! Need powercommander Quote:
Originally Posted by curt248 yes the mod will work as long as you have a powercommander III usb. The powercommander completely changed the character of my bike when I had just a bolt on. It made the power delivery electric. It erased all of the dips in the powerband. You'll need a map for your slip on to get the effects. The accelerator pump mod will also work well. | Thanks I will be sure to try it. |
07-24-2008, 8:20 PM
Bike(s): 2001 CBR929 Tricolor Posts: 1
| Re: Best mod ever! Accelerator pump its free! Need powercommander WOW!!!!! I installed the accelerator pump on my 2001 CBR 929 and all I can say is DO IT!! Makes a huge difference, now the bike is weeling in third. With no clutching. Best part its free. |
08-31-2008, 5:03 PM
Bike(s): Black 929 2000 Posts: 17
| Re: Best mod ever! Accelerator pump its free! Need powercommander I think I might need a Power Commander as the fuelling is very unpredictable at low revs and in low gears. Are they tricky to install/set up? There seem to be quite a lot on Ebay but do I need to get one specifically designed for my exact bike? |
08-31-2008, 6:43 PM
#13 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander Please describe your technique for 3rd gear no clutch wheelies. What speed or rpm are you at? |
08-31-2008, 11:32 PM
#14 |
Bike(s): 2006 Fireblade and 2002 hornet 919 Posts: 22
| Re: Best mod ever! Accelerator pump its free! Need powercommander Hi, can you's that have instaled this tell us somethings about this,that us skeptics on here are pondering. 1; Does it kick in (like turbo) or smooth for safe cornering? 2; It it a heavy usage of fuel that gives the extra power? 3; It is in every gear regardless if you want it on not? And finally 4; For those of you that have it a while, how's your chain and tyre life with this extra power? |
09-01-2008, 2:05 AM
#15 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander It can be adjusted to be smoother or more abrupt. The track settings are softer and the street settings are more abrupt. It happens weather you want it or not. You will probably like having it in all gears after trying it. The bike will seem weak without it. I'm sure it will eat your tires a bit quicker, but I'm not sure how much yet. As I get more experience I tend to ride harder so chain and tire life should become less t hough I havnn't noticed it yet. It's fine for cornering in my experience. It's not an unsafe rush just a bit of extra power, from extra fuel, for only 15 to 20 revolutions of the engine. So at 3000rpms (at 20 revs) its on for only 0.02 seconds. It reallly makes the bike feel more responsive and adds to the fun factor. |
09-01-2008, 2:18 AM
#16 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander At the risk of sounding silly, is it just a gimmick? I mean, if it pumps more gas, well it must allow more air, otherwise it's just running fat. So, if it's pumping more air and gas, doesn't that happen anyway when you twist the throttle? Is it possible it's effectively just giving it more "throttle" even though you twist it the same? Your brain would notice the new difference between your hand, and acceleration, making you think it has more power when really that's not the case...anyone? |
09-01-2008, 10:55 AM
#17 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander That's a good point. For those of us who have tried it, we can tell you it makes a noticeable difference. I don't think it would be possible to give 20% more throttle for 0.02 seconds. The computer is much faster than we could ever be. If you've used a powercommander before, you'd notice that changing the amount of fuel makes big differences in the way the engine performs and how it feels. It made such a positive difference in my bike that I will buy one for every bike I get in the future. It really makes the bike smoother and more powerful, with the correct map of course. The fact that so many people have them is an indication of how good they are. I would never drop close to $300 on a gimmick and I doubt that many others would either. The powercommander itself made a giant difference, but the accelerator pump mod was total icing on the cake. A mod that can be felt immediately is a good mod indeed. There was no extensive riding to see if the mod made a difference. It was noticeable right away. Even my full exhaust was a bit hard to tell if it was better at first. It was worth an extra 10 HP. Part of that was the sound was so different that I didn't want to attribute any power difference to the drastically different exhaust note. When I did staight line acceleration tests again my buddy there was no question. Our bikes were close to even before the exhaust. After, my bike pulled on him easily at any time with authority.
09-01-2008, 11:05 AM
#18 |
Bike(s): XX, RC51, '08 1000RR LE Posts: 1,672
Rep:  (51) Rep Power: 4
| Re: Best mod ever! Accelerator pump its free! Need powercommander It adds more fuel to compensate for the engine to lean out a bit when you are hard on the throttle. There is a lag between the new mixture getting to the combustion chamber and when you get on the throttle. |
09-03-2008, 9:31 AM
#19 |
Bike(s): 07 cbr1000rr Posts: 12
| Re: Best mod ever! Accelerator pump its free! Need powercommander I did the mod and it worked great....It seems like I found long lost power  |
09-03-2008, 11:52 AM
#20 |
Bike(s): 2001 CBR929RE1 Age: 31 Posts: 1,176
Rep:  (65) Rep Power: 8
| Re: Best mod ever! Accelerator pump its free! Need powercommander damnit i'm gonna do it as well when i get home. |
09-03-2008, 12:00 PM
#21 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander your going to love it. Just use the settings that are downloaded with the program. No need to make any adjustments before you try it out. |
09-03-2008, 3:31 PM
#22 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander I did 95, 20, 20 on the settings |
09-03-2008, 10:46 PM
#23 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander OK, thanks curt248 for all that info, that's my weekend project confirmed, I'll post up when it's finished. |
09-07-2008, 11:52 AM
#24 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander Curt, where did this map come from, it doesn't appear in the list of downloadable maps on Dynojet's website? I've got a 2000 929; is that what it's designed for? |
09-08-2008, 12:19 AM
#25 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander It's not a map, it's an add on module. It is on dynojets website. It's a seperate program from the maps. |
09-08-2008, 12:38 AM
#26 |
Bike(s): 02cbr954 Posts: 1,161
Rep:  (26) Rep Power: 5
| Re: Best mod ever! Accelerator pump its free! Need powercommander I liked it When i first put it on but realized i wasnt as smooth with the throttle so I turned it off. |
09-08-2008, 8:16 AM
#27 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander okay, my observations.
It didn't give me that special turbo boost  at start but it did help fix that lack of power before the kick in the pants at 3-4 k's ( from the erion full systemm, that the pc3 erion map couldn't fix) so it does now give more even power output through the rev's. very good thing.
the only thing i'm worried about is at cold start ( kinda chilly out today), the bike fired up then died. ( almost the first time ever). had to give it some gas during idle just to make sure. i'll have to look into it cause it was the first run after to upgrade. |
10-06-2008, 4:32 AM
#28 |
| Re: Best mod ever! Accelerator pump its free! Need powercommander Well I put it on both my bikes but just got "ENABLED" or "DISABLED" but no options for the settings. I've not got a chance to test it yet (rain). This was from www.powercommander.com. |
10-06-2008, 6:14 PM
#29 |
Bike(s): All Black '07 Fire Blade 1000rr Posts: 20
Originally Posted by nav900 Well I put it on both my bikes but just got "ENABLED" or "DISABLED" but no options for the settings. I've not got a chance to test it yet (rain). This was from www.powercommander.com. |
I found this interesting as well, so I checked my power commander settings, no option available. I did the download and enabled the accelerator pump. After doing so you have to use the power commander drop down tab to open the settings so you can adjust accordingly. I wasn't able to try it out due to rain today either but I sure am curious as to the hype. Any one that did this, did you use the generic race or street settings or find something a little more outside the parameters that gave your bike better throttle response? |
10-06-2008, 9:10 PM
