How to Change Oil- 2002 954 - Page 2 - Honda Motorcycles - FireBlades.org
Articles: Honda FireBlade Articles related to the Honda CBR 900RR, Honda CBR 929RR, Honda CBR 954RR, and Honda CBR 1000RR Motorcycles.
post #16 of 23 Old 11-05-2010, 10:15 AM
Reputation Power: 23
Re: How to Change Oil- 2002 954
I always wear nitrile gloves when I work on the bike.
Deadsmiley is offline
post #17 of 23 Old 03-27-2013, 2:56 PM
any chance you could do a step by step for replacing the stator? I just did mine and its making an unpleasant rattling sound and I can smell something rubbing.. not good!!
cloudstalker is offline
post #18 of 23 Old 03-27-2013, 2:58 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Is it in the right way around?
Did you follow the manual?
post #19 of 23 Old 03-27-2013, 3:28 PM
in true have-a-go herbert style I did not have a manual, i took pictures of what it looked like when it came off and tried to follow them going back on. what I'm worried about is if it isnt a mis aligned stator its something more internal which will really toast my sandwich
post #20 of 23 Old 03-27-2013, 5:02 PM
drained oil took it all back apart, improperly torqued flywheel bolt looks to be the issue. schoolboy error. lets see if this sorts it..
post #21 of 23 Old 03-29-2013, 8:48 PM
Reputation Power: 19
Since we resurrected this thread, allow me to interject the fact that you don't need to disconnect the side faring at the bottom, from the other side fairing. Just remove the other bolts and lean that fairing piece over/against something, then you'll have just enough room to pull the drain plug and reach in to get the oil filter. Though... completely disconnecting the piece would give you more room to work, so that's an advantage there.
Just a personal preference one way or the other.
Sportbike_Mike is offline
post #22 of 23 Old 04-29-2013, 11:59 PM
Thanks for the post. Changed my oil for the first time today and I'm sure this saved me a few headaches.
TravisSB is offline
post #23 of 23 Old 12-26-2013, 4:19 PM
Images: 2
how do you get to the bolt on the left side of the cbr logo? do i have to unscrew the tank?
the guy in this video unscrews his tank, im not sure what to do. help please
hondarider773 is offline
Go Back   Honda Motorcycles - FireBlades.org > Articles > Articles: Honda FireBlade
Human Verification
Search tags for this page
.how to change oul on a cbr954rr
2002 cbr 954rr oil change
2002 honda 954 oil drain plug
2002 honda cbr 954 oil drain plug location
cbr 954 oil
honda cbr 954 oil change
how much oil change on my cbr 954rr
how to change oil on cbr954rr
what oil does my 2002 cbr954rr use
what oil for cbr 954
How to change brakes on a 2002 954rr. eatsricejcd General Discussion 16 03-17-2010 7:19 PM
oil change! HELP PLEASE!!! Loaded Honda CBR 600 3 03-07-2009 4:29 AM
How often do you change your oil? CBR_954_RR General Discussion 12 07-20-2008 2:05 PM
oil change alcinshaw Honda Cruisers 1 04-19-2007 10:37 PM
