| 2007 Honda CBR600 RR Specifications Model: Honda CBR 600 RR
Year: 2007
Category: Sport
Engine and transmission
Displacement: 599.00 ccm (36.55 cubic inches)
Engine type: In-line four
Stroke: 4
Compression: 12.2:1
Bore x stroke: 67.0 x 42.5 mm (2.6 x 1.7 inches)
Fuel system: Injection. Dual Stage Fuel Injection (DSFI)
Valves per cylinder: 4
Fuel control: DOHC
Ignition: Computer-controlled digital transistorized with three-dimensional mapping
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 156.5 kg (345.0 pounds)
Seat height: 820 mm (32.3 inches) If adjustable, lowest setting.
Chassis and dimensions
Rake (fork angle): 23.7°
Trail: 96 mm (3.8 inches)
Front suspension: 41mm inverted HMAS cartridge fork with spring preload, rebound and compression damping adjustability
Front suspension travel: 119 mm (4.7 inches)
Rear suspension: Unit Pro-Link HMAS single shock with spring preload, rebound and compression damping adjustability
Rear suspension travel: 130 mm (5.1 inches)
Front tyre dimensions: 120/70-ZR17
Rear tyre dimensions: 180/55-ZR17
Front brakes: Double disc
Front brakes diameter: 310 mm (12.2 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Fuel capacity: 18.16 litres (4.80 gallons)
Color options: Black, Pearl White/Silver, Red/Black, Ultra Blue Metallic/Silver
Comments: Model ID: CBR600RR |
