Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > Articles: General
Articles: General: General Motorcycle Articles.
Bimota SB8K
Old 11-06-2007, 7:42 PM
Website Owner - AYS
.OrgOwner's Avatar
Rep: .OrgOwner will become famous soon enough.OrgOwner will become famous soon enough (113)
Bimota SB8K
Bimota SB8K -
Some information outlined on the bike from Bimota
Extensive use of light alloys and carbon fiber
Carbon fiber faring
Carbon fiber fuel tank . Many elements of the SB8K are machined from aluminum alloy, a distinctive feature of all classic and current Bimota motorcycles.
Chassis
The chassis is unique composite structure frame. The upper section is constructed from light alloy and the lower frame section consists of two carbon fiber plates with a box structure that makes for the best possible rigidity to weight ratio. The composite frame creates an extremely lightweight bike - 185 kg (408 lb) on-road weight at an exceptional rigidity.
Front suspension: Öhlins upside-down fully adjustable forks with TiN surface treatment
Front wheel travel: 4.7 in
Front brake: 2 x 320 mm semi-floating discs, 4-piston 4-pad radial calipers - Brembo
Front wheel: 6 spoke design light alloy forged 3.50x17 - OZ
Front tyre: 120/70 ZR 17
Rear suspension: Progressive linkage with fully adjustable Öhlins monoshock
Rear wheel travel: 130 mm / 5.1 in
Rear brake: 240 mm disc, 2-piston caliper - Brembo
Fuel tank capacity: 21 l / 5.6 US gal (including 5 l / 1.3 US gal reserve)
Weight: 175 kg / 400 lbs (includes battery, lubricants and, where applicable, cooling liquid)
Seat height: 810 mm / 31.9 in
Engine
Type: Suzuki TL 1000 R - L twin cylinder,
4 valve per cylinder; liquid cooled
Displacement: 996 cc
Compression ratio: 11.3:1
Fuel injection: Electronic fuel injection, 55 mm throttle body
Exhaust: Double aluminium mufflers
Emissions: Euro 2
ID:	27592  Click image for larger version
.OrgOwner is offline
Old 11-08-2007, 7:57 PM
bjay51d's Avatar
Bike(s): 02cbr954
Rep: bjay51d is on a distinguished road (26)
Re: Bimota SB8K
bjay51d is offline
View bjay51d's Profile View bjay51d's Gallery Find More Posts by bjay51d
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:40 PM.
