| General Discussion General Motorcycle Discussion. If it's related to motorcycles in any way, and doesn't fit into a more specific forum, it goes here. |
05-11-2004, 2:54 AM
Reputation Power: 12
Rivet type master link !?
hey guys i am about to change my chain and not about to pony up the $65 for a tool to peen over the edge of the masterlink, i used to use my buddies tool but it has been pilfered..... anyone ever use the ball end hammer or the punch method ???? i'm not about to take any chances when it comes to my chain....
I don't kill flies but I like to mess with their minds. I hold them above globes. They freak out and yell, 'Whoa, I'm way too high!'
05-11-2004, 5:35 AM
Re: Rivet type master link !?
Its anything like a push bike chain.......
I spent the better part of a day trying to knock out the link with a hammer and punch... gave up and bought the tool the next day....punched out the link in a few minutes.....save the frustration and banged knuckles and get the tool.
05-11-2004, 8:01 AM
Reputation Power: 11
Removing the chain isnt so much of a problem (dremel, drill, and punch), its installing the new link that would pose a problem. If you are not up for spending $100 on the tool, see what the shop will charge you to rent/install the chain for you. Bottom line - Only use the appropriate tool for the job, especially when your life depends on the job being performed.
05-11-2004, 8:10 AM
the question wasnt about removing the link rather about installing it....
05-11-2004, 8:21 AM
I was against the idea of doing it myself but after speaking with a lot of mecanics that have the tool but use a punch instead. I tried it with succes and it is a piece of cake!!!!
first use a pair of plyers, and a little bolt that you place on the edge of the rivet so to apply a pressure to get the plate in. Do both sides equaly and press until alined with the other links. Take a sledge hammer and put it on the back of the link to provide stability when you will hit the rivet.
I did not use a punch as recomanded by mecanics but a mecanical hammer round ege of hammer. Do not hammer to hard cause it is pretty soft (rivet)
good luck it is a piece of cake
Just ride like everyone is out there to kill you!!!
05-11-2004, 1:33 PM
05-11-2004, 3:47 PM
I don't think I would do the hammer thing just because I bought the tool kit that looks like the Motion Pro kit but is a knock off for $35 shipped. It's not the best quality but it does the job. It's not worth doing it wrong to save a couple bucks.
05-11-2004, 3:55 PM
Reputation Power: 32
I have seen several bent or broken sprockets from using the "hammer" technique. I would use a clip type master link safety wired before I took a hammer to the rivet ends . . .
and your girlfriend too.
05-11-2004, 6:13 PM
 $65 > your life (possibly)? Seems like cheap insurance to me. Especially if you can pick up the tool for only $35, like OnTheEdge.
05-11-2004, 9:08 PM
OK OK, you guys convinced me, I sprung for the tool..... it wasnt even a money issue, it was just... hell i dont even know... well anyway its done now and i feel better having done it properly.... the thing that started me thinking was when i asked the shop i am faithful to to lend or rent me the tool for an hour said to just use a hammer, "thats what everyone does" so i started thinking and naturally came to you guys for your opinion...
thanks again !!!!!
05-11-2004, 10:42 PM
just one more reason to do all your work yourself and foret the stealerships, they are all jokers and don't care if they do it wrong, heck its your bike and if the sprocket gets bent they just get more work changing it in a few weeks! They're all the same!
"How is education supposed to make me feel smarter? Besides, every time I learn something new, it pushes some old stuff out of my brain. Remember when I took that home beermaking course, and I forgot how to drive?" - Homer J. Simpson
| Search tags for this page |
easiest way to press chain motorcycle, how to install a motorcycle chain master link, how to join chain rivet joining link, how to peen a motorcycle chain, how to put a master link on a motorcycle chain, how to rivet a motorcycle chain, master link rivet tool, motorcycle chain master link rivet tool, motorcycle chain stamped master link, rivet master link, rivet type master link, rivet type motorcycle chain
You may not post new threads
You may not post replies
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
I can barely type...
Chain |
Off-Topic |
58 |
09-15-2003 6:45 PM |
