brake bleeding
Old 05-26-2004, 7:45 PM
BushrodW's Avatar
Bike(s): '01 cbr929; '04 aprilia rsvr factory, '65 Greeves
Rep: BushrodW is on a distinguished road (10)
Send a message via Yahoo to BushrodW
brake bleeding
I suppose this is a nit-pick question but here it is.
When bleeding one's brakes does it matter if the pistons *the ones in the caliper* are retracted or extetended?
Curious because my rear wheel pads seem to rub the disc more than the front and since it's time to change fluid I thought I'd exercise the old OCD and ask
BW
BushrodW is offline
View BushrodW's Profile View BushrodW's Gallery Find More Posts by BushrodW
Old 05-26-2004, 7:49 PM
smkeatr's Avatar
Bike(s): '06 VT750DC, '05 CRF250r
Rep: smkeatr will become famous soon enoughsmkeatr will become famous soon enough (103)
Re: brake bleeding
BW
You need to squeeze the brakes to bleed them under pressure. I believe the KB has the process posted. If not, you pump them, hold tight and open the bleeder screw. It will squirt out, the pedal, or lever will go all the way down and then tighten the screw. Repeat, repeat, repeat until all the air is out and it's nice and firm.
smkeatr is offline
View smkeatr's Profile View smkeatr's Gallery Find More Posts by smkeatr
Old 05-26-2004, 8:07 PM
I'm working on it...ok?
maxib's Avatar
Re: brake bleeding
Uhhh, just in case...
Don't do this if the calipers are not mounted on the rotors.
maxib is offline
Old 05-26-2004, 8:10 PM
smkeatr's Avatar
Re: brake bleeding
I assumed he still had them on the bike.
Whatever you do, don't apply the brakes if the calipers are off the rotor. It will be hell pushing them back in. Not to mention, whatever you would use to do it will most likely damage it.
smkeatr is offline
Old 05-26-2004, 9:49 PM
BushrodW's Avatar
Re: brake bleeding
the rub: suppose one is using a MityVac?
BW
BushrodW is offline
Old 05-26-2004, 10:37 PM
smkeatr's Avatar
Re: brake bleeding
BW
changing brake lines help..
smkeatr is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:23 PM.
