chain touching rear tire - Honda Motorcycles - FireBlades.org
 4Likes
  • 2 Post By lanbrown
  • 1 Post By Jim16
  • 1 Post By Jim16
post #1 of 13 Old 06-18-2017, 5:59 PM Thread Starter
Quoted: 3 Post(s)
hey all
I just noticed something and it worries me: the chain runs very close to the rear tire on my bike, and when it moves around from the bumps in the road, it sometimes touches the tire ( previous owner put wider 200mm Avon tires, they are about half used now) and leaves grease on the external edge, for about one inch, just outside of the zone I use when leaning the most.
I have cleaned the tire as well as I could but I am now wondering what to do:
-shall I adjust the wheel parrallelism to bring the tire further from the chain, by pulling the right side of the axis further towards the end of the swing arm? is it going to create vibrations?
-should I just change that tire? is it to be considered rotten? not sure if I can trust it now :-/
-is 200mm too wide for a 919?
thank you for your input
Jim16 is offline
post #2 of 13 Old 06-18-2017, 6:10 PM
Quoted: 174 Post(s)
Reputation Power: 23
Re: chain touching rear tire
200 is a wide tire and was done for looks, not handling. Is the rim stock or a wider rim put on? Also, you do not want to have the tire anything but straight. Have you been behind a car that you can visually see that it is not tracking straight and that the rear is either to the left or to the right of the front of the vehicle.
Here is an example:
A Motorcycle is a single track vehicle though but you can expect higher tire wear and in corners it won't be as well sure footed.
You should fix it right.
lanbrown is online now
post #3 of 13 Old 06-18-2017, 6:20 PM Thread Starter
Quoted: 3 Post(s)
thank you !
the rim is stock.
Jim16 is offline
post #4 of 13 Old 06-18-2017, 6:29 PM
Quoted: 174 Post(s)
Way too wide for that stock rim. It also ruins the handling and as you have found, it doesn't fit right as it is close to the chain. The PO wanted it for the poser points but also loved chicken strips.
unslow1 and IanDoohan like this.
post #5 of 13 Old 06-18-2017, 7:10 PM Thread Starter
Quoted: 3 Post(s)
ahah, well, strangely the previous owner rides way serious, I believe he actually mounted that wide tire just to sell it...And the fun part is that I bought it and I'm anti-show-off, so I methodically removed all the douchy ameloriation, and there were just two: a black windshield and fancy handle grips.But I ADMIT I liked the wider tire at the time ah ah
bad idea.This bike is going to get a new tire, I don't trust this one anymore anyway.
unslow1 likes this.
Jim16 is offline
post #6 of 13 Old 06-18-2017, 7:22 PM
Quoted: 174 Post(s)
Yep, many like wide tires; cars, motorcycles or even trucks. At times it is performance related but many times it is just aesthetics. Sure I have wide tires on my vehicle and they were also part of package. They are wider than the non performance package but the vehicle is pushing 550HP. You can get the same package on the smaller motor but also has about 250HP less; in that case the wider tires are really pointless.
In your case, the seller probably needed to put a new tire on anyway and decided wider will help sell it and the new owner can deal with it.
post #7 of 13 Old 06-18-2017, 9:41 PM
President Team Full Chat
Images: 4
Quoted: 241 Post(s)
Reputation Power: 74
180/55 for the OEM rear tire size on the 5.5" rear rim. That 200 on the OEM rim must look ridiculous.
Mind posting a picture for curiosity's sake?
IanDoohan is offline
post #8 of 13 Old 06-19-2017, 8:58 AM Thread Starter
Quoted: 3 Post(s)
of course
by the way if anyone happens to own a spare oem rear fender on which I could mount stock turn signals...
IanDoohan likes this.
Jim16 is offline
post #9 of 13 Old 06-19-2017, 11:24 AM
Heeza Y Zasch
unslow1's Avatar
Quoted: 218 Post(s)
Reputation Power: 41
she's got a SSATAF
good onya for puttin' it back to proper
unslow1 is offline
post #10 of 13 Old 06-19-2017, 1:26 PM
Images: 4
Quoted: 241 Post(s)
That's a great looking 900! Do you have plans to relocate your muffler/mid pipe? If you go back to the OEM under-tail tray your right turn signal wont fit with the muffler there.
Also, any way to post a pick of how close the chain actually is to the tire? Reason is that I have a 6" rim on my 99, with a 190/55 on the rear and a 520 size chain. It fits nicely. You could possibly get away with the 200 series if you went to a 520 size chain and sprocket set up.
post #11 of 13 Old 06-19-2017, 1:50 PM
Gunk's Avatar
Images: 8
Quoted: 175 Post(s)
Reputation Power: 10
That is a great looking bike, that red colour scheme I'm sure was for North America only, we ended up with some pretty dubious paint schemes over here. They matched the owners shell suits!
Gunk is offline
post #12 of 13 Old 06-19-2017, 2:33 PM Thread Starter
Quoted: 3 Post(s)
yep, I know.I haven't decided yet.I have all the stock exhaust's parts but it's damaged and doesn't look as good as this splendid Devil that also has an amazing sound.
So I might just put one stock blinker on the left, and leave the teardrop on the right lol
yes, but why bother? I don't really want a 200 anyway.
Jim16 is offline
post #13 of 13 Old 06-19-2017, 2:50 PM
Quoted: 174 Post(s)
Then the question is 180 or 190. Some motorcycles do better with a 190 and some do better with the 180. I don't know what is the case with yours though.
Human Verification
Street tire options: Brand and 190 or 200 rear tire? curryd Aftermarket Perfomance Parts Reviews 28 06-28-2011 12:04 AM
CBR929 Rear C/F hugger, rear wave rotor,gilles chain adj. snipes285 For Sale 29 07-22-2008 2:46 PM
Chain bike through rear tire or sub-frame? Ol' Gravy Leg General Discussion 2 04-14-2008 1:20 AM
Plugs in the rear front or rear tire. #414 General Discussion 11 08-11-2007 11:48 AM
BT020 rear tire with high perf front tire JWHT Honda FireBlade 4 09-05-2004 6:37 AM
