07-31-2006, 10:25 PM
#1 | | MSF Ridercoach
Bike(s): 05 CBR 1000RR Age: 34 Posts: 2,179
| Metal in tire OK, I went for my first good ride in weeks today and at some point ended up with a very thin piece of metal in my week old rear tire.
it was pretty much paper thin, went from 1/4 inch wide to about 1/2 inch wide over the inch or so it went into the tire.
It seemed to go in at a very shallow angle, it pulled out of my nicely heated up tire very easily and smoothly and doesn't seem to have gotten into the carcass at all.
At first I thought to myself that it didn't go deep enough to do any real damage or cause me any issues but after spending a couple hours in the twisties and then coming home it has been popping into my head over and over.
Should I worry about it and replace the tire or should I monitor it and if the area starts to tear then worrry about it?
I have never had anything go wierd with tires before other than normal wear and replace so I am not sureif I should really worry about this or not.
"Come on you sons of bitches! Do you want to live forever?"
[GySgt Daniel J."Dan" Daly, USMC; near Lucy-'le-Bocage as he led the Fifth Marines' attack into Belleau Wood, 6 June 1918]
07-31-2006, 10:31 PM
#2 | | Das Ende ist hier
Bike(s): One Posts: 2,705
| Re: Metal in tire If it's taking your mind off the road, you should replace it. |
07-31-2006, 10:52 PM
Join Date: 01-31-2006 Location: Linconton, GA - Where I can ride year 'round
Bike(s): The REAL KING - Hayabusa Age: 33 Posts: 2,932
| Re: Metal in tire Got pics??? |
07-31-2006, 11:24 PM
Bike(s): too many to list Age: 30 Posts: 14
| Re: Metal in tire seriously, if you are worried about it, replace it. |
08-01-2006, 6:08 AM
#5 | | Snossberries taste like Snossberries.
Bike(s): Fast Posts: 2,762
| Re: Metal in tire I've got to say, if I were you, and there was not an obvious "split" where the object entered, and it didn't enter the tire past the threads, I might just monitor it - of course, I buy with road hazard on my tires, so I would have replaced it....
Go with your gut feeling though. Only you know what you should do.
__________________  |
08-01-2006, 3:28 PM
#6 | | MSF Ridercoach
| Re: Metal in tire No kind of raod hazard stuff available on bike tires that I know of here.
I know it didn't go deep enough to get past the tread part of the tire but there is an obvious tear on the surface.
A couple pics of what it looks like after going about 70 miles after I got the metal in it and took it out.
I think I am more concerned about the fact that I was not worried about it and maybe I should be.
08-01-2006, 3:38 PM
#7 | | Mr. Brownstone
| Re: Metal in tire I wouldn't worry about that. |
08-01-2006, 4:09 PM
Bike(s): 2000 Fireblade, 02 GSXR 600 Track Bike (sold) Posts: 404
Rep:  (65) Rep Power: 6
| Re: Metal in tire Quote:
Originally Posted by BDA116 I wouldn't worry about that. | |
08-01-2006, 4:32 PM
#9 | | Send Maple Clarice
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,813
| Re: Metal in tire Mark the sidewall and do a couple of inspections over the next few hundred miles. But I would ride it. |
08-01-2006, 4:45 PM
#10 | | Meatarian
Bike(s): 01 R/B 929 Age: 28 Posts: 12,236
| Re: Metal in tire I would ride with it also (I've rode on a plug for many thousands of miles before without issue).
if you're really worried take it off and inspect the inside of the tire (I doubt you'll see anything as you said you don't think it went that far in). could give you a little piece of mind though.
08-01-2006, 4:50 PM
#11 | | Das Ende ist hier
Originally Posted by Getsome No kind of raod hazard stuff available on bike tires that I know of here.
I think I am more concerned about the fact that I was not worried about it and maybe I should be. | Mark the sidewall with a grease pencil so you can quickly find it and ride. That doesn't look anything like the mental picture the initial description put in my head.
