winter maintainance
Old 11-14-2006, 9:27 PM
Bike(s): 2002 CBR600 F4i
Rep: fshrmn76 is on a distinguished road (10)
Send a message via AIM to fshrmn76
winter maintainance
I finally took my bike off the road for the winter. I have some questions as to doing maintenance and cosmetic work during the cold months. My brother bought me a set of stands to keep the bike off the concrete. Is it safe or even recommended to do simple things like change the fluids, remove the fairings etc. while on the stands or should I leave it on the side stand like I have been doing all summer.
fshrmn76 is offline
View fshrmn76's Profile View fshrmn76's Gallery Find More Posts by fshrmn76 My Map Location
Old 11-14-2006, 9:29 PM
Blow me.
phobiaphobe's Avatar
Bike(s): 998RR4
Re: winter maintainance
Is the garage heated?
If you do a search you'll find dozens of threads on this topic, but at a minimum I would recommend:
-putting it up on stands
-changing the oil
-taking the battery out (or hookoing up a trickle-charger)
-topping up the fuel tank and adding stabilizer
-put a cover over her
phobiaphobe is offline
Old 11-14-2006, 9:49 PM
Hammer's Avatar
Bike(s): GSXR Stunt Bike
Rep: Hammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud of (1355)
Phobe,
I usually leave my old oil in the bike through the winter. I have read that over time the oil creates toxins and you do not want to run that oil through the motor when spring hits thinking you have good oil in it. I usually just leave the old oil in the bike through winter and put fresh in before my first track day. I just don't see the need in changing new oil again. I may be wrong but who knows.
Hammer is offline
Old 11-14-2006, 9:56 PM
Das Ende ist hier
seamus's Avatar
Bike(s): One
Rep: seamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud ofseamus has much to be proud of (1425)
-take it off the stands
-change the oil
-put the battery back in (or take it off the trickle-charger)
-top up the fuel tank
- throw on your cold weather gear
- ride every day there isn't snow on the ground
seamus is offline
View seamus's Profile View seamus's Gallery Find More Posts by seamus
Old 11-14-2006, 11:48 PM
Custom900's Avatar
Bike(s): The REAL KING - Hayabusa
Rep: Custom900 has a spectacular aura aboutCustom900 has a spectacular aura aboutCustom900 has a spectacular aura about (231)
Send a message via AIM to Custom900
-change the oil
That was my thought.
Winter prep for me means putting on a different jacket and a thicker set of gloves.
Custom900 is offline
View Custom900's Profile View Custom900's Gallery Find More Posts by Custom900
Old 11-15-2006, 12:05 AM
NanoSfere's Avatar
Bike(s): '06 1000RR, 01 929RR
Rep: NanoSfere will become famous soon enough (72)
Send a message via AIM to NanoSfere Send a message via Yahoo to NanoSfere
And down here, there is no winter. Just like Custom, ride all year.
NanoSfere is offline
View NanoSfere's Profile View NanoSfere's Gallery Find More Posts by NanoSfere
Old 11-15-2006, 5:11 AM
HondaGalToo's Avatar
Originally Posted by Hammer View Post
Phobe,
Nah, you're better off changing it before Winter storage, as you don't want all those acids and stuff sitting in there all Winter. I change mine prior to storage, and use that oil in the Spring. Unless it's stored for more than 6 months, changing the oil again in Spring isn't necessary. The reason for the second change is because the oil might accumulate moisture, but it's unlikely that'll happen in just a few months. That's the reason for using a battery tender and not just starting it up periodically to charge the battery without actually riding the bike. Just my two cents.
HondaGalToo is offline
Old 11-15-2006, 11:53 AM
gt702's Avatar
Bike(s): Enough for now
mostly. You will get moisture build up even in just a few months if the temperature floats above and below freezing (or close to it). So for your first ride in the spring (or even if just running it) be sure to let it warm up to the point the thermostat opens and everything gets up to full operating temperature for at least 10 minutes. The water will evaporate off, and this will burn off any extra fuel that runs down the cylinder into the oil while trying to get the cold engine started.
Definitely change it before winter. The combustion by-products are corrosive and are in the oil. This is what you want out before the oil gets water and starts the reactions going
gt702 is offline
Old 11-15-2006, 6:17 PM
thank you for all the replys, but i still am unsure if it is safe to do all of these things while the bike is on the stands or should i drop it down and do it on the side stand. sorry if it sounds like a dumb question i am new to this sort of thing.
fshrmn76 is offline
Old 11-15-2006, 6:19 PM
gt702's Avatar
Might depend on the stands. I do everything on the stands. You have to be careful losening and tightening bolts, but otherwise it works. I like to put the bike on the side stand for draining the oil because that makes the drain the low spot on my bike.
gt702 is offline
Old 11-15-2006, 6:20 PM
Hammer's Avatar
I do all my maintaince on the stands as my bike does not have a side stand.
Hammer is offline
Old 11-15-2006, 6:25 PM
maybe because it does not really matter...........
JBODIE's Avatar
Bike(s): 94 CBR 900RR
Rep: JBODIE will become famous soon enoughJBODIE will become famous soon enough (127)
My thoughts also.
JBODIE is offline
View JBODIE's Profile View JBODIE's Gallery Find More Posts by JBODIE
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 6:51 AM.
