| Aprilia SMV 750 Dorsoduro The Aprilia SMV750 Dorosduro is an agressive looking machine. It also features the ride by wire engine control system. Features - Lighweight, 750cc 90 degree fuel injected V-twin. Very over-square bore to stroke ratio
Four valves per cylinder
Double overhead cam with mixed gear and chain timing drive
Electronic fuel injection with two throttle bodies
Stick-coils integrated in the spark plug caps
Three way catalytic converter and Lambda probe
Hydraulically operated clutch
Mixed gear and chain timing drive
Compound steel trellis and aluminium alloy frame for extremely light weight and high torsional rigidity
Aluminium alloy swingarm with offset monoshock
Fully adjustable 43 mm upside down fork
Racing brakes with radial front calipers The Aprilia's V90 engine delivers an amazing 95 hp at 9,000 rpm with 8.25 Kgm of torque at 7,000 rpm, record values for a 750 cc twin. |
