Totally crazy idea
Old 08-21-2005, 4:37 PM
Bike(s): 2000 CBR929
Rep: atr911 is on a distinguished road (10)
Totally crazy idea
Okay: flame retardant suit /on
Here's the though, I want to replace my gauge cluster with a flat pannel monitor.
I'm nuts I know.
Here's what I'd be interested in. LED shift lights replace tach. Only issue is mileage for resale and oil changes/maintenance, how can I get around this?
Screen could be used for:
-GPS
-data feedback from pc3
-rear view mirror from camera installed in tail
-race vids from camera installed in nose
Mounting the monitor (probably 7" 12V screen) is easy, I could either leave stock gauges in place and mount over top (swivel maybe?) or remove gauges (this is where the Odometer problem comes into play)
Wiring again is easy.
Here are the problems:
Will the unit be able to handle the vibrations?
Will the bike be able to handle the added strain on the electrical system?
Is there a device small enough to be recorded onto? Look at these little jump drives able to store 1+ GB now, there must be something out there!
I understand this probably isn't for 90% of you out there, I'm bored stupid and was thinking about this lastnight as I was driving along w/o mirrors (i'm too wide and can't see out them anyways!) and though it'd be pretty trick! Maybe even incorporate something like the Veypor aftermarket gauge as one of the programs....
Crazy but original!
Adam
atr911 is offline
View atr911's Profile View atr911's Gallery Find More Posts by atr911
Old 08-21-2005, 6:04 PM
Going into turn one
sheepofblue's Avatar
Re: Totally crazy idea
Screen is likely a lot of power and I am not sure PCIII puts out any data
Send maple
sheepofblue is offline
Old 08-21-2005, 7:35 PM
How do you tune it with a USB port then?
the primary use (other than the obvious just to be crazy) would be as a rear view mirror/video capture and recording device.
atr911 is offline
Old 08-21-2005, 8:02 PM
Going into turn one
The USB flashes the memory an activity that would probably result in a reset while running.
Of course check the RC51 forum for some corrupting ideas
Send maple
Old 08-21-2005, 8:19 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
Rep: seamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud of (1425)
I've just begun my planning to mount multiple cameras and a monitor for video capture/rear view also. Hadn't thought of GPS integration or removal of guages so the monitor was going to be smaller, but now I'm curious too.
Rear view camera is easy however I would like to have the video capture camera have sound and speed/tach overlay so I'm looking into that now.
seamus is offline
View seamus's Profile View seamus's Gallery Find More Posts by seamus
Old 08-21-2005, 8:39 PM
check out ott-motorcycles.ca they have some cool ideas and packages for video capture.... also, I have seen many SD based video capture recording devices out there that are quite small.... I'm VERY interested in the speed overlay if possible. I'll probably just use an LED tach. Take a look at some of the HUD units that are available too. There is one that has bar graph tach, speed (taken from a different sensor so it's MucH more accurate) and gear.
Adam
atr911 is offline
Old 08-22-2005, 12:45 AM
Sirkbac's Avatar
Bike(s): 2005 1000rr Repsol, 1984 Kawasaki 750 Turbo
Rep: Sirkbac is on a distinguished road (28)
Send a message via AIM to Sirkbac Send a message via Yahoo to Sirkbac
You could try this for an LED tach:
http://www.cbr929rr.com/revlight.htm
Ed Helbling
05 1000RR (Repsol)
00 929RR (ylw/blk)
86 Yamaha FZ750 (Ugly/Nasty)
84 Kawasaki 750 Turbo (Black/Red/Oil)
77 Puch Newport
73 Kawasaki G5 (Orange/Dirt)
02 Mazda Protege5
www.cbr929rr.com
2000 CBR 929rr FOR SALE!
Sirkbac is offline
View Sirkbac's Profile View Sirkbac's Gallery Visit Sirkbac's homepage! Find More Posts by Sirkbac
Old 08-22-2005, 10:27 AM
Das Ende ist hier
seamus's Avatar
Bike(s): One
Like the Revlight but I have a different plan. The 1krr has a tiny, useless cyclops light above the headlights that I plan on removing. The video capture camera will go there. The speed/tach overlay (if I can make it work) will be need to be sent to the video capture feed. I'll have a separate feed to a small (4in?) monitor for rear view.
