Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > Articles: General
Articles: General: General Motorcycle Articles.
2008 Yamaha R6 Photos & Specifications
Old 01-20-2008, 7:57 PM
Website Owner - AYS
.OrgOwner's Avatar
Rep: .OrgOwner is a jewel in the rough.OrgOwner is a jewel in the rough.OrgOwner is a jewel in the rough (272)
2008 Yamaha R6
"Light, powerful and bristling with knowledge gained from years of racing, the YZF-R6 is the most advanced production 600cc motorcycle Yamaha—or anybody else—has ever built."
"The YZF-R6 was the first production motorcycle with a fly-by-wire throttle system—for flawless response under all conditions"
"YCC-I, Yamaha Chip Controlled Intake, introduced in 2007 on the R1, is now used on the R6 to vary intake tract length for excellent cylinder filling and a broader powerband. On the higher-revving R6, its benefits are even more pronounced"
Engine
Type 599cc liquid-cooled inline 4-cylinder; DOHC, 16 titanium valves
Bore x Stroke 67.0 x 42.5mm
Compression Ratio 13.1:1
Carburetion Fuel Injection with YCC-T and YCC-I
Ignition TCI
Transmission 6-speed w/multi-plate slipper clutch
Final Drive #525 O-ring chain
Chassis
Suspension/Front 41mm inverted fork; 4-way adjustable, 4.7-in travel
Suspension/Rear Single shock; 4-way adjustable, 4.7-in travel
Brakes/Front Dual 310mm floating disc; radial-mount 4-piston calipers
Brakes/Rear 220mm disc; single-piston caliper
Tires/Front 120/70-ZR17
Tires/Rear 180/55-ZR17
Dimensions
Length 80.3 in
Width 27.6 in
Height 43.3 in
Seat Height 33.5 in
Wheelbase 54.3 in
Rake (Caster Angle) 24°
Trail 3.8 in
Fuel Capacity 4.6 gal
Oil Capacity (with oil filter change) Spec Not Available
Dry Weight 366 lb
New Features for 2008
Over 50 friction-reducing strategies have been employed inside the engine, including the use of wider crank bearings.
Upgraded fuel injection mapping for the YCC-T dual-injector system complements the higher compression ratio for great throttle response and reduced engine braking.
A magnesium subframe removes weight from the rear of the motorcycle for increased mass centralization.
All-new frame takes handling to the next level, allowing more precise turn-in, greater corner speed, and tighter exits. Thicker headpipe-headstock and swingarm pivot area walls, and elimination of the frame crossmember, help achieve perfect balance.
New swingarm has internal ribs added, and extruded section is now forged to work with the new frame.
Revised outer fork tubes, a new lower triple clamp, and increased fork offset provide highly tactile front-end feedback.
Moving the rider and bars forward and slightly lower enhances braking and turn-in performance. Clip-ons are also lower and re-angled.
Front discs are 310 x 5mm instead of 4.5mm for increased cooling qualities.
Increased fork height adjustability and rear ride-height adjustment range accommodate a greater range of riders and tires.
Revised bodywork results in even greater aerodynamic efficiency.
MSRP* $9,799 (Cadmium Yellow w/Flames) Available from December 2007
$9,599 (Team Yamaha Blue/White) Available from November 2007
$9,599 (Raven) Available from November 2007
$9,599 (Liquid Silver) Available from November 2007
ID:	28171  Click image for larger version
.OrgOwner is offline
Old 01-28-2008, 2:42 PM
Bike(s): 2000 929RR
Rep: BigMike0147 is on a distinguished road (15)
Re: 2008 Yamaha R6 Photos & Specifications
SWEET Bike!! I'll take one of each please!!
BigMike0147 is offline
View BigMike0147's Profile View BigMike0147's Gallery Find More Posts by BigMike0147
Old 01-29-2008, 12:14 AM
-Z-
Gearhead/Sportbike Nut
-Z-'s Avatar
Bike(s): 1999 VFR800, 2002 954
Rep: -Z- will become famous soon enough-Z- will become famous soon enough (147)
Send a message via AIM to -Z-
I sat on one last Friday in San Francisco...I love how great the performance is supposed to be. But I ran into a problem...I sat on it, and if my legs were maybe just an inch shorter, things would have been fine. But my knees were hitting part of the tank, where it flares out near the top. It was very uncomfortable. I'm not too happy about that. I've never had legs too long for a bike before. Not sure what's up with that.
-Z- is offline
View -Z-'s Profile View -Z-'s Gallery Find More Posts by -Z- My Map Location
Old 01-31-2008, 5:19 AM
Maholli's Avatar
Bike(s): 2008 CBR 1000RR, 2007 CBR 1000RR, 2007 ZX-14
Rep: Maholli is a splendid one to beholdMaholli is a splendid one to beholdMaholli is a splendid one to beholdMaholli is a splendid one to beholdMaholli is a splendid one to beholdMaholli is a splendid one to behold (695)
the 600RR stomps this bike.. stay with honda..
Maholli is offline
Old 01-31-2008, 12:12 PM
-Z-
-Z-'s Avatar
Oh, definitely prefer Honda. I'm just kinda partial to Yamaha too, and always have been. Especially since they made the engine in my awesome 91 Toyota Celica Alltrac (or GT4 for those not in the states). That car's about as wild as a box of frogs on crack!
-Z- is offline
Old 02-01-2008, 7:44 AM
Maholli's Avatar
I like Yamaha but except for alot of minor changes I believe the RR is still gonna be top dog in the 600cc class the engine is just great on the 600RR as well as alot of other things. But the R6 is an awsome 600..
Maholli is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:33 PM.
