Go Back   Honda Motorcycles - FireBlades.org Forums > Articles > Articles: Honda CBR 1100XX
Articles: Honda CBR 1100XX: Articles related to the Honda CBR 1100XX Super Blackbird Motorcycle.
Chain Install Guide - Honda CBR 1100XX Blackbird
Old 08-03-2004, 10:10 PM
...no tour for you!
cbr99xx's Avatar
Bike(s): '03 954, '01 929, '99 1100XX (SOLD :( )
Rep: cbr99xx will become famous soon enoughcbr99xx will become famous soon enough (109)
... on the XX
This is how I installed my chain on my ‘99 Blackbird.
Parts list: DID/530ZVM120 (gold) chain
17 tooth drive sprocket
45 tooth driven sprocket (listing correct sprockets for the XX)
Special tools: Motion Pro chain riveting tool
Dremel tool with cut off wheel affixed
Torque wrench
Vernier calipers
I removed the left side faring.
I removed the drive sprocket cover. This appeared to be more difficult than it really was, the hydraulic clutch actuator comes off with the cover (no gasket required). I disconnected side stand kill switch in order to move the wire out of the way.
I loosened the bolt on the drive sprocket while the bike was in first gear and the chain was still tight.
I loosened the rear axel bolt and slackened the chain with the adjusters but did not remove the wheel just yet.
I picked a link and positioned it on the rear sprocket so that it could be reached with the Dremel tool. I then cut the braded part of one of the pins from this link.
Using the riveting tool (in breaker mode) I then pushed the cut off pin out of the link, breaking the chain.
I then removed the chain.
I then removed the rear wheel and installed my new (45 tooth for the XX) driven sprocket, torque to spec. (the nuts on the sprocket can be broken loose before wheel removal)
I then removed the drive sprocket (loosened earlier) and installed my new (17 tooth for the XX) sprocket, torque to spec.
I then cut my new chain to the required number of links (110 for the XX), remembering to… measure twice… cut once.( I broke this chain in the same manner described above)
I fed chain around drive sprocket.
Then I installed the rear wheel, leaving the axel nut loose.
I wrapped the chain around the driven sprocket and installed the rivet type master link making sure to use the supplied grease on the o-rings. I also shot a bit of the same grease up into the link holes before pushing the master link through. Using the rivet tool, I pressed the outer plate on the link (with o-rings greased and in place). Using calipers, I measured the distance between the plates on the links next to my master link. I then pressed the plate on the master link until I was just shy of the measurement I acquired from its neighbor. (When the pin is braded it will push the plate in a bit)
I then configured the rivet tool with the proper attachments to brad the link pins. The service manual listed a measurement for the link pin when it has been braded enough (.217”-.228” for the XX). I stopped working on the link when the pins fell in the middle of the previously stated range.
I tightened the chain, the rear axel nut (torque to spec), installed the front sprocket cover and installed the left side faring. I went for a ride (20-25 miles) and checked the chain again (I had to re-tighten).
After 16,000 miles my XX was in need of a new chain. This seemed a bit early to me but after some research this does fall into a ‘normal’ range of 16K to 23K (albeit at the low end of the scale). The XX had been doing touring duty and started life on a six day trudge up the Blue Ridge Parkway in the rain… everyday… in the rain. I am telling you this because many of you may remember that WD-40 is my friend when it comes to chain maintenance… not true with the ’bird. Being caught in a continuous down-pour I was concerned about my chain , stopped at a cycle shop and bought a can of PJ1. This chain has seen several brands of lube including the (manual) suggested straight 90wt..
The source for my chain and sprockets had 17/44 listed as stock replacements for my bike, as it turns out this is incorrect. I ordered the parts while at work (no manual) and trusted the vendor for this information… BIG mistake. The stock rear sprocket should be a 45 tooth unit… I have the correct sprocket on the way (looked all over locally, but had to order one) but for now, the 44 tooth sprocket will have to do.
Name:	Drive cover removed #3.JPG
ID:	6569  Click image for larger version
Name:	Dremel off link.JPG
ID:	6570  Click image for larger version
ID:	6571  Click image for larger version
Name:	Broken chain.JPG
Name:	Cut new chain.JPG
ID:	6573  Click image for larger version
Name:	Install new chain & sprocket.JPG
ID:	6574  Click image for larger version
Name:	Master link install G.JPG
ID:	6575  Click image for larger version
cbr99xx is offline
View cbr99xx's Profile View cbr99xx's Gallery Find More Posts by cbr99xx
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:59 PM.
