Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > Articles: General
Articles: General: General Motorcycle Articles.
Setting Suspension Sag On Your Motorcycle By Yourself
Old 06-25-2006, 1:03 PM
I slide good in the wet
clutchslip's Avatar
Bike(s): 04 Fireblade
Rep: clutchslip has a spectacular aura aboutclutchslip has a spectacular aura aboutclutchslip has a spectacular aura about (249)
Setting sag by yourself.
This came up here:
Suspension questions...........went for a ride today and realized mine sucks
So I thought I'd post-up the technique for everyone to set sag all alone.
For further information on sag, please see the many threads and articles about setting sag.
A good description by ABTECH is in this thread:
lowering front end does what ?
Setting sag without help:
These procedures assume you have your kick-stand in place, otherwise you need a chock.
Things you need -
(If you use the manufacturer's full suspension travel numbers, you do not need to lift the bike front or rear. Their numbers may or may not be accurate for setting sag at home.)
1. A steering pin lift for the front.
(Or other means to unload the forks with the wheel attached.)
2. Measuring tools. Accuracy is good.
The forks only need a tool to 150 mm.
The shock requires a tape measure or yard stick.
3. Zip ties for the forks.
4. Marks-a-lot or other pen/pencil.
5. Cardboard or other stiff material that can be marked.
6. Tape.
Two things you NEED to be able to do.
1. Lift the bike so the rear wheel is off the ground for a split second. (unless using the manufacturer's numbers)
If you cannot do this by yourself, you will need to hoist the bike rear from the sub-frame (tail area).
Very important:
2. You need to balance on your bike for 1 second or less.
If you cannot do this, you cannot set your sag.
(If you can't do this, you should practice a lot more.)
What you are doing:
You just need the three length numbers: unloaded, bike weight, bike+you weight.
Please see elsewhere for what these measurements mean. This is covered, over and over, on this forum and elsewhere.
Sag numbers are RELATIVE. That means as long as you take your measurements the same way from the same locations, they are correct. You can do all the bouncing or whatever you like during testing. That's up to you. Just remember to give about 1 sec for the suspension to settle down.
Forks:
The forks are easy, once you have the unsprung number.
1. Measure the unsprung length to a zip-tie on the left fork to stay consistent with the other measurements.
When you put a zip-tie on the left fork, it marks the farthest the forks have compressed.
When you lean the bike onto the kick-stand, it unloads the forks. The zip-tie stays in place.
2. Bike weight - just hold the bike upright for a split second.
3. You and bike weight - balance on board for a split second.
Shock:
There are a couple of ways to mark the measurements. Please do what you like. One way is not better than another. Remember, the numbers are RELATIVE, so take the measurements the same way.
Set-ups:
(It is easier to use the right side of the bike if you have a kick-stand.)
Method 1 -
A. Tape a marks-a-lot (or other pen) to/or near the rear axle.
B. Tape cardboard or other stiff material to bike directly above the axle.
(Obviously the cardboard must be long enough to be marked by the pen)
Method 2 -
A. Tape cardboard to the axle/swing-arm.
B. Tape pen to to bike directly above the axle.
In both methods, mark the cardboard exactly where you attached it, in case it comes loose or you need to move it. If you do a lot of adjusting, you will need to move the cardboard or change pen color so you don't get confused. (Changing colors helps, anyway, btw.)
The hardest part - the unsprung length:
1. Measuring the unsprung distance.
Without a hoist, you have to lift the rear wheel off the ground. You do NOT need to hold the wheel off the ground. This takes a thousandth of a second. The mark will be left on the cardboard. (I can lift my 2004 Fireblade. I weigh 175, I'm over 50, and I don't pump much iron.)
Please, use leverage and don't hurt your back.
Like the forks; when you lean the bike onto the kick-stand, it unloads the shock. The pen will leave a mark the farthest it has traveled.
1. Bike weight - hold the bike upright for a split second. Again, the pen will mark the farthest travel.
2. You and bike weight - balance on board for a split second. The cardboard has a new mark.
You now have all the numbers necessary.
Notes:
You can perform the front and rear measurements at the same time. (Not the "unsprung" length, though. Don't be silly.)
Keep those full length, unloaded numbers. They should never change much and they are the hardest to get.
Chock users - if you cannot get on/off the bike cleanly, use a crate or other step.
All interpretation of numbers and "proper sag" settings I leave to others.
If there is any confusion about my instructions, or there are errors, please post-up.
Good luck and good sagging by yourself.
