Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > Articles: Honda CBR 1100XX
Articles: Honda CBR 1100XX: Articles related to the Honda CBR 1100XX Super Blackbird Motorcycle.
Increasing ride height on the Honda CBR 1100XX Blackbird
Old 07-18-2004, 12:17 AM
...no tour for you!
cbr99xx's Avatar
Bike(s): '03 954, '01 929, '99 1100XX (SOLD :( )
Rep: cbr99xx will become famous soon enoughcbr99xx will become famous soon enough (109)
I got the idea to do this from the CBR1100XX Owner's Org. board.
Why do this?
A couple of reasons, raising the rear ride height gives you more ground clearance and increases rake.
The increased rake makes the bike turn more quickly.
I tour on my XX with Givis loaded down this, combined with a rider weight of 225 lbs, made my bike “slap-happy”. Adding rear ride height is the cure.
Why can’t I raise the rear even more to make it turn quicker still?
Be my guest… But remember that as you increase rake you reduce trail. If trail is reduced too much, instability will become an issue.
Here is how I shimmed the rear shock on my Blackbird.
Step 1) Set bike up with center stand on top of a ¾” thick piece of wood.
Step 2) Remove seat.
Step 3) Unbolt two bolts at the rear of the gas tank and raise the tank. I used a screwdriver to prop up the tank, you can use the wrench in the stock tool pouch (but who wants to put that puzzle back together).
Step 4) Loosen the shock mounting bolt (17mm), you will see the nut you are to loosen as soon as you raise the tank.
Step 5) Install shims on top of the shock mounting clevis. *
* I am using shims purchased at a local hardware store, the slot measures 3/8” and they were labeled 1/8” thick. When I stacked the two shims together I came up with 6mm.
Step 6) Tighten shock mounting bolt (41 ft lbs).
Step 7) Bolt tank back down.
Step 8) Install seat.
Step 9) Go ride!
I should note that this drops the wheel down ¾”-1” at the axel. You will notice this the first time you put the bike up on the center stand. You will still be able to spin the rear wheel but if you are on the slightest incline the rear tire will touch down.
** A 190/50 tire is mounted in the ground clearance picture, clearance for the stock 180/55 will be slightly different.
Name:	Center on board.JPG
ID:	6086  Click image for larger version
ID:	6087  Click image for larger version
ID:	6088  Click image for larger version
ID:	6090  Click image for larger version
ID:	6091  Click image for larger version
Name:	Shims in place.JPG
ID:	6092  Click image for larger version
cbr99xx is offline
View cbr99xx's Profile View cbr99xx's Gallery Find More Posts by cbr99xx
Old 07-19-2004, 1:55 PM
...no tour for you!
cbr99xx's Avatar
Re: Increasing ride height on the XX
This has to be the single best mod I have ever done to a bike. The shims cost .67 each and took all of 30 minutes to install. The increased agility is amazing; my XX had the tendency to run wide at exit (in part due to my Corbin seat allowing me to sit further back from the bars)... Now, with more weight over the front, this has gone away. I believe that when the proper 180/55 tire is installed on the rear, handling will be even better.
BTW... does anyone make rearsets for the XX?
cbr99xx is offline
Old 07-19-2004, 2:40 PM
stegen's Avatar
Bike(s): 2003 VFR, 2005 MV Agusta F4 1+1
Rep: stegen has a spectacular aura aboutstegen has a spectacular aura about (191)
those 2 little things make that much difference? man i am never amazed as to what goes into cycles
stegen is offline
View stegen's Profile View stegen's Gallery Find More Posts by stegen
Old 07-19-2004, 4:22 PM
...no tour for you!
cbr99xx's Avatar
cbr99xx is offline
Old 07-19-2004, 4:32 PM
ND4SPD's Avatar
Bike(s): '84 Magna V30
KB
ND4SPD is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 5:47 PM.
