Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > Articles: General
Articles: General: General Motorcycle Articles.
Coolant Changing / Radiator Flushing
Old 04-05-2005, 4:19 PM
ConqSoft's Avatar
Bike(s): 2007 Honda ST1300
Rep: ConqSoft is a splendid one to beholdConqSoft is a splendid one to beholdConqSoft is a splendid one to beholdConqSoft is a splendid one to beholdConqSoft is a splendid one to beholdConqSoft is a splendid one to beholdConqSoft is a splendid one to behold (838)
Submitted By: abtech
Changing your coolant:
  • Remove radiator cap.
  • Remove cap from overfill tank.
  • Place large drain pans on both sides of bike.
  • Remove overflow vent hose at radiator filler and aim the now open hose into the drain pan.
  • Undo the hose clamps from the large radiator hoses at the engine. (make certain the pans are large enough, or do it one side at a time)
  • Pull hoses from engine flanges.
  • At this point all of the coolant will drain from both the radiator and the engine. If you turn the engine over a couple of times (not running, just cranking) you will spit out any left in the block.
  • Replace hoses, caps etc.
  • Fill with whatever you will be using.
Flushing your radiator:
  • If you need to flush the system, then only remove one hose and use a garden hose or equivalent (connected to a water supply – tap water is ok) to run water through the system. When I do mine for the first time, I leave the lowest hose open, turn on the faucet and start the engine to flush the water jacketing. After about 2 minutes, turn off the engine, then the water and remove the other hoses and let it drain.
Note:
Many people have asked why I would use tap water (or water from a garden hose) when the service manual (and good sense) dictate the use of distilled water only to prevent corrosion. I only use tap water to flush the system, but always use distilled water and Water Wetter when refilling. When flushing, you need some decent pressure and a lot of water, so using distilled water for this purpose just isn't practical.
ConqSoft is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:16 AM.