-the clutchslip
P.S. Wow - this is big when posted!
clutchslip is offline
View clutchslip's Profile View clutchslip's Gallery Find More Posts by clutchslip
Old 06-25-2006, 10:02 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
Rep: seamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud of (1425)
Re: Setting sag by yourself
Originally Posted by clutchslip
...Not the "unsprung" length, though. Don't be silly...
I can.
seamus is offline
View seamus's Profile View seamus's Gallery Find More Posts by seamus
Old 06-27-2006, 3:56 AM
clutchslip's Avatar
Look I found a pic of seamus doing his one man pit crew:
I think he's saying: "You WILL set your sag, properly!!!!
Old 06-27-2006, 9:35 AM
Mr. Brownstone
Bike(s): 05 600RR
Rep: BDA116 has a brilliant futureBDA116 has a brilliant futureBDA116 has a brilliant futureBDA116 has a brilliant futureBDA116 has a brilliant futureBDA116 has a brilliant futureBDA116 has a brilliant futureBDA116 has a brilliant futureBDA116 has a brilliant futureBDA116 has a brilliant futureBDA116 has a brilliant future (1801)
Ever notice how the Hulk's pants always stay on nicely there in the groin area? That area is never large enough to bust open the shorts, rather it always stays as small as it is.
Hmmmmm.......................................
BDA116 is offline
Old 06-27-2006, 12:38 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
That's because it's the one thing I don't need when I'm angry and it would just get in the way. When I'm prepped for action, the blood flow causes the rest of my body to shrink.
My real cause for concern is why you would notice that. Got something you'd like to tell us, BDA? It's okay, we can still be friends.
seamus is offline
Old 06-27-2006, 1:01 PM
Mr. Brownstone
Bike(s): 05 600RR
Your green skin makes me horny, baby.
BDA116 is offline
Old 06-27-2006, 2:15 PM
schnogg's Avatar
Bike(s): 2000 929 (sold), 2007 GSXR 750
Rep: schnogg is on a distinguished road (35)
All your sag are belong to us!
schnogg is offline
View schnogg's Profile View schnogg's Gallery Visit schnogg's homepage! Find More Posts by schnogg
Old 06-27-2006, 8:41 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
Ok. Maybe we can't be friends...
seamus is offline
Old 06-28-2006, 12:05 AM
SomeStrangeGuy's Avatar
Bike(s): Addicted to them.
Rep: SomeStrangeGuy has much to be proud ofSomeStrangeGuy has much to be proud ofSomeStrangeGuy has much to be proud ofSomeStrangeGuy has much to be proud ofSomeStrangeGuy has much to be proud ofSomeStrangeGuy has much to be proud ofSomeStrangeGuy has much to be proud ofSomeStrangeGuy has much to be proud ofSomeStrangeGuy has much to be proud of (1106)
I refuse to set sag, when they hit 25 they are out the door and the cycle repeats.
SomeStrangeGuy is offline
View SomeStrangeGuy's Profile View SomeStrangeGuy's Gallery Find More Posts by SomeStrangeGuy
Old 08-06-2006, 1:18 PM
ihatecrashing's Avatar
Bike(s): 2001 929RR Knightrider Black
Rep: ihatecrashing will become famous soon enough (71)
Send a message via AIM to ihatecrashing Send a message via MSN to ihatecrashing Send a message via Yahoo to ihatecrashing
Awesome article! Thanks!!!!
ihatecrashing is offline
View ihatecrashing's Profile View ihatecrashing's Gallery Find More Posts by ihatecrashing
Old 04-16-2007, 10:24 PM
Bike(s): 2001 929RR
Rep: Mad-Pad is on a distinguished road (10)
I think maybe the two of you need to be "friends" and compare one another sag!
Mad-Pad is offline
View Mad-Pad's Profile View Mad-Pad's Gallery Find More Posts by Mad-Pad
Old 05-28-2007, 12:10 PM
Bike(s): 2000 CBR 929rr
Rep: IMATOPGUN is on a distinguished road (10)
Send a message via AIM to IMATOPGUN
Re: Setting Suspension Sag On Your Motorcycle By Yourself
The Hulk's groin does not enlarge like the rest of his body do to the steriods. The steroids shrink the groin area.....
IMATOPGUN is offline
View IMATOPGUN's Profile View IMATOPGUN's Gallery Find More Posts by IMATOPGUN
Old 06-17-2007, 3:27 PM
Bike(s): 2000 929
Rep: ratchetman is on a distinguished road (31)
Why do I want to set sag?
ratchetman is offline
View ratchetman's Profile View ratchetman's Gallery Find More Posts by ratchetman
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:56 PM.
