silverbullett or others..
06-04-2008, 3:39 PM
| silverbullett or others.. hello, i'm looking for some 929/54rr info. I found a thread where some individual asked about swing arm extensions like this.. 58cycle Parts & Accessories Webstore
i want to know how durable they are, i'm looking for something stronger but cant find anything but these  . I'm a bigger guy 240lbs max and would sometimes like to accommodate a 100lb passenger otherwise i'd be in the dog house!
other than that, i'm having a hard time finding a longer rear brake hose.
i'l be looking for more info but we'l start with this
thanks in advance |
06-06-2008, 12:49 AM
Bike(s): 94 cbr900rr drag only...997 down but not out Age: 43 Posts: 149
Rep:  (10) Rep Power: 1
| Re: silverbullett or others.. I've seen several bikes at the track with them, so I would imagine they are pretty durable. As for the lines, check local hot rod shops, most can make you a braided hose any length you want. I got mine from Speedway, but their choice of lengths is very limited. The hose is pretty inexpensive, it's those dang fittings that rob you! |
06-06-2008, 1:50 AM
| Re: silverbullett or others.. thanks for your response. i seemed to find an outfit that takes your swing arm and welds the custom extensions on at any length you want fixed for 75 dollars more than the bolt on jobbers. i think i'm going to go that route for the state of mind, especially considering i may be riding with a passenger. |
06-06-2008, 6:08 PM
| Re: silverbullett or others.. yeah, if it was me I would definitely want it welded. That's alot cheaper than the 550 I paid to have Myrtle West do my arm. One word of caution...It will handle TOTALLY different with the extra length on the street. Going around curves, it will try to stay upright and will not want to lean. |
06-09-2008, 1:37 PM
#5 | | Cycle Trendz Racing
Bike(s): S/B 954..Drag Racing Specialist and 2006 Champion Age: 31 Posts: 2,368
Rep:   (185) Rep Power: 11
| Re: silverbullett or others.. I used them for a little over a year I think and I had no problems racing or having my girl on the back. I did switch to a 10" over arm and weld on though since I needed to go farther back to keep the wheel down.
I used a scooters brake line and still have it on there with no problems; or you can do the steel braided that was mentioned.
__________________ www.cycletrendz.com
2006 Northeast Dragway Points Champion
2005 Northeast Dragway Points Runner Up
07-30-2008, 4:19 PM
| Re: silverbullett or others.. how long of a chain will i need for a 6" extension? 130 sufficient? |
07-31-2008, 5:55 AM
Bike(s): 08 1000rr, 07cbr125r, busa drag bike Age: 38 Posts: 245
Rep:  (10) Rep Power: 2
| Re: silverbullett or others.. i read they are good up to about 300 hp |
08-22-2008, 2:00 AM
| Re: silverbullett or others.. what are you guys using for a tether setup?
curious as to what you use for a sprocket set up also silverbullettt
08-27-2008, 10:31 AM
Bike(s): 2000 CBR929RR Age: 33 Posts: 185
Rep:  (10) Rep Power: 4
| Re: silverbullett or others.. Your real line should be long enough is you are only going 6 over, just reroute it. If you get extensions stay away from Yanka Shiki. I had a set bend. If you are 240 I would gear it at 15,45 or 46. I am 225 and ran 15 46 and went 9.90 on stk motor with shifter shift at 10,800 |
08-27-2008, 10:53 AM
#10 | | Cycle Trendz Racing
| Re: silverbullett or others.. My gearing is 1 down 2 up. I bought my tether from the track when mine broke; Schnitz has them, or you can get one of the clips and add it to the bungee hook you can get from Wal Mart or probably auto shop.
08-28-2008, 12:44 AM
| Re: silverbullett or others.. i ride on the interstate a lot so i'm leary of goinng -1,+2 just yet.. i just got my -1 front sprocket yesterday in the mail, i'm just waiting for my damn swingarm to get here from thompson customs! i already ordered a brake hose so i may be sol!
thanks for the info guys, would you mind showing me a pic of your handlebar set up? |
