Slider installation - success!
04-25-2005, 8:23 PM
Bike(s): Bikeless Posts: 8,830
| Slider installation - success! http://www.yoyodyneti.com/
That wasn't as bad as I thought it was going to be. I got a sharp new 1-1/16" plastic/metal/wood holesaw from ACE. It would prove to do a fine job on cutting through the plastic without boogering up the paint.
Finding the place to drill my pilot hole was a little bit of a chore. I tried Play-Doh, but the crap would not stick to the inside of my fairing. When I finally got it to cling long enough to leave an impression from the engine mount bolt (which I had backed out so it could make contact with the Play-Doh), I disturbed the imprint as I removed the fairing. Grrr.
The laser taped to a stepladder and pointing at the center of the engine mount bolt method didn't work because you couldn't see the dot on the bike's red pearl paint. Maybe I had too much light in the garage or the laser I was using (an old pointer of my roommate's) was weak.
On to Plan C then... triangulation. Yep, borrowed a little trick from my days working accidents and was able to drill two nearly perfect holes in the plastic. The photos of the finished product speak for themselves.
04-25-2005, 8:28 PM
#2 | | Back From the Ashes!!
Bike(s): '00 RC51 (Possible Resurrection), 93 Seca II(Sold) Age: 31 Posts: 7,724
Rep:   (101) Rep Power: 14
| Re: Slider installation - succsess! Looking good Chain  |
04-25-2005, 8:38 PM
| Re: Slider installation - succsess! Has anyone here ever experienced a set of sliders where, after torquing the bolts down, one slider turns by hand? Believe it or not, my 954's left hand slider spun by hand. So does my busa's! Two different bikes, two different manufacturers, two different brands of sliders. How crazy is that??? |
04-25-2005, 8:39 PM
Bike(s): A few Posts: 1,000
| Re: Slider installation - success! Heh, those look like emergency stop buttons. |
04-25-2005, 8:40 PM
| Re: Slider installation - success! |
04-25-2005, 8:47 PM
| Re: Slider installation - success! Quote: |
Originally Posted by evl_twn Heh, those look like emergency stop buttons. | LOL...was thinking the same thing...Twist & Pull....
Looks good Stretcher...
Sith Apprentice
04-25-2005, 8:50 PM
| Re: Slider installation - succsess! Quote: |
Originally Posted by Chain Has anyone here ever experienced a set of sliders where, after torquing the bolts down, one slider turns by hand? Believe it or not, my 954's left hand slider spun by hand. So does my busa's! Two different bikes, two different manufacturers, two different brands of sliders. How crazy is that??? | After awhile, they almost will all spin...the bolts tighten on the collars, not the sliders....eventually the plastic creeps....
Personally, I like the factory Honda sliders....
Sith Apprentice
04-25-2005, 8:50 PM
Bike(s): 02 Red/Black CBR 954RR/ 08 Red/Black CBR 1000RR Age: 36 Posts: 2,026
Rep:  (58) Rep Power: 9
| Re: Slider installation - success! Looks like you did a pretty fine job there!!
And yes, my intuitive sliders on my 954 turn by hand as well. |
04-25-2005, 9:06 PM
#9 | | Resigned to pursue other interests.
| Re: Slider installation - success! I thought they were "Easy Buttons" for when he got that boat on the track.  |
04-25-2005, 9:18 PM
#10 | | Send Maple Clarice
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,813
| Re: Slider installation - success! Umm not sure you better bring it to Grattan or Barber so I can inspect the work  |
04-25-2005, 9:23 PM
Originally Posted by Baketech ...the bolts tighten on the collars, not the sliders....eventually the plastic creeps.... | Why does only one side turn then? I recall my Honda being the same way. Odd.
And what do you mean, the plastic "creeps"?  |
04-25-2005, 9:24 PM
Originally Posted by soon2b954 Looks like you did a pretty fine job there!!
And yes, my intuitive sliders on my 954 turn by hand as well. | Thanks!
Both of 'em?  Only my left hand side turned on my '54. |
04-25-2005, 9:24 PM
#13 |
Originally Posted by ConqSoft I thought they were "Easy Buttons" for when he got that boat on the track.  |  The boat will be at MAM on May 30th, rain or shine. |
04-25-2005, 9:26 PM
#14 | | Back From the Ashes!!
Originally Posted by Chain Thanks!
Both of 'em?  Only my left hand side turned on my '54. | On my buddies F4i I am almost certain that both turn at this point |
04-25-2005, 9:33 PM
#15 |
Originally Posted by Chain Why does only one side turn then? I recall my Honda being the same way. Odd.
And what do you mean, the plastic "creeps"?  | Just coincidence I'm guessing....manufacturing tolerance..
Creep is when a plastic slowly deforms under load....viscoelastic flow of the material over time...
Sith Apprentice
04-25-2005, 9:33 PM
#16 |
| Re: Slider installation - succsess! |
04-25-2005, 9:35 PM
#17 | | Back From the Ashes!!
| Re: Slider installation - success! When I get my sato sliders I am having you put them on  |
04-25-2005, 9:39 PM
#18 |
Originally Posted by TGZ13 When I get my sato sliders I am having you put them on  | I'd be happy to, my brotha (assuming you're talking to me)!
I'm pretty retentive about my mods. I measured a couple different ways before I was sure I had the spot right, then I let fly with the drill. Turned out about as close as you could hope to get it.  |
04-25-2005, 9:42 PM
#19 | | Back From the Ashes!!
Originally Posted by Chain I'd be happy to, my brotha (assuming you're talking to me)!
I'm pretty retentive about my mods. I measured a couple different ways before I was sure I had the spot right, then I let fly with the drill. Turned out about as close as you could hope to get it.  | I was talking to you
You should have seen when I cut the holes in my car door to put in the component system. I must have measured 100 times and still didnt want to cut into them lol. |
04-26-2005, 12:07 AM
#20 | | Every ride a gift...
Bike(s): '02 RC51; '05 DR-Z400SM; '06 CBR600RR Age: 46 Posts: 4,132
| Re: Slider installation - success! Nice bungs!  |
04-26-2005, 12:36 AM
#21 |
Bike(s): Addicted to them. Posts: 4,302
| Re: Slider installation - success! Thats a fine helmet holder you've got there, and one for a partna as well I see
why put off today what you can wake up late and forget to do tomorrow. GPS Discussion Forums - Don't ask, know |
04-26-2005, 8:02 AM
#22 |
Originally Posted by bwhip Nice bung!  | Eww.  |
04-26-2005, 8:03 AM
#23 |
Originally Posted by SomeStrangeGuy Thats a fine helmet holder you've got there, and one for a partna as well I see  | I'm trying to decide if the plastic slider tops ought to be black.  |
04-26-2005, 8:06 AM
#24 |
Originally Posted by Chain I'm trying to decide if the plastic slider tops ought to be black.  | Nope....put E-Stop legend plates on them insead...
Sith Apprentice
04-26-2005, 8:07 AM
#25 | | | |
