What is the secret to using the microfiche at ronayers.com? I recently called them to get help identifying the part numbers I want to order (and got friendly, knowledgeable help), but it seems I should be able use the fiche and figure it out myself. Two problems:
1. There are two part numbers listed for the same diagram number. Example: look up a stator (alternator) cover for a '01 929. There are two Honda part numbers listed...which one?
2. There are two separate fiche images for a group of parts. Example: a clutch lever perch for a '01 929...there is a group called "Cable-Switch 1" and another called "Cable-Switch 2". Sometimes there are multiple part numbers in each of these (problem 1) too.
There must be something simple that I'm missing? Maybe one of you brainiacs can point me in the right direction...
