1994 CBR900rr - Honda Motorcycles - FireBlades.org
 27Likes
post #1 of 32 Old 02-03-2017, 2:11 AM Thread Starter
Quoted: 7 Post(s)
Send a message via MSN to drope323
1994 CBR900rr
Please help,
I have a cbr900rr that is not going over 108mph at all. not jetted everything stock. I ride it on the freeway mostly. I use 91oct gas and service it more often than usual. just replaced the spark plugs,fuel pump, stator, regulator, chain, oil, fuel and air filters, clutch plates and went from stock lights to LED's. The bike runs smooth and it runs perfect on the street at lower speeds, I also checked the ventilation on the gas tank and is good. bypassed the clutch switch and the kickstand switch. I even checked the air level on the tires and it is to specs. (some funny guy suggested that). Please help...
15966287_1796651803935200_3337750555386365680_n.jpg‎   15109547_1769804243286623_300435727443378473_n.jpg‎
drope323 is offline
post #2 of 32 Old 02-03-2017, 3:10 AM
Images: 7
Quoted: 63 Post(s)
Reputation Power: 9
Have you done a compression check?
drope323 likes this.
Gunk is offline
post #3 of 32 Old 02-03-2017, 3:29 AM Thread Starter
Quoted: 7 Post(s)
Re: 1994 CBR900rr
Nope, It was doing fine, this happened out of the blue. The top speed I could reach sometimes was 145mph.
drope323 is offline
post #4 of 32 Old 02-03-2017, 7:49 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 136 Post(s)
Reputation Power: 39
Re: 1994 CBR900rr
that's a rather meaty rear tire for the I-5 in San Diego!
Without knowing much more than what you've posted, I'd steer my troubleshooting toward the Fuel Pressure Regulator and/or cleaning the carbeurator(s). You stated you've changed the plugs... which ones are you running, and did you change the wires? Additionally, you could have a vacuum leak somewhere. Be sure to check all smaller rubber hoses, since in Socal they're prone to be weather-checked. Even the slightest leak can inhibit performance at any/all ranges.
Good luck, and keep us posted
fj1200rj and drope323 like this.
unslow1 is offline
post #5 of 32 Old 02-03-2017, 7:17 PM
President Team Full Chat
Images: 4
Quoted: 105 Post(s)
Reputation Power: 73
Re: 1994 CBR900rr
Agreed here, get ride of whatever that is on your rear rim!! It looks like, well, I can't even describe it! But I would guess 1 hot corner and you're gonna eat the pavement.
Did you forget you have a 6th gear?
It seems you've changed a heck of a lot of parts recently. Was all that in response to the new low top speed issue?
How did you measure your speed?
Being a street fighter, how accurate is your speedo?
Will it run to redline in lower gears?
Lots of questions to answer.
fj1200rj, Gunk and drope323 like this.
IanDoohan is offline
post #6 of 32 Old 02-04-2017, 12:08 AM
RRDemon's Avatar
Quoted: 52 Post(s)
Reputation Power: 61
Re: 1994 CBR900rr
Forget getting over 108mph... your bloody fairings have run off!!!!! I would be searching for the chap that nicked your fairings first =)
Seriously though, I would guess fuel filter, pump, or a carb issue.. ^^ Doohan the "carb guru" has arrived to help you out just in time too =)
RRDemon is offline
post #7 of 32 Old 02-04-2017, 9:13 AM
Quoted: 4 Post(s)
Re: 1994 CBR900rr
that's a key question.
fj1200rj likes this.
oldbastard is offline
post #8 of 32 Old 02-05-2017, 1:38 AM Thread Starter
Quoted: 7 Post(s)
Re: 1994 CBR900rr
I've checked al the hoses and they are all okay, I.m running k&n's and also new wires. Now, I'm failing to identify the fuel pressure regulator on my fireblade, would that be the pump that is positioned right bellow the main fuel valve?. When I have the bike running and put the valve on the off position it takes a few seconds and starts making a clicking noise, I'm asuming it is working well.
drope323 is offline
post #9 of 32 Old 02-05-2017, 1:46 AM Thread Starter
Quoted: 7 Post(s)
Re: 1994 CBR900rr
New filter and new pump, the only thing I haven't done is the compression test and the carb cleaning. I only dumped a can of seafoam on the tank with a lil bit of gas and left it siting for a couple of hours, then started the engine and rode it few blocks and back. It ran smoother after I did that. but still not getting over 108/110 mph like it used to.
drope323 is offline
post #10 of 32 Old 02-05-2017, 2:07 AM Thread Starter
Quoted: 7 Post(s)
Re: 1994 CBR900rr
1.- LOL
2.- I've replaced parts because they had to be replaced as they where old and worn, the only thing I did in response to this matter is a new pump and a can of seafoam on the tank. after this done it ran smoother but not faster.
3.- I removed the cluster and started using an application on my phone that works with GPS.
4.- Thinking that the app on my phone was giving me a wrong speed reading I attached the speedo cable and the cluster back to compare my phone against it and it changes by approximately 2 mph, the speedo shows 108 mph and the GPS 110/112mph (not that accurate but close enough).
5.- It does get to the redline on lower speeds.
drope323 is offline
post #11 of 32 Old 02-05-2017, 6:22 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 136 Post(s)
Re: 1994 CBR900rr
Running K&N what's?
Pardon me. Your carbureted Fireblade does not have an FPR. Excuse me for misleading you. That advice would be better suited for a machine with FI. I apologize.
unslow1 is offline
post #12 of 32 Old 02-05-2017, 6:36 AM
Images: 7
Quoted: 63 Post(s)
Reputation Power: 9
Re: 1994 CBR900rr
Just a thought, have you changed chain and sprockets?
1994 Urban Tiger Project
"Endless motorbike talk can and does bore me" - Barry Sheene
Gunk is offline
post #13 of 32 Old 02-05-2017, 4:08 PM Thread Starter
Quoted: 7 Post(s)
Re: 1994 CBR900rr
Running K&N what's?
K&N Spark Plugs
LOL
drope323 is offline
post #14 of 32 Old 02-05-2017, 4:10 PM Thread Starter
Quoted: 7 Post(s)
Re: 1994 CBR900rr
Yes, Same count and dimensions .
drope323 is offline
post #15 of 32 Old 02-05-2017, 5:17 PM
Images: 4
Quoted: 105 Post(s)
Re: 1994 CBR900rr
Fuel related, had to be. If it pulls hard to redline in 3rd but not 5th (for example), it's a fueling issue. My bet is crap in the carbs. Happens all the time, even to the cleanest carbs.
Get your bike up to temp, take a spray bottle of water and spray a stream of water on each header pipe. The water should "steam off" immediately. You'll know if you have a dead cylinder if the water trickles, or doesn't burn off instantly. That may help you narrow it down.
It might not show up at slower speeds, but once the engine is looking to keep you moving and wants more fuel it may be starving for it.
What is the symptom like? Is it like you're hitting redline at 108 mph? Or is it more the throttle is to the stop and it's just not revving out?
Tags
1994 , 900rr , cbr , cbr900rr , not reaching top speed
Human Verification
1994 CBR900RR Mikeo For Sale 2 01-09-2017 11:22 PM
1994 cbr900rr help japbikejon Honda FireBlade 4 09-17-2014 7:53 AM
1994 cbr900rr Taargus_Taargus Review My Ride 0 02-25-2013 7:51 PM
1994 CBR900RR Rocketdog Honda FireBlade 4 07-29-2010 2:04 PM
1994 CBR900RR scutfargas Review My Ride 10 02-02-2009 12:05 AM
