calling all drag racers!
Old 12-01-2006, 4:28 AM
Bike(s): 1000rr
Rep: TheDon is on a distinguished road (10)
i have a 2006 1000rr and im getting into drag racing. I have straps , lowering link, 6 in extension on the way(do they make 10in extensions?). what set up do i need to do well on a 1/8 mile track. Like i said im pretty new to it, i messed around with it with the bike all stock but wheelies are too common.
how should i set the bike up, from what i read i need to soften the suspension. Also how should i change the gearing? i think im gonna go with a dynojet quick shifter but if there is a better one let me know. i would like some nos too.
TheDon is offline
View TheDon's Profile View TheDon's Gallery Find More Posts by TheDon
Old 12-01-2006, 5:51 AM
maybe because it does not really matter...........
JBODIE's Avatar
Bike(s): 94 CBR 900RR
Rep: JBODIE will become famous soon enoughJBODIE will become famous soon enough (127)
Re: calling all drag racers!
Welcome to the org. and where in Ky are you from?
JBODIE is offline
View JBODIE's Profile View JBODIE's Gallery Find More Posts by JBODIE
Old 12-01-2006, 5:50 PM
Cycle Trendz Racing
SilverBullet's Avatar
Bike(s): S/B 954..Drag Racing Specialist and 2006 Champion
Rep: SilverBullet has a spectacular aura aboutSilverBullet has a spectacular aura about (185)
They don't make bolt on extensions more than 6". You need an MPS air shifter, not a quick shifter! Soften rebound and dampening on the shock, you want it to squat when you leave the line to put force on the rear tire. For gearing, I would go -1 front and up 2-3 in the rear, I'm only 2 up in the rear but will probably go to 3 next season if I don't sell the blade.
ps. Here's the link to my shop and I took the 2006 Points Championship at Northeastdragway this year. :: Northeast Dragway.com ::
Cycle Trendz Racing
www.cycletrendz.com
2006 Northeast Dragway Points Champion
2005 Northeast Dragway Points Runner Up
SilverBullet is offline
View SilverBullet's Profile View SilverBullet's Gallery Visit SilverBullet's homepage! Find More Posts by SilverBullet
Old 12-01-2006, 5:51 PM
Cycle Trendz Racing
Do a search for threads and posts by me and you will find pretty much all the info you could possible want to know.
www.cycletrendz.com
Old 12-01-2006, 6:11 PM
Bike(s): 1000rr
im live in louisville
TheDon is offline
Old 12-01-2006, 6:35 PM
Bike(s): 1000rr
should i soften the spring too or just the rebound and dampening.
TheDon is offline
Old 12-01-2006, 6:53 PM
Bike(s): 1000rr
Cycle Trendz Racing
where can i mount the airshifter bottle? and i see mps also has a dry nos kit, where would i mount that bottle also? i no that you can hook the horn up to the nos, but i thought the airshifter worked off the horn too.
TheDon is offline
Old 12-01-2006, 7:26 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
Rep: seamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud of (1425)
to the site.
GO [insert name of team playing the Cards]!!
Are you running at Ohio Valley?
seamus is offline
View seamus's Profile View seamus's Gallery Find More Posts by seamus
Old 12-01-2006, 7:51 PM
Bike(s): 1000rr
Originally Posted by seamus View Post
to the site.
ive been down there b4 but the bike was all stock and not lowered so u already no how that went. Do you go down there? i have probably seen you around b4.
TheDon is offline
Old 12-01-2006, 7:58 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
I've passed by. I'm not into the drag thing but it's fun to watch sometimes. I live in Vine Grove so I pass by the place all the time.
seamus is offline
Old 12-02-2006, 1:18 PM
johnnycrash's Avatar
Bike(s): 06 busa, 01 CR250R, 72 Husqvarna 450, 87TRX250R
Rep: johnnycrash is a glorious beacon of lightjohnnycrash is a glorious beacon of lightjohnnycrash is a glorious beacon of lightjohnnycrash is a glorious beacon of lightjohnnycrash is a glorious beacon of light (458)
My N20 system is triggered by a throttle position sensor and an RPM window switch (Schnitz racing - much easier IMHO than pushing a button. If you do prefer a button you can use your starter switch for activation as well, freeing up your horn for shifter duty.
