pc111 directions very not helpful..usb model help
05-01-2004, 9:47 AM
Bike(s): 03 54 Age: 34 Posts: 63
Rep:  (10) Rep Power: 5
| pc111 directions very not helpful..usb model help whats the deal on installing a map into the bike? i have the usb model. i just selected the map i downloaded from the interent and hit "send map". what does "send table " do? how do i know thw map is installed correctly? do i need to reset the throttle positions? at idle the position reads -4. need some help. thanks |
05-01-2004, 7:24 PM
Bike(s): 929 Age: 33 Posts: 837
Rep:  (70) Rep Power: 8
| Re: pc111 directions very not helpful..usb model help There should be an option in one of the menus for reseting the throttle position. It needs to read zero when the throttle is closed and 100 when the throttle is fully open.
Send map sends the map, which includes the ignition settings and the richen/lean chart (I forget the name of it).
Send table just sends the table you're looking at (either the ignition table or the other one), but not both.
I don't have the USB version but this is how the non-USB software works. |
05-01-2004, 8:28 PM
| Re: pc111 directions very not helpful..usb model help Quote: |
Originally Posted by EatnAsphalt There should be an option in one of the menus for reseting the throttle position. It needs to read zero when the throttle is closed and 100 when the throttle is fully open.
I don't have the USB version but this is how the non-USB software works. | thank you for the help.
i didnt reset the tp. and i have a red malfunction lite on on the dash now. i dont think they are related buy did yours come on after the install also?
if anyone has the usb model, how did you set yours up? |
05-01-2004, 9:18 PM
| Re: pc111 directions very not helpful..usb model help Does the red MIL light blink? It is normal for it to be lite when the engine is not running.
As long as you "clicked" the connectors (heard them click) when you plugged them inline to the stock harness, I don't see why the stock ECU would think there is a problem and blink the MIL light. |
05-01-2004, 10:31 PM
Join Date: 02-13-2004 Location: Lansvale Sydney Australia
Bike(s): CBR600RR Age: 36 Posts: 1,340
Rep:  (45) Rep Power: 6
| Re: pc111 directions very not helpful..usb model help Easiest way to send the map is to just press "insert" on you keyboard. Done.
Same as pciii etc. dunno why the fi light is on. |
05-01-2004, 11:10 PM
| Re: pc111 directions very not helpful..usb model help the lite stays lite when im riding. the flapper and htev valve were removed. i dont know why its on either. there doesnt seem to be a problem in the way the bike runs..... |
05-02-2004, 3:13 AM
| Re: pc111 directions very not helpful..usb model help If the motor that runs the HTEV and flapper was removed, that could cause the red light. Not sure though. |
05-02-2004, 10:24 PM
| Re: pc111 directions very not helpful..usb model help Yep, it can. It will eventually go out. Mine did. No worries though. |
05-03-2004, 11:49 AM
| Re: pc111 directions very not helpful..usb model help if thats the case that would be great. the lite blinks twice at idle. if anyone knows the code let me know. thanks |
05-03-2004, 12:04 PM
Age: 34 Posts: 930
Rep:  (10) Rep Power: 6
Originally Posted by The Sook Yep, it can. It will eventually go out. Mine did. No worries though. | Bulb eventually burned out.  |
05-03-2004, 10:25 PM
Originally Posted by n.e.o. rider if thats the case that would be great. the lite blinks twice at idle. if anyone knows the code let me know. thanks | For a 929, 2 blinks means there is a problem with the MAP sensor. Not sure if it's the same for the 954s. |
05-03-2004, 11:37 PM
Bike(s): 2004 Black ZX-10R, 2005 Blk/Grn Ninja 250R Posts: 280
Rep:  (18) Rep Power: 7
Originally Posted by EatnAsphalt For a 929, 2 blinks means there is a problem with the MAP sensor. Not sure if it's the same for the 954s. | Hmmm... Maybe the vacuum line to the MAP sensor pulled loose while the tank was up for installation? Just a guess. |
05-04-2004, 2:00 AM
#13 |
| Re: pc111 directions very not helpful..usb model help Nice one Kookie, may be right. The important thing was that it didn't blink any more. hahahaha |
