Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > Articles: General
Articles: General: General Motorcycle Articles.
2008 Kawasaki ZX6 R Ninja Photos & Specifications
Old 03-06-2008, 7:24 PM
Website Owner - AYS
.OrgOwner's Avatar
Rep: .OrgOwner will become famous soon enough (77)
2008 Kawasaki ZX6
Features -
High-Revving 599cc Four-Cylinder, DOHC Engine
Four-Valve Cylinder Head
Ram Air Induction
Digital Fuel Injection
TCBI Ignition with Digital Advance
Six-Speed Transmission
Racing-Style Slipper Clutch
Gear Position Sensor
Lightweight Twin-Spar Aluminum Perimeter Frame
Uni-Trak® Rear Suspension
41mm Inverted Cartridge Front Fork
Radial Mounted Front Disc Brakes
Aerodynamic Bodywork
Specifications
Engine Type Four-stroke, liquid-cooled, DOHC, four valves per cylinder, inline-four
Displacement 599 cc
Maximum Torque 40 lb ft @ 11,500 rpm
Bore x Stroke 67.0 x 42.5mm
Compression Ratio 13.3:1
Fuel Injection DFI® with four 38mm Keihin throttle bodies, oval sub-throttles, two injectors per throttle body
Ignition TCBI with digital advance
Transmission 6-Speed
Final Drive X-Ring Chain
Rake/Trail 25 deg / 4.3 in.
Frame type Aluminum perimeter
Front Tire Size 120/70-ZR17
Rear Tire Size 180/55-ZR17
Wheelbase 55.3 in.
Front Suspension / wheel travel 41 mm inverted cartridge fork with top-out springs, stepless rebound damping, stepless compression damping, fully-adjustable spring preload / 4.7 in.
Rear Suspension / wheel travel Bottom-Link Uni-Trak® with gas-charged shock, top-out spring and pillow ball upper mount, dual-range (high/low-speed) stepless compression damping, 25-way adjustable rebound damping, fully-adjustable spring preload / 5.2 in.
Front Brake Type Dual 300mm petal-type rotors with four-piston, four-pad calipers
Rear Brake Type Single 210mm petal-type rotor with single-piston caliper
Fuel Tank Capacity 4.5 gal.
Seat Height 32.3 in.
Dry Weight 368.2 lbs.
Color Lime Green, Candy Plasma Blue, Vivid Yellow, Special Edition: Ebony
Warranty 12 months
ID:	28682  Click image for larger version
ID:	28683  Click image for larger version
.OrgOwner is offline
Old 03-10-2008, 11:50 AM
Twincam's Avatar
Rep: Twincam is on a distinguished road (45)
Send a message via MSN to Twincam
Re: 2008 Kawasaki ZX6 R Ninja Photos & Specifications
IMO it looks fairly similar.. I like the colour coded rims on the Kawasaki Green - should have done it for all of them
"Out Of Many, We Are One"
Twincam is offline
View Twincam's Profile View Twincam's Gallery Find More Posts by Twincam
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:34 AM.
