Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > Articles: General
Articles: General: General Motorcycle Articles.
2008 Honda XL700V Transalp - Photos And Specifications
Old 08-17-2008, 4:31 PM
I'm a bird.. NOT a bloke!!!
LoopyLee's Avatar
Bike(s): Honda, Kawasaki
Rep: LoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond repute (2583)
Send a message via MSN to LoopyLee Send a message via Skype™ to LoopyLee
Eight years after the last models release, the new Transalp with its new engine and adventure sports style, reestablishes itself as Europe's most adaptable mid sized motorbike. Easily able to carry two passengers and their gear, this bike can perform easily on any surface. New features include spoked lightweight wheels, a smaller 19 inch front wheel, a wider radial rear tyre, ABS brakes, twin front discs, and a new catalyzer, installed for a low center of gravity, below the swingarm . The contoured dual seat and redesigned rear seat cowl, with integrated pillion grips, will ensure a comfortable ride over any distance for both the rider and passenger .
Specifications
Engine Type: Liquid-cooled 4-stroke 8-valve SOHC 52° V-twin
Engine Displacement: 680.2cm³
Bore & Stroke: 81 × 66 mm
Compression Ratio: 10 : 1
Carburetion: PGM-FI electronic fuel injection
Max. Power Output: 44.1kW / 7,750min-1 (95/1/EC)
Max. Torque: 60Nm / 5,500min-1 (95/1/EC)
Ignition: Digital transistorized with electronic advance
Starter: Electric
Gearbox: 5-speed
Final Drive: O-ring sealed chain
Wheels Front: Aluminum rim/wire spoke
Wheels Rear: Aluminum rim/Tangentially Located (TL) spoke
Tires Front: 100/90 R19M/C (57H)
Tires Rear: 130/80 R17M/C (65H)
Suspension Front: 41 mm leading-axle telescopic fork,177 mm axle travel
Suspension Rear: Pro-Link with adjustable compression damping, 173 mm axle travel
Brakes Front: 256 × 4 mm dual hydraulic disc with dual-piston Combined three-piston calipers, ABS and sintered metal pads
Brakes Rear: 240 × 6 mm hydraulic disc with Combined single-piston calliper, ABS and resin mould pads
Length x Width x Height: 2,250 x 905 x 1,305mm
Wheelbase: 1,515 mm
Seat Height: 841 mm
Ground Clearance: 177 mm
Fuel Capacity: 17.5 litres (including 3-litre reserve)
Dry Weight: KERB weight 218kg (F: 105kg; R:113kg)
ID:	31428  Click image for larger version
ID:	31429  Click image for larger version
ID:	31430  Click image for larger version
Some days you're the bug; some days, the windscreen!
Blade Rider - Life, The Universe & Everything.. Biking
LoopyLee is offline
View LoopyLee's Profile View LoopyLee's Gallery Visit LoopyLee's homepage! Find More Posts by LoopyLee
Old 08-17-2008, 8:58 PM
Bike(s): 1998 CBR 900rr, 1986 Yamaha fz750
Rep: alcopaulic is on a distinguished road (10)
Re: 2008 Honda XL700V Transalp - Photos And Specifications
I want one, I want one badly! This is such a good alternative to the expensive BMW's and KTM's and most likely alot cheaper to maintain also. Does anyone know MSRP on it yet?
alcopaulic is offline
View alcopaulic's Profile View alcopaulic's Gallery Find More Posts by alcopaulic
Old 08-26-2008, 4:56 PM
Bike(s): '98 Fireblade RRW, '88 VFR750 FJ
Rep: Destructo has much to be proud ofDestructo has much to be proud ofDestructo has much to be proud ofDestructo has much to be proud ofDestructo has much to be proud ofDestructo has much to be proud ofDestructo has much to be proud ofDestructo has much to be proud ofDestructo has much to be proud of (1121)
They do look like a good bike, also a good everyday bike, but obviously not as powerful as the bigger BMW's and KTM's. They're selling new for about £5500 or so over here, I think.
Destructo is offline
View Destructo's Profile View Destructo's Gallery Find More Posts by Destructo
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:51 PM.
