Does clutchless shifting damage the transmission? - Honda Motorcycles - FireBlades.org
post #1 of 22 Old 02-01-2007, 12:47 PM Thread Starter
Reputation Power: 15
I have been shifting my 954 and even my Dana without using the clutch. After I learned how at the track I use it on the street too.
My friends say I could damage the transmission or at least wear it out sooner.
Does anyone have a scientific explanation of if this is true and why.
It seems to me the were would be negliable with or without a clutch.
Thanks
I go slow... I go slow...
I shall wear the bottoms of my trousers rolled.
mmeacham is offline
post #2 of 22 Old 02-01-2007, 1:23 PM
nedro's Avatar
Reputation Power: 25
Re: Does clutchless shifting damage the transmission?
It damages the engaging dogs and it bends the shifting forks. Racers do it but then, they take their trannis apart every year and replace the broken/ bent stuff. Do you?
And it's not quicker.
Ride Red
nedro is offline
post #3 of 22 Old 02-01-2007, 2:25 PM
ConqSoft's Avatar
Images: 143
Reputation Power: 37
See similar threads below also.
ConqSoft is offline
post #4 of 22 Old 02-01-2007, 2:51 PM
Reputation Power: 11
Use your clutch. It's there for a reason.
madkaw is offline
post #5 of 22 Old 02-01-2007, 3:47 PM
Reputation Power: 23
Two cents+: I've done constant clutchless upshifting, and occasional clutchless downshifting with my 929. I've done it at full throttle, max rpm for more than 65 track days. I do not have any problem whatsoever with the transmission. It still shifts clean and easy. Nothing is bent. Nothing is giving any signs of being worn at all. It still shifts like new, in fact, a little better than when it was new if anything. I still own the bike, and it shifts and runs great.
You must be careful and not force it into the next gear. A little pressure (maybe a few ounces) on the lever to preload, then a quick tiny blip, and it pops into the next gear. If you put a lot of force behind the lever, there is some potential for harm, but if you just preload it, and let it snick in, it should cause no problems. Drag racers do it all the time, because it is quicker. I've done it on every street bike I've had without any transmission problems ever. Air shifters coordinate the movement of the lever with a blip of the throttle, no clutch. Those don't usually cause any transmission problems either. When you do it yourself, you are just doing the same thing as an air shifter.
Zippy is offline
post #6 of 22 Old 02-05-2007, 11:08 PM
Images: 8
Ive got more than 30,000 on one of my RC51s, plenty of clutchless up and down shifting. Not one single problem ever.
rokitt51 is offline
post #7 of 22 Old 02-06-2007, 3:36 AM
I recommend purchasing a power commander with integrated clutchless upshift software/hardware. Superbikes use this technology if I'm not mistaken.
Zixxer is offline
post #8 of 22 Old 02-06-2007, 3:24 PM
Clutchless upshifts = no problem...I use clutch when I downshift...no problem so far.
Jabone is offline
post #9 of 22 Old 02-07-2007, 3:08 AM
Images: 2
Reputation Power: 12
what about if your bike is equipped with a quickshifter?
jamilrahman is offline
post #10 of 22 Old 02-07-2007, 7:09 AM
I use my clutch. It is there for a reason.
Gigolo Jason is offline
post #11 of 22 Old 02-08-2007, 1:47 PM
Send a message via MSN to JustinkF
Clutch is there for a reason, to get in and out of gear, not necessarily between them.
JustinkF is offline
post #12 of 22 Old 09-11-2008, 11:41 PM
Reputation Power: 9
if anything you get a smoother shift
gotama is offline
post #13 of 22 Old 09-12-2008, 12:11 AM
Images: 12
Reputation Power: 9
Use the clutch.
dbierman is offline
post #14 of 22 Old 09-12-2008, 12:17 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
I have to disagree.
I haven't used the clutch on my bikes for years on the road or track, up or down the box and haven't had any problems.
Every time you disengage and re-engage the clutch it is slipping causing wear, heat and polluting your oil with clutch material.
Of course, like everything you have to make the effort to learn to do it correctly. Done incorrectly you'll bend forks at the least and possibly wear the dogs. I've got over 60,000kms of road and racing on my SRAD GSXR (bought new) and it stills shifts better than any Honda box I've used.
post #15 of 22 Old 07-29-2009, 5:04 PM
Reputation Power: 9
I have to disagree.
Gotta love BladeRacer....and it's the truth done the same with all my bikes not one problem, just got to feel it! some of you guys are silly"use the clutch, that's what it's there for," I Laugh at guys like u at bike night, So u still have your stock fender and lic plate lolololol. probably never taken your tank off once!
909Honda is offline
Human Verification
954/929 transmission - are they the same?? King Kenny Honda FireBlade 0 07-25-2005 7:59 PM
Hurricane damage in the Gulf Pete Off-Topic 20 07-13-2005 11:56 AM
CBR954 clutchless shifting Abjatrer Honda FireBlade 44 10-18-2004 5:57 AM
Damage estimate for the blade. firedawgon929 Honda FireBlade 10 02-04-2004 3:09 PM
Clutchless shifting IRideChasey Honda FireBlade 35 08-05-2003 12:59 PM
