06 cbr1000rr launch
Old 04-27-2007, 12:22 AM
Bike(s): 06 cbr1000rr
Rep: redline65 is on a distinguished road (10)
06 cbr1000rr launch
Hey guys I am having a bear of a time getting this thing out of the hole. The clutch wants to lock up and not slip. Is there something that can be done?
06 cbr1000rr
redline65 is offline
View redline65's Profile View redline65's Gallery Find More Posts by redline65
Old 04-27-2007, 6:02 AM
Jungleboy's Avatar
Bike(s): 2003 CBR954RR-For sale, 2004 CBR1000RR race bike
Rep: Jungleboy will become famous soon enoughJungleboy will become famous soon enough (136)
Re: 06 cbr1000rr launch
I feel your pain! My normally great starts have completely turned to crap since upgrading to the 1000RR.
Now before anyone tells you its because its hydraulic thats not the case!
It has more to do with the plates running dry and the large diameter of the clutch. It is in a sense designed too well and just wants to bite.
Im trying to figure out a solution at the moment...
Temporarily Im going to pull the plates out and soak them before my next race, but this is a bit impractical could get tedious after a while, I considering blending ~5% friction modified oil (containing moly) with my normal oil, just hope it wont slip under normal conditions...
Im also going to chamfer the oil holes on the inside of the inner basket to help get some more oil through to the plates, failing that I will even consider an auxillary oil pump if I can figure out away to route it to the inside of the clutch as its no use just directing onto the clutch from the outside as centrifugal forces will just throw the oil strait off...
Ill be sure to update this thread if I come up with anything
Jungleboy is offline
View Jungleboy's Profile View Jungleboy's Gallery Visit Jungleboy's homepage! Find More Posts by Jungleboy
Old 04-27-2007, 10:03 AM
SilverBullet's Avatar
Bike(s): S/B 954..Drag Racing Specialist and 2006 Champion
Rep: SilverBullet has a spectacular aura aboutSilverBullet has a spectacular aura about (185)
Well, disregard my pm then....didn't realize it was grabbing too much for you. I'm sure you've tried leaving at a little higher rpm....I tried that and had to back off as the bike went side ways towards the tree...rutt row...luckily it was a bye run in the semi-finals...but I did have a .502 light!
www.cycletrendz.com
2006 Northeast Dragway Points Champion
2005 Northeast Dragway Points Runner Up
SilverBullet is offline
View SilverBullet's Profile View SilverBullet's Gallery Find More Posts by SilverBullet
Old 04-27-2007, 10:04 AM
You can also add a couple pounds of air in the tire so maybe it will give just a quick slip then grab.
www.cycletrendz.com
Old 04-27-2007, 1:50 PM
Yea we are going to tear into it tonight, I have tried winding the hell outa the thing, and when it locks up then hold the hell on,, but if anyone else is having this problem post it up on how ya fixed it or what is going on. This is on the new 06-07 cbr1000rr
Old 04-27-2007, 3:53 PM
Bike(s): 2004 1000RR TURBO
Rep: turbochachi is on a distinguished road (10)
Tell me a little bit about your bike and i will try to help you.
turbochachi is offline
View turbochachi's Profile View turbochachi's Gallery Find More Posts by turbochachi
Old 04-27-2007, 4:35 PM
Carolina Kracker
Quick 26's Avatar
Bike(s): 06 CBR1000rr, 05 CBR1000RR Repsol Edition(stolen)
Rep: Quick 26 has a spectacular aura aboutQuick 26 has a spectacular aura aboutQuick 26 has a spectacular aura about (211)
had a hard time keepin the front wheel down on mine
Quick 26 is offline
View Quick 26's Profile View Quick 26's Gallery Find More Posts by Quick 26 My Map Location
Old 04-27-2007, 6:25 PM
well its an 06 1000rr, the clutch does not want to let your slip it, at all, as soon as it feels itself starting to slip WHAM it engages. We are going to rip it apart tonight to see if we can make some adjustments to how it engages. On thing I noticed is that the hole basket sits up pretty high and doesn't get a whole lot of oil to it.
