Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > Articles: General
Articles: General: General Motorcycle Articles.
Benelli 1130 Cafe Racer
Old 08-13-2007, 6:21 AM
Website Owner - AYS
.OrgOwner's Avatar
Rep: .OrgOwner is a jewel in the rough.OrgOwner is a jewel in the rough.OrgOwner is a jewel in the rough (272)
Specifications - Benelli Cafè 1130 Racer -
Here are some basic specs on the exotic Benelli -
Engine4 stroke, 3 cylinders in line, tilted forwards 15°, fitted with anti-vibration countershaft
Bore x stroke88 x 62 mm
Engine Displacement1130 cc
Compression ratio11.5:1
Cooling systemLiquid, with lateral double radiator, served by two electrofans
Oil cooling systemWith radiator
DistributionChain driven double head cam shaft with 4 valves per cylinder
LubricationWet sump
Max power/rpm101 kW at 9250 rpm
Max torque/rpm117 Nm at 6750 rpm
CarburretionElectronic injection with 1 injector per cylinder
IgnitionSingle coil inductive discharge electronic ignition
ClutchWet clutch
Gearbox6-speed extractable
TransmissionStraight toothed primary gear, chain driven secondary
Exhaust systemStainless steel
FrameMixed solution. Front: ASD steel tube trellis, fastened with screws to boxed rear section, aluminium alloy castings. Subframe: aluminium die-cast.
SuspensionFront: Marzocchi "upside down" fork diameter 43 mm, damping,rebound and spring pre-load adjustment; Rear: ASD steel tube trellis swingarm with Extreme Technology single shock absorber with spring pre-load adjustment
WheelsBrembo cast aluminium alloy front 3.5"x17", rear 6.00"x17"
TyresTubeless, radial; Front 120/70 x 17" - 120/65 x 17"; Rear 190/50 x 17" - 200/50 x 17" - 180/55 x 17"
BrakesBrembo. Front: double floating disk, diameter 320 mm, with twin 4-piston caliper. Rear: with single disk, diameter 240, with twin piston caliper
DimensionsWheelbase 1419 mm; seat height 780 mm
Dry weight199 kg
.OrgOwner is offline
Old 08-15-2007, 7:42 PM
bjay51d's Avatar
Bike(s): 02cbr954(rip)05 zx10
Rep: bjay51d is a jewel in the roughbjay51d is a jewel in the roughbjay51d is a jewel in the roughbjay51d is a jewel in the rough (346)
Re: Benelli 1130 Cafe Racer
Robocop is somewhere blowing a fuse over this bike
bjay51d is offline
View bjay51d's Profile View bjay51d's Gallery Find More Posts by bjay51d
Old 08-15-2007, 7:58 PM
Website Owner - AYS
.OrgOwner's Avatar
Yeah your probably right on with your comment but it's good look at the exotic stuff every now and again.
Old 08-15-2007, 8:05 PM
bjay51d's Avatar
I wouldnt mind having that in the stable it just looks alittle busy
bjay51d is offline
Old 08-15-2007, 8:17 PM
Website Owner - AYS
.OrgOwner's Avatar
Yeah the only thing about bikes like that I guess is that if you need to get a part in a hurry it might not always be that easy or cheap. I think I could find a place for one in my shed.
Old 08-16-2007, 2:14 PM
Bike(s): '03, CBR954RR; Titanium & '04 CBR600RR; Blue
Rep: Phadreus is on a distinguished road (43)
My guess is he's out back fighting over the bike with Judge Dred!
Phadreus is offline
View Phadreus's Profile View Phadreus's Gallery Find More Posts by Phadreus My Map Location
Old 08-16-2007, 9:11 PM
Website Owner - AYS
.OrgOwner's Avatar
Or perhaps it "transforms" into something.
Old 08-16-2007, 11:05 PM
Bike(s): XRR 'tard, VFR
Rep: slickwill is a jewel in the roughslickwill is a jewel in the roughslickwill is a jewel in the rough (252)
Had to do the conversion.
