11-04-2005, 1:57 PM
#1 | | Compromise
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,762
| Brake Marker Placement? I am wondering what the spacing is on brake markers at the track?
For those that are going  I am trying to figure some maximum accelerations for my computer. I figure hard front braking is likely the most G's a bike pulls. Given the distance I can guestimate the maximum I will generate by calculating speed change vs braking distance (yes I missing time I know).
11-04-2005, 3:31 PM
Bike(s): Puch Posts: 14,391
| Re: Brake Marker Placement?
Sheeply, you're trying too hard. There is no standard followed by motorcycle tracks. Spacing and location can change depending on the mood of the cornerworker that day. They can be moved during the day.
Never, ever try to calculate something based on spacing as a given, it's a good way to end up on your head.
Hard on the brakes I went go over 1.2 G's. |
11-04-2005, 3:55 PM
#3 | | Compromise
| Re: Brake Marker Placement? Quote: |
Hard on the brakes I went go over 1.2 G's. | OK I was guessing a 2G sensor is enough. What did you pull yours from? and this is for post ride analysis and sensor construction, I am not trying to calculate where to brake
11-04-2005, 4:01 PM
| Re: Brake Marker Placement? 2G sensor is enough as long as you don't hit anything.
It's an integrated G-force/tilt sensor that comes with my data aq.
They are incredibly fragile. I had 2 die on me. |
11-04-2005, 4:06 PM
#5 | | Compromise
11-04-2005, 4:37 PM
| Re: Brake Marker Placement? It's just a dx/dt calc. Your sensor should have the calibration curve. |
11-04-2005, 4:59 PM
#7 | | Compromise
Originally Posted by luvtolean It's just a dx/dt calc. Your sensor should have the calibration curve. | Actually it outputs a signal that I can run into my a/d converter and log. The calculation I am referencing is what I am going to do with it. I am thinking lean for sure but considering a poor sheep's IMU so I can calculate track position and lean (maybe cross correlated with GPS). Just trying to think it through then let it sink into my thick skull some  kind of a measure twice cut once thing. Still plotting though and trying to figure what sensors I want then $ and placement and programming. Of course then I will have to make my app on the Mac to download, compute, plot, predict or in general crunch the data gathered.  Guaranteed to keep the wool busy for a long time to come.
11-04-2005, 5:05 PM
Bike(s): 2000 929 Posts: 725
Rep:   (105) Rep Power: 9
| Re: Brake Marker Placement? The markers are only good for reference from your last lap. Not only do they sometimes move or get hit, on a few turns you can brake after all the markers have gone by. |
11-04-2005, 5:59 PM
Bike(s): SV650S Posts: 5,710
| Re: Brake Marker Placement? Especially don't try to use the brake markers at Grattan. An evil little Frenchman likes to mess with your reference points there...
Is a paradigm worth 20 cents?
11-04-2005, 6:00 PM
#10 | | Mr. Brownstone
Originally Posted by tigerblade blah blah blah Iliketoplaywithmynuts blah blah......evil little Frenchman...blah blah.......... | Wow, went for the triple redundancy this time, eh? |