Silverbullet is definitely your go-to guy for making drag race bikes. His shop can get you everything you need.
johnnycrash is offline
View johnnycrash's Profile View johnnycrash's Gallery Find More Posts by johnnycrash
Old 12-03-2006, 11:08 AM
Cycle Trendz Racing
The MPS kit comes with a switch that I use to make the starter button work for my NOS. My horn button is used for the airshifter when I am not using autoshift. It all depends on how you want to use the NOS. In my opinion it is better to use a button......if you are bracket racing, run your dial in off motor only...and if you spin or have a bad 60' you can spray to make up the time. On a wide open switch, I am wide open around 5ft out....so it would come straight up in first. I'm extended 9-1/2" and it comes up when I bump spray in first. If you spray every pass, you can't make up the time you lost from spinning or a bad 60'. It's hard to make people understand that.
As far as where to mount the bottles.....thats hard since the 1K doesn't have the trunk space like the 929/954. You can mount one bottle to the swingarm and the other bottle on the side around the rear peg area would be my guess. I have a 1K at the shop we just finished port/polishing the head on, but he is picking it up tomorrow so I won't be able to look over it good to help you any more than that unfortunately.
www.cycletrendz.com
Old 12-03-2006, 11:09 AM
Cycle Trendz Racing
Thanks Johnnycrash!
www.cycletrendz.com
Old 12-03-2006, 11:58 AM
Silverbullet: ever heard of a BTC box (or something like that)?
I saw something about it on another site - apparently it will allow me to control which gears the nitrous sprays in. I definitely don't want to spray in first - and right now with stock wheelbase spraying in second is pretty hairy as well.
Old 12-04-2006, 5:08 PM
  #15
Bike(s): 04 550hp Turbo Hayabusa
Rep: sonicsbomb will become famous soon enoughsonicsbomb will become famous soon enough (100)
Send a message via AIM to sonicsbomb Send a message via Yahoo to sonicsbomb
Jason and his shop will definatley hook you up!! No better place to get your Honda set up. I would trust a guy who races what he sells!!
sonicsbomb is offline
View sonicsbomb's Profile View sonicsbomb's Gallery Find More Posts by sonicsbomb
Old 12-04-2006, 5:14 PM
  #16
abtech's Avatar
Bike(s): 2007 RC51
ain't that the truth
abtech is offline
Old 12-04-2006, 6:32 PM
  #17
A Spaniard in Texas.
onevcs's Avatar
Bike(s): 2005 CBR1000RR, '98 Suzuki DR650SE
Rep: onevcs is a jewel in the roughonevcs is a jewel in the roughonevcs is a jewel in the rough (293)
[quote=seamus;554929] I'm not into the drag thing but it's fun to watch sometimes. quote]
I've always suspected but didn't want to ask...
onevcs is offline
View onevcs's Profile View onevcs's Gallery Find More Posts by onevcs My Map Location
Old 12-04-2006, 7:13 PM
  #18
Das Ende ist hier
seamus's Avatar
Bike(s): One
[quote=onevcs;555857]
You wanted me to watch?
seamus is offline
Old 12-12-2006, 8:55 AM
  #19
Just answering my own question here. After finding out how expensive and rare a BTC box is I found this - a PCIII hub. This will allow me to control the gears I spray in - and I may be able to run my shifter as an autoshifter with this device as well.
Not many drag racers on this site - but it may help someone.
Schnitz Motorsports, Inc
Old 12-13-2006, 3:09 PM
  #20
Cycle Trendz Racing
Yeah, but they aren't widely used. I've personally never installed one either or seen one working, but I knew they were out there. Wish I could help you more than that!!
Thanks Sonic
www.cycletrendz.com
Old 06-29-2007, 11:30 AM
  #21
Bike(s): 2002 honda 954
Rep: allstarcycles is on a distinguished road (10)
where can i buy a set of front end straps?
allstarcycles is offline
View allstarcycles's Profile View allstarcycles's Gallery Find More Posts by allstarcycles
Old 07-03-2007, 7:19 PM
  #22
Bike(s): 05 R1
Rep: jonpiper is on a distinguished road (19)
Straitline prouctions will make a bolt on extension any length you want ...
Contact info :
Chris Nix 256-621-1657 , tell him Piper sent you
Personally I wouldnt go over 10 with bolt on's but I have seen several people in the north alabama area go waaaaaay out . But round here "bigger is better"
jonpiper is offline
View jonpiper's Profile View jonpiper's Gallery Find More Posts by jonpiper
Old 07-03-2007, 9:38 PM
  #23
Bike(s): 2006 CBR1000RR
Rep: HCCAFan is on a distinguished road (15)
Back from the dead!
HCCAFan is offline
View HCCAFan's Profile View HCCAFan's Gallery Visit HCCAFan's homepage! Find More Posts by HCCAFan My Map Location
Old 07-04-2007, 6:19 PM
  #24
Bike(s): 05 R1
Originally Posted by HCCAFan View Post
Back from the dead!
yah ... jut trying to help a brotha out
jonpiper is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:19 AM.