I'm relooking my layout to see if I can get the GPS/larger monitor in place also. This would take me a lot longer as I'm not in Sheep's league of geekdom.
seamus is offline
Old 08-22-2005, 11:08 AM
Blow me.
phobiaphobe's Avatar
Bike(s): 998RR4
Since when was Vancouver in Ontario?
phobiaphobe is offline
Old 08-22-2005, 12:27 PM
Bike(s): 2005 Honda CBR 1000RR
Rep: Whippet Goode is on a distinguished road (11)
He's probably a GTA resident that wants to move out West ... pining away for the truly stunning macadam of BC.
Cheers
Whippet Goode is offline
View Whippet Goode's Profile View Whippet Goode's Gallery Find More Posts by Whippet Goode
Old 08-22-2005, 3:39 PM
Fig
Newton
Fig's Avatar
Bike(s): 929RRR
Rep: Fig will become famous soon enoughFig will become famous soon enough (123)
http://www.gumstix.com/
You can get a linux machine the size of a pack of wrigleys. Doesn't do video, but you can definitely capture some data.
Fig
Fig is offline
View Fig's Profile View Fig's Gallery Visit Fig's homepage! Find More Posts by Fig My Map Location
Old 08-22-2005, 3:52 PM
ND4SPD's Avatar
Bike(s): '84 Magna V30
Fig
ND4SPD is offline
Old 08-23-2005, 12:49 AM
LOL I think I neeed to update my profile, I just moved to GVA from GTA
atr911 is offline
Old 08-23-2005, 2:38 PM
Bike(s): 2001 CBR929RE1
Rep: MACI4LIFE will become famous soon enough (65)
Send a message via ICQ to MACI4LIFE
Thats a really good idea. too bad the 929 doesn't have that.
but the back would be an idea. especially for the side mirror replacements. Just wondering where it'll go.
MACI4LIFE is offline
View MACI4LIFE's Profile View MACI4LIFE's Gallery Find More Posts by MACI4LIFE
Old 08-23-2005, 8:44 PM
  #15
Das Ende ist hier
seamus's Avatar
Bike(s): One
http://www.pimall.com/nais/ultraminidvr.html
Little expensive and probably a bit overkill, but it's about what I'm looking at for the video capture. May be able to mount this and a switch to switch between video sources. Don't really need the rear view while on the track or recording the back twisties for posterity.
On the other hand, Lilliput makes a nice 7" touchscreen. I'd like to be able to use the 7" touchscreen to display the tach/speedo/gear selection with video underlay. The ultramini DVR would be there to capture video when wanted.
Maybe I should add this to the "what I want to see on the 06 Blade" thread...
seamus is offline
Old 08-23-2005, 9:04 PM
  #16
Going into turn one
OK I didn't want to rain on your fun but have a question. You have a 7" touch lcd that has a video feed coming to it, how do you overlay text? This would require either hardware and/or software plus something gathering RPM information Even a split screen front and back camera requires something to combine two video feeds in an intelligent manner. Just some thoughts.
Send maple
Old 08-23-2005, 9:20 PM
  #17
Mr. Brownstone
Bike(s): 05 600RR
So you want a video system that also logs data and can overlay that data real time with the video?
No problem.
http://www.aimsports.com/products/david/index.html
BDA116 is offline
Old 08-23-2005, 9:58 PM
  #18
Das Ende ist hier
seamus's Avatar
Bike(s): One
You're not raining on my parade, sheep. Questions will only give me food for thought. Geek makes me happy.
How do I overlay text/gauges/whatever? I don't know. Yet. Could I buy the AimSport deal? Maybe. Will it take me a couple of months, the entire winter, a year to make this work. Who knows? The fun is in the learning and experimenting. I'll probably let the really smart people do the majority of the hard work, buy components that may work and just fill in the blanks.
So far, I've found several DVRs that combine up to four cameras. Granted they're all 4 times the size of the trunk, but if there's a big one, there's got to be a small one somewhere.
Either that, or I'll buy a Goldwing, put my wife on the back with the Channel 7 News camera and ride heavy at Grattan next year. One way or another, I'm going to make this work. Anyone know if they make a high mount exhaust for the 'Wing?
seamus is offline
Old 08-23-2005, 10:03 PM
  #19
MSF Ridercoach
Getsome's Avatar
Bike(s): 05 CBR 1000RR
Rep: Getsome is a name known to allGetsome is a name known to allGetsome is a name known to allGetsome is a name known to allGetsome is a name known to allGetsome is a name known to all (618)
Send a message via MSN to Getsome
No problem.
