You can also learn from your runs and see at what highest or near there abouts RPM can you lunch (at the discovered point) where the rear is going to start spinning...if you got all the weight that you can afford to put into keeping the front from raising or in well balanced / managed state, then that's it...you can then do practice runs to play with and concentrate on the throttle to control the slippage (for the lack of a better word) back to the traction point and ride it on out...body position the same as lunch position...keep on shifting where you feel the front rising higher than you care for...if starts to.
All this, of course, easier said then done (for sure for me). But if you think you're doing everything down from your experiences and exploring, practiced, suggestions about, etc. Regards to shifts...how about increasing a tooth or two on the rear sprocket and (do runs again
hehehee he
but do an extra shift from the get-go..what would that be..third or forth?? and compare it...anyway...one more gear to go through this way. Good luck.
Nb: i don't know anything about 9.29k RR power band.
Nbb: i claim that i can not do anything in this post nor ride a tricycle