That amounts to 135 HP and 86 ft/lb
439 pounds dry weight
Not that impressive...unless you're Robocop I guess
slickwill is offline
Old 08-17-2007, 12:51 AM
Bike(s): 2005 honda repsol cbr 1000rr5
Rep: hondapowered is on a distinguished road (12)
Kick ROBO cop's A$$
Manufacturer MV Agusta Model Year 2007 Model F4-1000 Senna MSRP DONT LOOK HERE POWERTRAIN Engine 4-cylinder, 4-stroke, 16-valve, DOHC, radial valve, liquid-cooled, water-oil heat exchanger Displacement 60.8 ci Bore x Stroke 3 x 2.2 in. Compression Ratio 13:1 Torque 111 Nm (11.3 kgfm) @ 10,000 rpm Horsepower 174 hp (128 kW) @ 11,900 rpm DRIVETRAIN Ignition Electric Transmission Cassette gearbox, 6-speed, constant mesh Clutch Wet, multi-disc DIMENSIONS Frame CrMo steel tubular trellis (TIG welded) Length 79.01 in. Width 26.97 in. Wheelbase 55.4 in. Seat Height 31.87 in. Ground Clearance 5.12 in. Dry Weight 418.8 lbs. Fuel Capacity 5.52 gal. (1.06 gal. reserve fuel) BRAKES / WHEELS / TIRES Suspension Front: Upside-down telescopic hydraulic fork w/ rebound-compression damping & spring preload adjustment; 5.07 in. travel
Rear: Progressive, FI-derived single shock w/ rebound-compression (hi/low) damping & spring preload; 4.72 in. travel Brakes Front: Double floating 12.6 in. disc w/ steel braking band and aluminum flange; radial-type, 4-piston, 1 in. caliper
Rear: Single steel 8.27 in. disc; 4-piston, 1 in. caliper Tires Front: 120/70-ZR 17 (58 W)
Rear: 190/55-ZR 17 (75 W) Trail 4.08 in.
hondapowered is offline
View hondapowered's Profile View hondapowered's Gallery Visit hondapowered's homepage! Find More Posts by hondapowered
Old 08-17-2007, 9:38 AM
I like that one a lot. Much more to my tastes. Dry weight of 418 plus a 5.5 gal fuel tank means a 470-480 pound bike though. Still pretty heavy. 174 HP will help make up for that but I think that much weight def. means giving up some handling quickness. It's probably rock solid though.
Old 08-17-2007, 8:53 PM
The MV is pure sex on wheels! I'd take it...
Phadreus is offline
Old 08-17-2007, 10:30 PM
Here is a great MV page detailing the F4 - Tamburini
Edit: MV Agusta F4-1000 Tamburini
It doesn't list the MSRP until the bottom of the page. I know 42K is a ridiculous amount for a bike but after reading the entire page about the bike I thought the MSRP was going to be double that. No wonder it is sold out.
Old 08-17-2007, 10:36 PM
Originally Posted by slickwill View Post
Here is a great MV page detailing the F4 - Tamburini<snip>.
Oopsey, I think you missed the URL.
Phadreus is offline
Old 08-17-2007, 10:57 PM
How about the F4CC? 195mph, $120,000, beautiful carbon fiber body work. Includes a 15000 euro special edition watch.
MV Agusta F4CC
Old 08-17-2007, 11:13 PM
  #15
MV Agusta F4CC
I guess it's "ok" if you like that sort of bike, you know; rare, wrapped in carbon fiber, loaded full of race bits, fast, beatiful...
Would you go for one of those, or a garage with 10 different SBK's in it?
Phadreus is offline
Old 08-17-2007, 11:45 PM
  #16
I'd go for one of those over the garage full of SBK's, you can only ride one at a time. Unless by SBK you mean a factory bike built for WSBK competition. I really want to get my hands on a top level ex-racebike. Obviously getting my hands on a GP bike would be the ultimate dream.
Old 08-18-2007, 12:16 AM
  #17
You just missed Larry Pegrams CBR1000 a few months back on e-bay. Buy Now = $25K. Not bad considering...
I read once that Honda said they have about $15 million per copy in their RC211V. I haven't seen any of them come accross ebay yet...but I'm waiting.
