help...key won't open gas tank - Honda Motorcycles - FireBlades.org
post #1 of 17 Old 05-04-2006, 10:30 PM Thread Starter
Just pulled the bike out of the shed from the winter and my key won't open up the gas tank. I've tried all three of my keys as well as lubricants. I've tried pushing the cap down and jiggling in every which way. What should I do?
ric641 is offline
post #2 of 17 Old 05-04-2006, 10:38 PM
sheepofblue's Avatar
Images: 91
Reputation Power: 45
Re: help...key won't open gas tank
I would let the lubricant set in for a day or so before bringing it to the locksmith. However this might change with more detail on how they do not work (I assume the key won't turn) Also remember penetrating oil generally evaporates with time so use a couple of applications over time and if it work use something like graphite lube on it after you get it open (to avoid rusting or seizing
Must obey the sheep dog
sheepofblue is offline
post #3 of 17 Old 05-04-2006, 10:39 PM
G-Force Junkie's Avatar
Reputation Power: 22
Sure it your bike Have you tried unbolting it? Sounds like some of the tumblers are sticking...try filling it with a penetrating oil and let it sit a while. Then push the key in and out a few dozen times to loosen things up.
G-Force Junkie is offline
post #4 of 17 Old 05-04-2006, 11:39 PM
Images: 10
Reputation Power: 32
That has happpened to me on the road, riding on fumes. My only option was to take the dipstick (VFR) and get some hot motor oil on the key.. worked the tumblers gently for a few minutes. Result!
If by being violent you mean Islam prescribes expansion of its rule through warfare and is therefore violent then so be it. - SPDUDE
See you at Grattan June 25-27 2007 !
Email me for info.
CBRVFR is offline
post #5 of 17 Old 05-05-2006, 1:34 AM
Custom900's Avatar
Images: 13
Send a message via AIM to Custom900
Without a doubt the tumblers are sticking. Over time the brass corrodes and mends itself to the aluminum to some degree. Spray liberally with WD-40 and slide the key in and out of the keyhole. If that alone does not work gently tap on the top of the key with something like the end of a screwdriver. This will likely knock the stubborn tumblers loose.
If all else fails a locksmith will drill it out.
Freedom of Speech
Custom900 is offline
post #6 of 17 Old 05-05-2006, 10:10 AM
rb1
Another option to consider, though it may not apply to your bike:
I had an F4i key fail to open the tank lock when the bike was new. (The very first time I took it to get gas!) In this case, the key would turn, but it seemed not to turn quite all the way. I unbolted the cap and discovered that the lock bolt on one side didn't retract far enough to clear the lip to allow the lid to open. I ended up filing the tip of the bolt to shorten it (just a tiny, tiny bit). I lightly filed it, put it back on the bike, if it didn't work, I filed it again... until it finally worked. I never had any problems after that.
It's not likely that your bike has the same problem, but no matter what the problem is, it will be easier for you to figure it out if you unbolt the lock and cap from the bike so you can see what happens when you turn the key.
rb1 is offline
post #7 of 17 Old 05-05-2006, 11:09 AM
Custom900's Avatar
Images: 13
Even if he unbolts the cap if the cap is still locked he will not be able to get the cap assembly off the bike.
Freedom of Speech
post #8 of 17 Old 05-05-2006, 11:58 AM
rb1
I had to wiggle the key for about 1/2 hour before I finally got it open. Then I took it off see what was causing the problem. I just wanted to point out that, even if you get the lock open by lubing it, it's a good idea to look at the lock mechanism before deciding that it is OK. Otherwise, it could just happen again.
rb1 is offline
post #9 of 17 Old 05-06-2006, 12:04 AM
Custom900's Avatar
Images: 13
Glad to hear that you got everything up and going again. Now the next time you put the bike into storage you will put a little oil in the lock as well.
Freedom of Speech
post #10 of 17 Old 05-06-2006, 12:27 AM
rb1
Are you confusing me with ric641? I don't see anything from ric641 saying he got it fixed yet. (and I didn't have my bike in storage)
I hope you're right, and ric641 did get it fixed.
rb1 is offline
post #11 of 17 Old 05-06-2006, 8:15 AM
HondaGalToo's Avatar
Images: 16
Reputation Power: 29
That happened to mine, too, a few years ago. I did manage to get the cap open (after bending one key), but I then had to unbolt it and fiddle with the alignment. The key worked, but the lock wasn't retracting enough due to poor alignment. It's been fine since I did that.
So, yeah, loosening it up and jiggling it around a bit might help.
HondaGalToo is offline
post #12 of 17 Old 05-06-2006, 10:51 AM
Custom900's Avatar
Images: 13
You're right. I did get the two of you confused.
Freedom of Speech
post #13 of 17 Old 05-08-2006, 1:35 PM
Purpdust's Avatar
Reputation Power: 21
Send a message via MSN to Purpdust
I have heard of this technique used in other practices as well
Purpdust is offline
post #14 of 17 Old 05-08-2006, 3:53 PM
Custom900's Avatar
Images: 13
I really don't want to hear about your practices with Phobe.
Freedom of Speech
post #15 of 17 Old 05-08-2006, 4:05 PM
MrX954's Avatar
Images: 5
Send a message via AIM to MrX954 Send a message via Yahoo to MrX954
OMG, as soon as I saw this threads title I remembered being stranded at the gas station so many times on my F4i desparately trying to get the cap open, since the Honda dealership wouldnt replace it
Anyways those sure were spine chilling moments when the fuel light came on
X
MrX954 is offline
Human Verification
Search tags for this page
honda gas cap key dont work
honda motorcycle gas tank door wont unlock
how to unlock cbr 600 gas cap without a key
how to unlock the gas tank on a 99 honda shadow without the key
key wont open gas tank
motorcycle gas cap won't open
motorcycle gas tank key won't turn
motorcycle gas tank will not open
motorcycle gas tank wont open
yamaha dirt bike gas key wont open
Gas Tank Question, 96/97 and 98/99... Help mwallans Honda FireBlade 7 05-01-2007 7:52 PM
Gas Tank Prop 929rrob Honda FireBlade 21 05-24-2005 4:36 PM
929 gas tank? bl954rr Honda FireBlade 2 07-06-2004 8:59 PM
Gas tank question? prkiller Honda FireBlade 1 05-20-2004 9:52 PM
Gas tank/ Gas cap question 954WRECKER General Discussion 8 04-12-2004 11:18 PM