If it keeps distracting you from riding, replace it so you can keep your mind on the ride. |
08-01-2006, 4:51 PM
| Re: Metal in tire Tire looks good to me. I wouldn't worry about it at all. |
08-01-2006, 8:26 PM
#13 |
Bike(s): 954 Posts: 82
Rep:  (43) Rep Power: 3
| Re: Metal in tire I have marks like that on my tires also. Just forgett about it. you would be loosing air if you had a problem. |
08-01-2006, 8:39 PM
#14 | | maybe because it does not really matter...........
Bike(s): 94 CBR 900RR Age: 36 Posts: 1,267
Rep:   (127) Rep Power: 5
| Re: Metal in tire I'd ride it. |
08-02-2006, 6:23 AM
#15 |
Bike(s): Honda CBR 954RR Age: 23 Posts: 42
Rep:  (17) Rep Power: 0
| Re: Metal in tire Instead of replacing it and burning 120+ on a new one. I'd suggest going out and buying tire sealant. I had something puncture a small hole in my rear tire a couple weeks ago, and I went out and bought this tire sealant. Don't remember what its called, but its green and CAN be used on motorcycle tires. Just read the package, because I know they make different kinds for cars/trucks. I bought mine at Wal-Mart so you might went to check there, or an auto parts store should have it. Just so you know that you have to drain the air out of the tire first. Then apply the sealant, and put air back into it. |
08-02-2006, 8:51 AM
#16 |
Originally Posted by MetalMilitia Instead of replacing it and burning 120+ on a new one. I'd suggest going out and buying tire sealant. I had something puncture a small hole in my rear tire a couple weeks ago, and I went out and bought this tire sealant. Don't remember what its called, but its green and CAN be used on motorcycle tires. Just read the package, because I know they make different kinds for cars/trucks. I bought mine at Wal-Mart so you might went to check there, or an auto parts store should have it. Just so you know that you have to drain the air out of the tire first. Then apply the sealant, and put air back into it. |
That schizzle has NO place in an MC road tire...
Sith Apprentice
08-02-2006, 11:13 AM
#17 |
Bike(s): '06 CBR1000RR, '06 CRF450X, '06 CRF100 Posts: 5,998
Originally Posted by Baketech
That schizzle has NO place in an MC road tire...  |  |
08-02-2006, 11:15 AM
#18 |
| Re: Metal in tire It's working for me so far and saved me some $$$. What's wrong with it? |
08-02-2006, 11:33 AM
#19 | | Activate Interlock, Dynotherms Connected
Bike(s): 05 GSXR1000 Y/B, 06 GSXR750 B/W Age: 33 Posts: 1,528
Originally Posted by MetalMilitia It's working for me so far and saved me some $$$. What's wrong with it? | It is kind of like playing with fire. You can do it, but at some point you will get burnt |
08-02-2006, 1:00 PM
#20 |
| Re: Metal in tire No no no. No sealants.
That stuff throws everything out of balance. Not only that, it's supposed to only be a temp fix. |
08-02-2006, 1:58 PM
#21 |
Originally Posted by Custom900 That stuff throws everything out of balance. | And be sure to let the mechanic who changes that tire next know that there is sealant in it...'cuz he won't want to be dragging on his cigarette when he pops that bead. |
08-02-2006, 3:41 PM
#22 |
Bike(s): POS '04 ZX-10R Age: 39 Posts: 1,475
| Re: Metal in tire Ride it as is or replace it but dont use a sealant.... |
08-02-2006, 5:19 PM
#23 | | Meatarian
| Re: Metal in tire that tire sealant is made by Slime SLIME - Smart Solutions for Flat Tire Prevention & Repair!
I wouldn't use it on any vehicle. remember when you put that crap in its not just coating the tire, its also coating your wheel too. so when you go to put the next tire on you have a shitload of crap to clean off your wheel.