Phadreus is offline
Old 08-18-2007, 11:27 AM
  #18
I read once that Honda said that have about $15 million per copy in their RC211V. I haven't seen any of them come accross ebay yet...but I'm waiting.
Wow, I was talking to my wife about it last night and guessed $5 million per GP bike.
Old 08-18-2007, 4:27 PM
  #19
bjay51d's Avatar
MV Agusta F4CC
bjay51d is offline
Old 08-18-2007, 4:30 PM
  #20
Why do people keep doing that to the bikes I post up? Point that the other direction.
Old 08-18-2007, 4:48 PM
  #21
bjay51d's Avatar
come on man alittle monkey spunk never hurt anyone....
bjay51d is offline
Old 08-22-2007, 9:41 PM
  #22
Bike(s): CBR954RR 2003
Rep: GreginOz is on a distinguished road (10)
Lay down misere...
MTT- Turbine SUPERBIKE, Y2K bike, Jet Bike, Jay Leno’s motorcycleMTT- Turbine SUPERBIKE, Y2K bike, Jet Bike, Jay Leno’s motorcycle
GreginOz is offline
View GreginOz's Profile View GreginOz's Gallery Find More Posts by GreginOz
Old 08-22-2007, 10:40 PM
  #23
Been down that road...
Bike(s): '03 919 '96MZ660Skorp '72Trump '94XR600R '03Blast
Rep: 129CBRider is on a distinguished road (27)
I got my whole collection for the price of one ElectraGlide...
You can only ride one bike at a time, but then you can only wear one pair of shoes at a time, too, and who has only one pair of shoes?
129CBRider is offline
View 129CBRider's Profile View 129CBRider's Gallery Find More Posts by 129CBRider
Old 09-21-2007, 2:06 PM
  #24
Bike(s): 2005 CBR 1000RR
Rep: Boy Blader is on a distinguished road (10)
Hi there everyone. It's been a while since my last time in here.
This dude i know her in Australia has one. He was raving on about it and how good it is. But you know he's had nothing but trouble with it. All electrical problems. Been in the shop more times than on the road. "Told him to stay Jap"..Not to mention they cost $25,000 Australian Dollars.
You can check out my post on 2005 engine builds to see what I've been up to.
Cheers.
Boy blader.
Boy Blader is offline
View Boy Blader's Profile View Boy Blader's Gallery Find More Posts by Boy Blader
Old 10-12-2007, 3:28 AM
  #25
Bike(s): 1997 CBR900RR
Rep: fizzerchris is on a distinguished road (10)
Send a message via AIM to fizzerchris Send a message via Yahoo to fizzerchris
I believe Jay Leno called the MTT the "More Money Than Brains Bike"...
2 speed automatic engine: "Fast" and "Did you see something?"
But at least you can get it in a 2 seater... that's just wrong... and not even a good wrong.
fizzerchris is offline
View fizzerchris's Profile View fizzerchris's Gallery Find More Posts by fizzerchris
Old 10-12-2007, 3:46 AM
  #26
Bike(s): 2006 blue and yellow 1krr
Rep: ldavis is just really niceldavis is just really niceldavis is just really niceldavis is just really nice (396)
maybe not compared to the liter class super sports, but take in mind that's it's pretty much a naked bike..
ldavis is offline
View ldavis's Profile View ldavis's Gallery Find More Posts by ldavis My Map Location
Old 10-12-2007, 8:29 AM
  #27
Just traded even my '91 KLR, OEM blue with hot pink Jeremy McGrath KLR logo on the side of the tank for a '94 XR600 street legal Baja Design dual sported thumper for the mountain forest roads/trails...that starter button always made me feel lazy anyway.
Old 10-12-2007, 8:34 AM
  #28
Woods fun!
Old 10-12-2007, 10:34 AM
  #29
Naked should make it ten pounds lighter then. It's worse than I thought.
Old 10-15-2007, 8:47 PM
  #30
they are also produced at a lower power scale, just compare the stats of the new b king to the busa which uses the same motor.. or the 919 vs. any of the other 900's that honda makes.
ldavis is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:35 AM.