I want one....
"Come on you sons of bitches! Do you want to live forever?"
[GySgt Daniel J."Dan" Daly, USMC; near Lucy-'le-Bocage as he led the Fifth Marines' attack into Belleau Wood, 6 June 1918]
Getsome is offline
View Getsome's Profile View Getsome's Gallery Find More Posts by Getsome My Map Location
Old 08-24-2005, 8:33 AM
  #20
Bike(s): 929RR, DR650SM
Rep: MotorGus is on a distinguished road (10)
Hello,
I ride a 929 and already thought about that. It's not easy to do, but is doable.
You can have a 7 inch lcd monitor set up on the bike, as long as it works on 12 volts. The alternator a wreckulator/rectumfryer have plenty of juice for such device, so its not a problem.
About the vibes, it depends on the tyupe of vibes, and quality of the equipment.
about the multifunction monitor, that will be VERY expensive, as you need to do some real programing to integrate all the information you mentioned in only one screen and arrange it in a way that nothing conflicts. Looks more a job to an experienced info/electronic engineer.
Than you have another problem, these LCD's mounted on bikes are very sensible to light variations, so when you see perfectly at night, you see a blank screen in day light, you'll have to adjust the brightness from day to night, and vice-versa. Also direct sunlight will give you a hard time seeing whats in the screen...
I've done the lcd + plus cam rear view mod, to remove those ugly mirrors. It works, but it requires some training till we're confortable.
I've used a 2,5 inch tft monitor, as a 4 inch was too big without removing the gauges. But since the 2,5 seems to be a little small, i'm getting another fairing stay so i can do some changes in the structure and move the stock gauges to another position.
One other thing, you'll need to instal a capacitor between the monitor, and bike wiring, otherwise, the image will flicker with the increase of revs.
The electrical juice is continuous and sensible to alternator output, so higher revs, means higher output, more work to the wreckulator/rectumfryer but the end output is not a perfect stream of juice, still has some oscilations, that you'll notice on the screen or lights.
MotorGus is offline
View MotorGus's Profile View MotorGus's Gallery Find More Posts by MotorGus
Old 08-26-2005, 9:21 PM
  #21
Das Ende ist hier
seamus's Avatar
Bike(s): One
Which is a better DVR format, DiVX AVI or MPEG4?
I'm consistently narrowing down my search for mini DVRs and cameras and this is my second stumbling block. The first one being the gauge display.
I think I've solved the LCD brightness (direct sunlight washout) problem by putting the camera in the small (useless) light housing. This allows me to keep my dark windscreen. An LCD brightness of approximately 300-400 nits (see, I already learned something) will keep the visibility of the LCD screen useful in indirect sunlight.
With the hardware issues pretty much solved, all that's left is the details. Of course, the details in this case are the trickiest part.
seamus is offline
Old 08-26-2005, 9:33 PM
  #22
Huummmm, sorry to spoil your party, but the real problem is not direct sunlight to the camera. The reall bugger, is the sun reflection on the LCD monitor, as the camera has an autoadjusting device who reacts on higher/lower brightness levels to optimize view.
The LCD becomes indistinct when you have the sun light on your back reflecting on the lcd screen.
When i go in the h/way by the afternoon with the sun on my back i can't see much, but everytime i pass under a bridge or tunnel, there i see perfectly behind has there's no sunlight reflection!
As i said, it's doable, but requires some pratice for daily use.
MotorGus is offline
Old 08-26-2005, 10:28 PM
  #23
Das Ende ist hier
seamus's Avatar
Bike(s): One
I didn't write that clearly. The LCD screen will mount in place of the original instrument panel. The dark windscreen will shield the screen from direct sunlight.
seamus is offline
Old 08-27-2005, 2:34 AM
  #24
Hey, I love both cities. Toronto is a beautiful city... no complaints about it - one of my top half dozon favourite cities in the world, that I've been to... aside from the fact that Western Canadians despise it (kinda' like the NY vs LA thing for those south of the 49th). You'll fit in well in Vancouver - just don't mention your from Toronto, eh.
Cheers
Old 08-27-2005, 7:28 AM
