| General Discussion General Motorcycle Discussion. If it's related to motorcycles in any way, and doesn't fit into a more specific forum, it goes here. |
05-30-2004, 8:00 PM
Reputation Power: 11
how to repair pinhole radiator leaks??
i have the radiator fan relocated on the busa. it then proceeded to wear a couple little pinhole leaks in the radiator. how do i fix it? TIG weld? bars leaks? radiator repair shop? this radiator has been modified in order to work with an intercooler so i really need to repair it.
thanks
05-30-2004, 9:30 PM
Re: how to repair pinhole radiator leaks??
I saw McGyver put 2 raw eggs in a hot radiator to fix bullet holes....
Chris
05-30-2004, 11:01 PM
Chris
OMG... That just made me laugh hysterically.
Sorry soupy. I understand you're in a mess and waiting for helpful answers but the "McGyver solution" was funny... you gotta laugh.
Jordan H.
The three most feared words in racing, "Powered by Honda".
05-31-2004, 1:20 AM
Reputation Power: 10
Yellow pages for the local radiator shop.
01 929 red/black
05-31-2004, 7:50 AM
Reputation Power: 32
I use JB Weld and have run several crashed radiators that have been repaired with this or straight epoxy with excellent results.
Just make certain you let it cure for at least 36 hours before using it.
and your girlfriend too.
05-31-2004, 7:00 PM
Black pepper-like the kind you use on food. No joke. Just put some in the filler neck and run it for a little bit. Should take care of it.
Fightin' Texas Aggie Class of '05!
'01 CBR929RR Y/B, '02 Honda XR50 Death Machine
But officer, it's only a 4 cylinder!
05-31-2004, 8:21 PM
for a permanent fix on a turbo engine? not sure thats the route i'd like to take. i think i'm gonna try and TIG weld it tomorrow.
05-31-2004, 8:45 PM
Adding more and more CBR parts
Reputation Power: 15
If the core is brass or copper whip out with your electrical solder and a crack torch er I mean a propane torch.
Use a dremel to polish off any paint and get to some metal. It also helps if you make sure this puppy is bone dry before trying to fix.
on my 66 mustang 4 core radiator I had the fan bite a few cores. I cut out the damaged area. Pinched the tubes about an inch down and filled the fresh cut tube with solder.
05-31-2004, 9:08 PM
Awww, come on! Where's your sense of adventure?
05-31-2004, 9:23 PM
i too have used solder and a butane torch to fix a radiator. It was on an old jeep and the kids motor mount let go putting the fan into the radiator. We soldered about 20 holes in the middle of the woods, filled it back up with muddy water and it never leaked. He never even replaced the radiator and it's still not leaking 2 years later. Copper solders real well (obviously!)
Mark
"How is education supposed to make me feel smarter? Besides, every time I learn something new, it pushes some old stuff out of my brain. Remember when I took that home beermaking course, and I forgot how to drive?" - Homer J. Simpson
| Search tags for this page |
any motorcycle radiator repair, can i put some seal blocker in with my coolant on my 2003 honda 600rr, honda motorcycle radiator repair, how do i re weld a bracket on on a copper radiator, how do you stop a leak in a radiator on a 2004 ninja, how to fix a radiator leak on a honda motorcycle, how to fix motorcycle radiator leak, how to repair a dirt bike radiator, how to repair a motorcycle radiator, how to repair a motorcycle radiator leak, motorcycle radiator repair, pin hole in radiator repair
You may not post new threads
You may not post replies
