Cold pilot power pressures
Old 04-14-2005, 11:01 PM
Northern RR's Avatar
Bike(s): 04 1000RR Black and Silver
Rep: Northern RR will become famous soon enough (71)
Send a message via MSN to Northern RR
I have spent the night reading up on what pressures to run in my new pilot powers( ) I have seen anywere from 29 to 34PSI for the front and 31-36PSI for the rear...I just wanted to make sure that these are taken when the tire is COLD and also I wanted to find out how the tires wear at the lower pressures for street riding? Any help is greatly appreciated...Northern RR
Northern RR is offline
View Northern RR's Profile View Northern RR's Gallery Find More Posts by Northern RR
Old 04-15-2005, 12:02 AM
Kidder's Avatar
Bike(s): 07 Suzuki DL650 ABS
Rep: Kidder is on a distinguished road (10)
Re: Cold pilot power pressures
I run 36, 40 on my 04 Gixxer Thou.
Kidder is offline
View Kidder's Profile View Kidder's Gallery Find More Posts by Kidder
Old 04-15-2005, 8:06 AM
Do you have any traction issues running those pressures ? how are they wearing?
I have been finding that when running around 36-38 in the rear that it likes to break traction a lot(probabbly just the roads around here )
Old 04-15-2005, 8:43 AM
Bike(s): '02 Suzuki TLR, '05 Gold Wing, Candy Black Cherry
Rep: Newfie TLR is on a distinguished road (29)
Rob, I'm not sure of the rear, but I know in the front, less than max rated pressure will cause a bad case of cupping. I've found once it starts, the tire will always have it and will usually get worse. Now, you must note that I've never run on Michelins so I'm only guessing those will act the same as Bridgestones and Dunlops.
I run 42-42 almost all the time unless I go to the track. If you go for a "spirited" ride in the twisties, you may want to drop pressures, but then bring them up again. You know the roads down here, any ride is 99.9% on the center of the tire so we never get a chance to break the tire free.
Newfie TLR is offline
View Newfie TLR's Profile View Newfie TLR's Gallery Find More Posts by Newfie TLR
Old 04-15-2005, 9:56 AM
ccwilli3's Avatar
Bike(s): 2003 BabyRR
I'd contact a michelin tire rep or race tire distributor, but I'd doubt that 36/42 would be what they'd recommend.
ccwilli3 is offline
Old 04-15-2005, 10:57 AM
If that's what's on the sidewall, I'll bet they will, under normal street riding, that is.
Old 04-15-2005, 11:51 AM
motojedi's Avatar
Bike(s): 05 CBR600RR, 05 ST1300
Rep: motojedi is on a distinguished road (10)
I just ran mine for the first time on the track last sunday. I started with 30psi front and rear and had a 4 lb. gain in the front and 5 lbs. in the rear after the first session. I find this to be perfect. The tires felt fantastic. I'll probably add about 4 to 6 lbs. for the street. (34-36f/34-36r) The 30 psi starting point (cold) was reccommended by the tire-guy with Sportbike Track Time.
motojedi is offline
View motojedi's Profile View motojedi's Gallery Find More Posts by motojedi
Old 04-15-2005, 1:06 PM
sounds good, that is pretty close to what I am running now, I guess I just need the roads to clean up so that I can really have a good uidea of how well they stick
Old 04-15-2005, 10:13 PM
Meatarian
CBR929RE's Avatar
Bike(s): 01 R/B 929
Rep: CBR929RE is a splendid one to beholdCBR929RE is a splendid one to beholdCBR929RE is a splendid one to beholdCBR929RE is a splendid one to beholdCBR929RE is a splendid one to beholdCBR929RE is a splendid one to beholdCBR929RE is a splendid one to beholdCBR929RE is a splendid one to behold (932)
doesn't the sidewall just give the MAX psi for the tire
CBR929RE is offline
Old 04-16-2005, 12:20 AM
Bike(s): '06, '04 ZX10R, '03 954, '95, '98, '00 ZX6R
Rep: FuTAnT is on a distinguished road (22)
Bzzzt, the Michelins love lower pressures, and don't cup like the Bridges and Dunslops.
I run 32f, 36r and find them brilliant. Wear rate is also fantastic. I just leave them at this and scratch away! They really do work well at lower pressures than other tyres.
FuTAnT is offline
View FuTAnT's Profile View FuTAnT's Gallery Find More Posts by FuTAnT
Old 04-16-2005, 12:22 AM
Bike(s): 04 R6
Rep: Scratch is on a distinguished road (47)
Originally Posted by FuTAnT
<snip> I just leave them at this and scratch away!
You rang?
I find 32f 33r to be optimal for the street w/ power's. But that's just my opinion.
Scratch is offline
View Scratch's Profile View Scratch's Gallery Find More Posts by Scratch
Old 04-16-2005, 12:35 AM
Yes, just the MAX. That's all I've ever seen anyway.
Old 04-17-2005, 5:45 AM
Bike(s): 2001 CBR 929, camwork, full exhaust, PowerCommandr
Rep: MrFurious is on a distinguished road (10)
I will concur of the approximate pressures of 33F - 34R
MrFurious is offline
View MrFurious's Profile View MrFurious's Gallery Visit MrFurious's homepage! Find More Posts by MrFurious
Old 04-17-2005, 8:32 AM
abtech's Avatar
Bike(s): 2007 RC51
Okay, just had to check in on this one:
Picking an "ideal" pressure for track riding is like trying to pick a single "ideal" gear ratio for 4 different/dissimilar tracks. It just ain't gonna happen.
First of all, the starting pressure is relative and is used as a baseline to attain a 20% growth in pressure once the tires come up to full running temperature. Although the ideal "running temperature" can vary from brand to brand and compound to compound, it is usually between 170 and 185 degrees fahrenheit. This correlates to a standard increase (from stone cold to full hot) in pressure of approximately 20%.
In other words, regardless of your original cold pressure, once the tire is hot it should now be: original PSI + 20% of original PSI (30 pounds cold should be 36 pounds hot).
The actual percentage can be fine tuned, but this is a generally accepted guideline and the reason some manufacturers recommend a higher than "popular" cold starting pressure, as lower cold pressure will cause overgrowth and the tire will run much hotter than the compound/carcass was designed for.
This procedure of measuring pressure growth will take all of the variables into account including bike/rider combined weight, pace, ambient and surface temperatures as well as tire compound.
NB: As mentioned in another thread long ago and far away, the growth percentage for street riding (all else being equal) is around 10 percent.
abtech is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 7:06 PM.
