919rr high rev misfire
Old 05-19-2008, 2:21 PM
Bike(s): outlaw 900rr 73" wb, 100 hp nitrous, 7" slick.
Rep: muppetracer is on a distinguished road (10)
first run up the strip on my drag only 919, the engine fires up instantly and revs freely and sounds strong it launches ok then bad misfire 1.9 second 60' time then 14,4 second 1/4 at 90 mph . static is set to 39 degrees.runs with schnitz pro 2 ignition. v & h pro-pipe, on returning home i found these possible faults. realised i hadnt fitted the air box the bike was set up with a dynojet kit and k&n filter fitted in the air box . also i found a loose wire on one of the coils, would the lack of air box and filter couse this bad a misfire ?
muppetracer is offline
View muppetracer's Profile View muppetracer's Gallery Find More Posts by muppetracer
Old 05-19-2008, 2:24 PM
Bike(s): 2002 Cbr 954RR
Rep: Carolina_954 is on a distinguished road (16)
Re: 919rr high rev misfire
not sure about the 919. if it has fuel injection, it will mess it up. there is a sensor on the back that must be connected on the 954. If it is not connected it can cause a rough running condition. Like I said though, I don't know about that particular bike
Carolina_954 is offline
View Carolina_954's Profile View Carolina_954's Gallery Find More Posts by Carolina_954
Old 05-19-2008, 2:37 PM
I should of said its the last of the carb models.
Old 05-20-2008, 6:00 PM
Bike(s): 94 cbr900rr..945 nitrous motor this winter
Rep: cbr900racer77 is on a distinguished road (38)
I know if the airbox isn't on the carbs properly it will make the RR run rough and break up (if it's jetted properly to start with) so I would assume it would do the same to the 919. I had schnitz promod box on my 9RR, think the box was messed up. It would never retard properly on motor, no matter where I moved the triggers. I sold it on ebay and plan on using v&h powerpak this year. good luck!
cbr900racer77 is online now
View cbr900racer77's Profile View cbr900racer77's Gallery Find More Posts by cbr900racer77
Old 05-20-2008, 6:14 PM
thanks for that . i've put the air box back on,re-checked the static timing,now has 39 degrees advance with 34 degrees retard programed for starting , checked all electrical conections made sure the spark plug leads are firmly snapped on to plugs (not an easy job) just got to wait till june for next test weekend at the strip.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:30 AM.
