Motorcycle wisdom
Old 04-06-2004, 5:53 PM
ND4SPD's Avatar
Bike(s): '84 Magna V30
Motorcycle wisdom
1. Every ride is optional. Every parking job is mandatory.
2. If you push the bars left, the bike goes left. If you push the bars right, the bike goes right. That is, unless you continue pushing the bars all the way, then the bike will go down.
3. Riding isn't dangerous. Crashing is dangerous.
4. It's always better to be on the sidelines wishing you were on the track than on the track wishing you were on the sidelines.
5. The only time you have too much fuel is when you're on fire.
6. The rear wheel is just a big fan on back of the bike used to keep the rider cool and his/her butt relaxed. If going into a corner too fast, slamming on the rear brake causes the "fan" to abruptly stop. When this happens you can actually see the rider start sweating and his/her butt become tense.
7. When in doubt, slow down. No one has ever hit something too slow.
8. A 'good' ride is one from which you can walk away. A 'great' ride is one after which you can use the bike again.
9. Learn from the mistakes of others. You won't live long enough to make all of them yourself.
10. You know you've left the sidestand down when all left turn are Bat-turns. You know you've left the centerstand down when your in 1st gear at 4000 rpm going nowhere.
11. Never let a motorcycle take you somewhere your brain didn't get to three seconds earlier.
12. Always try to keep the number of times you put your sidestand down equal to the number of times you put the sidestand up.
13. There are two simple rules for riding smoothly and fast in snow and on ice. Unfortunately no one knows what they are.
14. You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
15. If all you can see in your mirrors is sparks and all you can hear is screaming from your passenger, things may not be as they should be.
16. In the ongoing battle between objects made of metal, rubber and fiberglass going 100+ miles per hour and the ground going zero miles per hour, the ground has yet to lose. Same holds for cars, large trucks, and animals taller than you. Draws don't count.
17. Good judgment comes from experience. Unfortunately, the experience usually comes from bad judgment.
18. Keep looking around. There's always something you've missed.
19. Remember, gravity and centrifical force are not just a good ideas. They're laws and are not subject to appeal.
20. The two most useless things to a rider are the braking distance behind you and nine-tenth of a second ago.
ND4SPD is offline
Old 04-06-2004, 6:08 PM
NinerPilot's Avatar
Bike(s): 01 929
Re: Motorcycle wisdom
Ive seen most of those in regards to flying...
The propeller is acctually a big fan to keep the pilot cool... When the prop stops turning you can see the pilot start to sweat.
Chris
NinerPilot is offline
Old 04-06-2004, 6:40 PM
tigerblade's Avatar
Bike(s): SV650S
Rep: tigerblade is a splendid one to beholdtigerblade is a splendid one to beholdtigerblade is a splendid one to beholdtigerblade is a splendid one to beholdtigerblade is a splendid one to beholdtigerblade is a splendid one to beholdtigerblade is a splendid one to behold (894)
"Bat-turns" -
Is a paradigm worth 20 cents?
tigerblade is offline
View tigerblade's Profile View tigerblade's Gallery Find More Posts by tigerblade
Old 04-07-2004, 1:15 AM
Bike(s): '05 R1 Shift Red
Rep: Joel is on a distinguished road (15)
Those are great. Thanks.
Joel is offline
View Joel's Profile View Joel's Gallery Find More Posts by Joel
Old 04-07-2004, 2:36 AM
Bike(s): 954RR, S2000 (four wheeled sportbike)
Rep: CBRS2K is on a distinguished road (10)
Here's another. Money is not the root of all evil. Not having money is the root of all evil.
CBRS2K is offline
View CBRS2K's Profile View CBRS2K's Gallery Find More Posts by CBRS2K
Old 04-07-2004, 8:28 AM
Bike(s): 02 954, 96 CR250R, 99 FLSTC, 93 XL1200, 82 CB900C
Rep: sl954 is on a distinguished road (10)
Chris
That makes a little more sense
sl954 is offline
View sl954's Profile View sl954's Gallery Find More Posts by sl954
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:22 AM.