Old 04-27-2007, 6:26 PM
Quick were you able to slip your clutch out of the hole pretty hard?
Old 04-27-2007, 6:36 PM
Are you drag racing or road racing on the track
The second poster was thinkin about additive but I might lean away from that one because eventually it will be a shootout bike and we midas well fix the problem now.
Old 04-27-2007, 6:37 PM
Its a drag bike
Old 04-27-2007, 6:48 PM
Tell me about the bike and yourself.
how long , lowered ,your weight, 60 ft times, how long drag racing ,ETC.
Old 04-27-2007, 6:55 PM
Been draggin for awhile, had a gsxr before this, the bike has not been lowered into the weeds yet, so everything on it is still stock, need to see what it will run before start modding it up. I am 6'1" 230
Old 04-27-2007, 7:10 PM
  #15
I pm you
call me i want to talk to you BIG GUY lol im only 5 5
Old 04-27-2007, 7:26 PM
  #16
Jungleboy's Avatar
Yeah I was just thinking of trying that as a bandaid fix just because Im so frustrated as it grabs every time off the line and thhe front wheel just snaps up and I have to grab the clutch to stop it looping out
Ideally I would like to leave the line at about 5500-6000 RPM but you just can not slip it and feed it in progressively as its just like a light switch...
Ive spoken to the engine builders from HRC Australia and they havent found a real solution The riders basically leave the line at lower rpm but I want to be able to start like I did on my 954
The only time it has worked ok was just after I had the clutch apart and had the plates soaking in oil, So i think if we can get more oil to the plates some how we can solve the problem....
Old 04-27-2007, 7:43 PM
  #17
Jungle boy how is your bike set up
what are your 60 ft times
Old 04-27-2007, 10:05 PM
  #18
ITS NOT THE BIKE ITS YOU
Old 04-27-2007, 10:51 PM
  #19
Lou i just called we have it tore apart and something does not seem right. Riveted to the back of the basket is a primary gear with springs to help shock load. Well that plate will not move at all and the springs appear to be loose so it should move. It looks like there is some gauling on the basket where the two surfaces meet. It is setup somewhat like a care. I have never seen this setup on a bike. Have any of you taken these things apart this far and what are you experiences?
Old 04-28-2007, 2:56 AM
  #20
Jungleboy's Avatar
Well it must be me and every other Honda superbike racer I know.
The Aussie factory Honda riders are also having the same problem..
Maybe we all need counciling
Old 04-28-2007, 2:41 PM
  #21
No its the bike bro there is something seriously wrong
Old 04-28-2007, 5:03 PM
  #22
you could be right,bring it back to the dealer and let them worry about it.
is the bike still covered by honda. dont tell them you drag race it
Old 04-30-2007, 8:44 AM
  #23
Carolina Kracker
Quick 26's Avatar
i only took it to the track one night. i had a time leaving with mine as well, but i was figuring it was operator error. i was rinning a 7.1 on mine, and my buddies were running 6.80s. they do a bit more draggin than i
Quick 26 is offline
Old 05-14-2007, 4:24 AM
  #24
Bike(s): 98R1 04 CBR1000
Rep: RIPPERTON is on a distinguished road (10)
Problem solved. You have to reduce the friction surface area by 25% because the clutch is simply to big for the amount of torque the cbr is producing, its overpowering the motor. How to reduce the surface area ? there are 8 pairs of plates (16 altogether) what you need is 6 pairs but also maintain the stack height so you have to double up some of the plates. Start by removing all the plates and restacking them in a slightly different order. Well refer to the plates as outers (with castleations on the outer circumference) and inners (with castleations on the inside. Restack the plates in this order: outer,outer inner,inner,outer,inner,outer,inner,outer,inner,ou ter,inner,outer,outer,inner,inner then the pressure plate. Now you have 6 pairs of plates. I have just tested this setup in the street after first trying 4 pairs but got too much slip at high rpm. 6 pairs seem to be a happy medium and operates just like a clutch is supposed to. One thing for race bikes to watch out for is slip. By reducing the friction area your also reducing the grip area so after juggling the plates around you will need to test for slip and increase preload on the springs. If youre still running the narrow outer at the back of the stack you will have to double up a different pair of plates
Cheers and many happy holeshots RIPPERTON SYDNEY AUSTRALIA
PS would like some feedback on this.
