ignition retard for nitrous
03-14-2009, 11:45 PM
Bike(s): hayabusa Posts: 37
Rep:  (20) Rep Power: 0
| ignition retard for nitrous hello. I'm looking for someone who has played with ignition timing for better power on the 954 with a nitrous setup. Here is the scenario, I threw in an ignition advancer (+4 throughout), I now have a dry nitrous kit I am trying to utilize. Instead of taking out the advancer, I purchased the Dynojet ignition advance which allows the user to also retard timing by a max of 10 degrees.
Question:
What would be a good benchmark to start with? For example -4 at mid and upper rpm's, or retard the timing more, to say, -4 at mid range to -8 at wide open throttle. Anyone know what might work best to start? |
03-15-2009, 10:54 PM
#2 | | choices we make define who we are
Join Date: 01-08-2009 Location: Haughton, Louisiana currently in Iraq.
Bike(s): 2007 CBR1000RR Age: 35 Posts: 1,576
| Re: ignition retard for nitrous go with the -4 and -8, that will be real close....
__________________ DO YOUR DUTY IN ALL THINGS, YOU CANNOT DO MORE, YOU SHOULD NEVER WISH TO DO LESS! GENERAL ROBERT E. LEE |
04-14-2009, 8:32 AM
Bike(s): 2003 CBR954 devil high mount and PC3 usb Age: 24 Posts: 100
Rep:  (11) Rep Power: 5
| Re: ignition retard for nitrous what size shot? |
04-14-2009, 10:04 AM
| Re: ignition retard for nitrous it's at a 30 dry shot right now, I want to make sure everything works properly, if everything works fine I will go to a 40, which is the max I want to use( for now) . It is controlled by a wot, window switch, and a progressive controller. |
04-14-2009, 6:11 PM
| Re: ignition retard for nitrous think on good air fuels a 954 engine could take a 50 shot and hold for a while?
what A/Fs will u be looking for under spray? 11-12? |
04-14-2009, 9:56 PM
| Re: ignition retard for nitrous I was told to start low and work up. This way I know I won't run into a catastrophic lean condition. Silver bullet stated he went up to a 60 shot on a modded 954 and the spark plugs melted. I think with a good dyno tune, to make sure your air and fuel ratio is good, a 50 shot would be fine. I will be going to my local dyno to make sure air fuel is correct at a 30 shot, then put in my 40 shot and get a custom map for it. |
11-09-2009, 12:30 AM
Bike(s): 2007 cbr1000rr Posts: 22
| Re: ignition retard for nitrous Quote:
Originally Posted by artimusgilmore it's at a 30 dry shot right now, I want to make sure everything works properly, if everything works fine I will go to a 40, which is the max I want to use( for now) . It is controlled by a wot, window switch, and a progressive controller. | im thinking about nitrous on my bike and was just wondering how much was your setup? |
