98 900 motor
Old 01-04-2009, 8:52 AM
Bike(s): 1998 CBR900RR dragbike
Rep: sparkie900 is on a distinguished road (10)
98 900 motor
how much stress would a 50 shot put on a stock motor with 9000 miles on it, have'nt sprayed it yet because of the snow, but the first t &t will be end of feb.. just installed new clutch also.. thanks
sparkie900 is offline
View sparkie900's Profile View sparkie900's Gallery Find More Posts by sparkie900
Old 01-05-2009, 7:27 AM
Bike(s): outlaw 900rr 73" wb, 100 hp nitrous, 7" slick.
Rep: muppetracer is on a distinguished road (10)
Re: 98 900 motor
i would say it depends on what sort of controller you use, there are ones about that let you programme when and how much gas you use, ie you can add a small percentage after launch then have it ramp up to 100% further into the run, this would be kinder on the motor.
muppetracer is offline
View muppetracer's Profile View muppetracer's Gallery Find More Posts by muppetracer
Old 01-23-2009, 8:54 PM
oh no! another puerto rican with a 'blade
shakey1378's Avatar
Bike(s): 2001 929, 2009 hd vrscdx
Rep: shakey1378 is a jewel in the roughshakey1378 is a jewel in the roughshakey1378 is a jewel in the rough (267)
Send a message via MSN to shakey1378
Re: 98 900 motor
also depends on what kind of system your running. direct port? wet or a dry system? how much are you planning on spending?
if you are planning on running n2o and racing a stock engine on the regular you will have to rebuild at some point.
i dont know much about running nitro thru a bike but your average car at 1.8 to 2.5 liter stock 4cyl engine is usually running a 50 shot pretty safely. if it was me and i had to have n2o id start with a 25 shot and a good tuner. you can always turn it up once you figure out your limitations or can afford a proper nitrous build
actually if i was a hardcore type id probably leave my stock engine alone and buy another and rebuild for maximum results.
www.myspace.com/charley1378
shakey1378 is offline
View shakey1378's Profile View shakey1378's Gallery Visit shakey1378's homepage! Find More Posts by shakey1378 My Map Location
Old 01-31-2009, 9:24 AM
Bike(s): 94 cbr900rr..945 nitrous motor this winter
Rep: cbr900racer77 is on a distinguished road (38)
Re: 98 900 motor
I've run a 40 shot on stock 1000F many times with no problems. The thing that will get you first is #3 rod bearing.
cbr900racer77 is offline
View cbr900racer77's Profile View cbr900racer77's Gallery Find More Posts by cbr900racer77
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:59 PM.