Name:	CBR clutch stack.JPG
RIPPERTON is offline
View RIPPERTON's Profile View RIPPERTON's Gallery Find More Posts by RIPPERTON
Old 07-09-2007, 7:30 AM
  #25
Bike(s): 2004 CBR1000RR, 1997 CR500
Rep: BoiseRR is on a distinguished road (10)
Did anyone ever try the restack or any luck with anything else on the '06 1000 clutch? One of my friends traded in his 954 for a new 1000 last year and cannot get the thing to launch. He was the defending track champ on his 954, now he is lost somewhere in the back of the field on the new bike for the last year and a half. I rode his bike after the drags were done on Saturday and it starts to drag a little then just locks up! Rolling start, 5 to 10 mph you can slide the hell out of it (or just do a big nasty burnout!) and it feels fine. From a dead stop.....watch out! All the guys with the last model GSXR's had to add the wave washer/cushion into the clutch pack because theirs were doing the same thing and the newer GSXR's had that already in stock to fix same problem. But the '06 CBR already has the wave washer in it.
Tried converting it to cable, no help but I didn't think it would.
Tried different oil, ho help.
Soaked a new set of plates, no help.
BoiseRR is offline
View BoiseRR's Profile View BoiseRR's Gallery Visit BoiseRR's homepage! Find More Posts by BoiseRR
Old 07-10-2007, 2:53 AM
  #26
Bike(s): 06 1000RR
Rep: RR_Monster is on a distinguished road (10)
I'm having the same problem on my 06, wish someone would come up with a mod to help this, I might try changing the plate order, but i dont want to sacrifice street riding and going through clutches faster. good thing there is next to none aftermarket support for us honda draggers
RR_Monster is offline
View RR_Monster's Profile View RR_Monster's Gallery Find More Posts by RR_Monster
Old 07-11-2007, 11:15 AM
  #27
Bike(s): 2000 CBR929RR
Rep: bryanclapper69 is on a distinguished road (10)
I dont know if it will help, but R1's had the same problem. I know a couple guys that have drilled a hole in the top of the clutch cover and ran an oil line to keep the clutches oiled. Seem to help R1's from burning clutches up.
bryanclapper69 is offline
View bryanclapper69's Profile View bryanclapper69's Gallery Find More Posts by bryanclapper69
Old 07-13-2007, 3:48 PM
  #28
Bike(s): CBR
Rep: franc01 is on a distinguished road (28)
I don't know if this would help or hurt but Cycle Logic has a lockup clutch kit available for the 1000RR. I guess you could add in slip then let the lockup do it's job when the revs come up.
I thought this was just my particular bike being so grabby- I was going to get a braided clutch line to see if this would help with slipping the clutch. I love my 954's clutch and my cousin's '07 ZX-10 has a pretty sweet cable clutch as well.
Take care,
Franc
'06 1000RR
franc01 is offline
View franc01's Profile View franc01's Gallery Find More Posts by franc01
Old 07-13-2007, 3:55 PM
  #29
Get on psychobike.com and ask on that board. That is a dragracing board and I know thier are 3 or4 people on thier with 1000rr., Ken Stotz has a 1000rr that runs 7.31.
Old 07-15-2007, 1:00 PM
  #30
OK, my buddy tried the restack. Worked great for 2 launches.......then started grabbing again! Took the bike home and tore the clutch out. Steels are blues and clutch is cooked!!!!! Threw in the spare sitting on the bench with the stock config and he has a Hinson hub/clutch assembly on order. The say it will absolutely fix the problem plus he'll then have a slipper.
BoiseRR is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 9:03 PM.
