03-22-2004, 4:09 PM
| Dzus fasteners.... Can they be mounted to stock plastics?
If I have 2 sets of plastics, can one have the stock hardware and the other have Dzus? |
03-22-2004, 4:20 PM
#2 | | Team Visa Racing
Bike(s): 04 GL1800A,00 929RR,87 CR500R,81 CB900F,71 CB836K1 Age: 45 Posts: 3,858
| Re: Dzus fasteners.... Of course you can. Does someone make a kit of all the right parts? Probably not, but that shouldn't stop you. BTW there are many different brands of fasteners. You don't have to be tied down to D'zus only.
Ride Red
03-22-2004, 5:06 PM
Bike(s): '01 CBR 929 black & red, K7 GSX-R600 Age: 48 Posts: 6,468
| Re: Dzus fasteners.... To use them, though, don't you have to replace the threads with whatever the Dzus fasteners hook into? If the threads have to be replaced, then it would make it more difficult to use the stock fasteners. Dunno, I've never used them, but I thought I remembered something about them attaching something other than the stock threads. |
03-22-2004, 5:19 PM
Bike(s): KTM 950 Adv, FZR400R, SP1 Age: 43 Posts: 1,538
Rep:  (10) Rep Power: 7
| Re: Dzus fasteners.... Dzus.. only way to go.
Yeah, they use a clip on the female side that the fastener *locks* into. See attached photo. I hope never have to won anothe bike without them... |
03-22-2004, 5:20 PM
#5 | | Team Visa Racing
| Re: Dzus fasteners.... I'm assuming the bolts going into the frame would stay. All the other bolts use a rubber encased nut assembly that can be tossed. I think there are 12 that go from the upper to the mid, and from the mid to the lower. Both sides included.Then there are a few on the bottom of the lowers and in the front. And all of the plastic connectors can be replaced.
Ride Red
03-22-2004, 5:37 PM
| Re: Dzus fasteners.... Yeah, that's my point. The female part has to be replaced with the Dzus part, meaning the rubber encased nuts have to be removed. There's a name for them...wellbolts?..wellnuts?...anyway, it sounds like ND4SPD can't easily switch back and forth between Dzus fasteners and stock fasteners, unless I'm missing something. |
03-22-2004, 5:48 PM
#7 | | Team Visa Racing
| Re: Dzus fasteners.... Quote: |
Originally Posted by HondaGalToo Yeah, that's my point. The female part has to be replaced with the Dzus part, meaning the rubber encased nuts have to be removed. There's a name for them...wellbolts?..wellnuts?...anyway, it sounds like ND4SPD can't easily switch back and forth between Dzus fasteners and stock fasteners, unless I'm missing something. | Yes he can if he has two sets of plastics. All of the so called "wellnuts" are attached to the body panals. When changing the plastics, the wellnuts go with them. Again, bolts going into the frame are always used no matter which set he choses.
Ride Red
03-22-2004, 5:51 PM
Originally Posted by nedro Yes he can if he has two sets of plastics. All of the so called "wellnuts" are attached to the body panals. When changing the plastics, the wellnuts go with them. Again, bolts going into the frame are always used no matter which set he choses. | It's the answer I was looking for. Thanks  |
03-22-2004, 6:02 PM
Originally Posted by nedro Yes he can if he has two sets of plastics. All of the so called "wellnuts" are attached to the body panals. When changing the plastics, the wellnuts go with them. Again, bolts going into the frame are always used no matter which set he choses. | Oh yeah! I knew that! They are attached to the body panels. Man, it's been a long winter and I haven't had the plastics off. Duh.  |
03-24-2004, 10:34 PM
Bike(s): 04 RC51-wrecked, 95 600F3-sold, 85 700VT, Age: 30 Posts: 737
Originally Posted by ND4SPD Can they be mounted to stock plastics?
If I have 2 sets of plastics, can one have the stock hardware and the other have Dzus? | I'm converting my stock plastic to DZUS along w/the airtech fairings. Should be a good mod since the stock plastic is a PIA to take off! |
