954 Info needed please. - Honda Motorcycles - FireBlades.org
 10Likes
  • 1 Post By unslow1
  • 3 Post By fj1200rj
  • 2 Post By IanDoohan
  • 2 Post By unslow1
post #1 of 11 Old 04-19-2017, 5:05 AM Thread Starter
Quoted: 3 Post(s)
Hia All, Ive just joined as im looking to buy a 954 and have a couple of questions.
First the obvious one, are there any issues i should be looking for.
What models have the 16 inch wheel.
some replace it with a 17 inch for a better tyre choice but is there any other advantage in doing that
Is Tyre choice a big issue.
Thanks
Dartagnan is offline
post #2 of 11 Old 04-19-2017, 5:13 AM
spagiratwink's Avatar
Quoted: 103 Post(s)
Reputation Power: 7
Re: 954 Info needed please.
Hi again take a look at this thread for starters, and there will be a lot of guy's coming along to give you good counsel
Are 929 and 954's a bag of trouble
spagiratwink is offline
post #3 of 11 Old 04-19-2017, 5:46 AM Thread Starter
Quoted: 3 Post(s)
Hi thanks for that. i am looking at very low mileage bikes as i dont swap and change and do about 7000 a year. so corroded carbs and blocked injectors etc are something on my mind
post #4 of 11 Old 04-19-2017, 5:52 AM
Quoted: 103 Post(s)
Reputation Power: 7
Are you in USA or UK, as you probably know slight differences with set-up
post #5 of 11 Old 04-19-2017, 6:56 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 218 Post(s)
Reputation Power: 41
Thanks
Other than the usual used bike issues (chain, sprockets, battery, tires, brakepads, valve adjustments, potentially low compression due to high mileage and/or lack of proper maintenance), the 954s are needing stators, voltage regulators/rectifiers, relays, and the HTEV servo motors have a tendency to malfunction/fail. These are not specifically design flaws, just that 954s are now 15 years old, and may require the aforementioned bits to be replaced.
Oh... and they all come with 17" rims.
IanDoohan likes this.
unslow1 is offline
post #6 of 11 Old 04-19-2017, 7:34 AM
Images: 1
Quoted: 95 Post(s)
Reputation Power: 119
Like the Musketeer? As Unslow said, they came with 17's so you'll find tire choice is unlimited. I will add to the fore mentioned list that lots of members experience fuel pressure regulator failures also. I have been very lucky, mine has 37k on it and I have not had any charging system issues of a bad FP reg, knock on wood, I know my turn is coming. It has always been garage kept, well cared for, and lived in a very dry climate. All things that have probably helped, except for the summer riding heat which can't be helping the stator or reg/rec. I'll sell you mine for $9000 (Sorry, little joke from another thread). Let us know how the search goes.
fj1200rj is offline
post #7 of 11 Old 04-19-2017, 2:09 PM
President Team Full Chat
Images: 4
Quoted: 241 Post(s)
Reputation Power: 74
Thanks
Make sure you do your research (and coming here was a great idea). You've already gotten great advice.
Just to be clear. The from the 929 and up (including 954, 1000RR), there were no carbs. Liter CBR's were/are fuel injected.
Along the same lines, all 17" wheels from 929 and after.
Make sure you're after a true 954, and not a carbed 99 or older blade that been made a 945, by adding larger pistons. See how that small number change can be a huge factor? 945's were a common mod back in the day, and got a bit confusing when the 954 came along. Anyhoo good luck, and let us know what you get.
spagiratwink and Dartagnan like this.
IanDoohan is offline
post #8 of 11 Old 04-19-2017, 4:38 PM Thread Starter
Quoted: 3 Post(s)
Thanks all for the info, Im in the UK
quote "Make sure you're after a true 954, and not a carbed 99 or older blade that been made a 945, by adding larger pistons. See how that small number change can be a huge factor? 945's were a common mod back in the day, and got a bit confusing when the 954 came along. "
will this show up in the V5 registration document.
post #9 of 11 Old 04-19-2017, 4:39 PM Thread Starter
Quoted: 3 Post(s)
One more thing for now anyway.
Has anyone fitted bar raisers to one and if so can it be done without having to butcher the fairing or stretch the wiring?
post #10 of 11 Old 04-19-2017, 5:13 PM
Images: 4
Quoted: 241 Post(s)
Your registrations are different across the pond. The VIN will let us know exactly what you have. I'm certain you're after a legit 954, I added my comment because you mentioned carbs and 16" wheels. Those ended production in 1999 on the RRX. A 954 (to confuse us all even more), is still considered a 900RR according to Honda. So if you have fuel injection, upside down forks, a 17"" front wheel, and a "pivotless frame", you have a 954.
Fitting had risers on the 954 or 929, from what I've heard, does foul the fairing. Look online for manufactures claims on those.
And finally, post some pictures when you receive said Blade
post #11 of 11 Old 04-20-2017, 7:10 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 218 Post(s)
Concerning "risers" on the 954, it wil be difficult finding clipons that're taller than the OEM ones. Aftermarket risers are measured from 0", not the difference from factory. OEM clipons are already at 2" to 2.25" over 0.
unslow1 is offline
Human Verification
(%$ Throttle Sync Info needed THCue Honda FireBlade 3 05-05-2016 10:55 AM
Cam Degreeing Info needed Andrei Honda CBR 600 11 03-29-2012 8:26 AM
Hello and info needed cbr400james Honda CBR400RR 3 10-10-2010 7:37 AM
Tire Info Needed ERION929 Aftermarket Perfomance Parts Reviews 3 09-11-2010 11:27 PM
954 rod info needed. Sneakin Deacon Honda FireBlade 5 07-22-2010 12:42 AM
