08-24-2006, 8:47 AM
Bike(s): 02 sv650, 00 R6 (track only) Posts: 244
Rep:  (50) Rep Power: 7
| I need to weld a nut Ok not my nut but a nut on the back of my forks.  The track bike I just bought has had the one and only Pinch bolt (under the axle) stripped. I tried working with the Heli-coil kit but had less faith in it the more I worked with it. Now my new theory is to try and have a nut welded on the backside of the fork. Than run a long enough bolt through. Any thoughts on this? Is it safe to weld on the fork? Should I try and tap the hole to the next size bolt? It was an M8 x 1.25. (goto a M9?) |
08-24-2006, 9:07 AM
Bike(s): 04 R6, 04 Vstar classic Age: 41 Posts: 2,243
| Re: I need to weld a nut Your title got me to check this thread out  Glad you point it out that you were talking about bike nuts.  |
08-24-2006, 9:13 AM
| Re: I need to weld a nut Quote:
Originally Posted by Frenchier6 Your title got me to check this thread out  Glad you point it out that you were talking about bike nuts.  | I should have known you would reply to this thread, thankfully I came out unscathed  |
08-24-2006, 9:20 AM
#4 | | Adding more and more CBR parts
Bike(s): 79 Kawabretta TS1-225, 2004 Frankenviffer Age: 34 Posts: 1,193
| Re: I need to weld a nut Tap it all the way through using the same size tap and use a longer bolt? If it is stripped all the way through then just slap a nut on the end sticking out and safety wire it?
Edit... take it to a machine shop for professional heli coiling |
08-24-2006, 9:45 AM
Originally Posted by Johnny Diablo Tap it all the way through using the same size tap and use a longer bolt? If it is stripped all the way through then just slap a nut on the end sticking out and safety wire it?
Edit... take it to a machine shop for professional heli coiling | Good call. But safety wiring a nut could be tricky I think. I have done the heads of bolts but not a nut. Is that possible? |
08-24-2006, 9:50 AM
| Re: I need to weld a nut Probably not the best fix, but you could use a castle nut until a permanent repair or replacement....
Sith Apprentice
08-24-2006, 11:00 AM
#7 | | Send Maple Clarice
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,813
| Re: I need to weld a nut Or nylon lock nut. Or Red Loctite. Or a cotter pin beyond the nut to keep it from backing of (still could loosen) Or a cotter pin through the bolt and nut (would prevent torqueing though) |
08-24-2006, 11:20 AM
Originally Posted by sheepofblue Or nylon lock nut. Or Red Loctite. Or a cotter pin beyond the nut to keep it from backing of (still could loosen) Or a cotter pin through the bolt and nut (would prevent torqueing though) | Yeah I thought of that to. I would like to be able to torque it again though. Hmmmmmm........ |
08-24-2006, 11:36 AM
#9 | | Send Maple Clarice
Originally Posted by eyauch Yeah I thought of that to. I would like to be able to torque it again though. Hmmmmmm........ | If you torque it then drill it will be close (but not the same) Personally I would use red loctite with a cotter pin beyond the bolt to ensure it stays on. |
08-24-2006, 5:56 PM
#10 | | Meatarian
Bike(s): 01 R/B 929 Age: 28 Posts: 12,233
| Re: I need to weld a nut I think what Bake was saying is that you put a long bolt all the way through, put a castle nut on the end and drill a hole in the bolt and slide a cotter pin in (just like how Suzuki does their rear axles). you could also safety wire the bolt/nut instead of using the cotter pin if you choose.
and of course throw some red loctite on there.
