Carbon build-up/loss of compression
Old 04-23-2004, 11:59 PM
Pete's Avatar
Bike(s): '06 CBR1000RR, '06 CRF450X, '06 CRF100
Rep: Pete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to beholdPete is a splendid one to behold (815)
I saw where BillAce is selling a 954 engine with 4,000 miles on it, and he describes carbon build-up on the valves and the resultant loss of compression. So as not to hijack his thread, I thought I'd ask my question here. Is it normal to have that much carbon build-up after only 4,000 miles?
Pete is offline
View Pete's Profile View Pete's Gallery Find More Posts by Pete
Old 04-24-2004, 3:37 AM
Bike(s): '05 R1 Shift Red
Rep: Joel is on a distinguished road (15)
Re: Carbon build-up/loss of compression
I'm going to say it's not entirely abnormal. If the valves have carbon on them, and then the motor does not run for a period of time, the carbon will harden up on the valves that are open. Once the motor is started up, the valves slam hard enough on the head to knock the carbon off the valves. A compression test or leak down test will not get the motor spinning fast enough to get the valves to seat properly.
Joel is offline
View Joel's Profile View Joel's Gallery Find More Posts by Joel
Old 04-24-2004, 5:49 AM
Bike(s): 2003 954 (fireblade) 149.3 Hp
Rep: ratter is on a distinguished road (28)
I wouldn't expect carbon build up at the low mileage unless the motor had not been run in properly and was burning a little oil
ratter is offline
View ratter's Profile View ratter's Gallery Find More Posts by ratter
Old 04-24-2004, 11:09 AM
Bike(s): 2000 Vmax looking to get 945RR or 1000RR
Rep: Zang is on a distinguished road (10)
What "fuel" was run? With the right (or rather wrong) type and depending what those 4000 were ridden like (1/4 at a time, all road, stop and go, slow, etc) anything is possible.
Zang is offline
View Zang's Profile View Zang's Gallery Find More Posts by Zang
Old 04-24-2004, 11:15 AM
Bike(s): 954, ZX6R, F2
Rep: BillAce is on a distinguished road (10)
The problem was a faulty mass airflow sensor causing a very rich condition. The dealer blamed the exhaust, EMS map and I didn't get the answer until I took it to a private mechanic. The dealer wanted me to sign off on $900 of labor to pull the head and investigate in case. If I can only get my new motor running I'll be all set. I haven't seen my 954 in almost 6 months.
BillAce is offline
View BillAce's Profile View BillAce's Gallery Find More Posts by BillAce
Old 04-24-2004, 11:17 AM
That could definately cause it...but I would think you would see an awful lot of smoke if it was that rich!
Zang is offline
Old 04-24-2004, 10:56 PM
CBRBob's Avatar
Since when do 929/954s have mass air sensors????????????????????????
CBRBob is offline
Old 04-24-2004, 11:29 PM
Heck I don't know...I don't have one...
Zang is offline
Old 04-25-2004, 2:05 AM
the whole story sounds suss
ratter is offline
Old 04-26-2004, 9:03 PM
Bike(s): 2004 Black ZX-10R, 2005 Blk/Grn Ninja 250R
Rep: CanyonCarver is on a distinguished road (18)
I'm guessing he means the MAP (Manifold Air Pressure) sensor. If it was faulty, it could produce the symptoms described.
CanyonCarver is offline
View CanyonCarver's Profile View CanyonCarver's Gallery Find More Posts by CanyonCarver
Old 04-27-2004, 12:04 PM
Bike(s): KTM 950 Adv, FZR400R, SP1
Rep: Holeshot is on a distinguished road (10)
Send a message via Yahoo to Holeshot
That's exactly what went though my mind.. I know what a MASS sensor looks like and I sure did not see one (or space for one) on the CBR!
Holeshot is offline
View Holeshot's Profile View Holeshot's Gallery Visit Holeshot's homepage! Find More Posts by Holeshot
Old 04-27-2004, 12:48 PM
I checked with the mechanic and that's it, my bad, but that's why I'm paying him.
BillAce is offline
Old 04-27-2004, 1:05 PM
luvtolean's Avatar
Bike(s): Puch
If the mechanic told you that the motor had excessive carbon build-up causing low compression at 4k, and that it was otherwise OK...it's time to find a new guy.
luvtolean is offline
Old 04-27-2004, 1:38 PM
Here's what I know. I was having trouble starting and fouling the plugs. I killed the battery trying to start it a few times. The dealer told me the valves were carboned up and they would pull the head if I signed off on a $900 labor bill, saying I would pay if it wasn't a defect. I decided to use a motorcycle only shop instead. They perfromed a leak down test and determined the rings were fine, the valves were unable to close completely causing a loss of compression. They measured 80-100 PSI. Does this sound right? They diagnosed and replaced the MAP sensor along the way as well.
BillAce is offline
Old 04-27-2004, 1:43 PM
  #15
luvtolean's Avatar
Bike(s): Puch
Yikes, 80-100 PSI sounds pretty low. Were all cylinders within that?
BTW for those that don't know, BillAce is a longtime member, and I'm quite sure there's nothing "fishy" about this...other than maybe a mechanic is lost.
There is no way cabon build-up SHOULD be responsible for this, unless you have leaky stem seals or something. Is it smoking?
Old 04-27-2004, 2:29 PM
  #16
It did have black smoke @ idle before being torn apart. It ran when I brought it in though. I'll see if I can get pictures of the valves, the pistons looked good, @ least from the top. It actually was running strong, the morning I had trouble starting, I thought the battery was low because it sat for a week. I charged it, went out and at one point did a rol on with a Gix 750, RC51 and 929 and walked them. When it didn't start next time, I figured the dealer should take a look, I rode it there and got the bad news. I just want it back, it's been a while.
BillAce is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:52 AM.
