Chain problem
Old 04-12-2007, 12:17 PM
Bike(s): Honda 929
Rep: polish projecti is on a distinguished road (10)
Chain problem
Bike: Honda 929 2000 almost 40,000km
This has been a problem since i purchased the bike (2nd owner). Under heavy throttle acceleration and throttle blipping, my chain seems to be catching on something and you can hear almost what sounds like a metal on metal click. Also it looks like the chain is not going straight over my swing arm, and rubs on the protective plastic. I have had the chain and sprockets recently replaced and still the problem remains. This problem is wearing down the new chain and sprockets alot faster then regular wear should, and I have already tried the easy fixes like chain lube and tightening. The local shop couldn’t figure it out so i turn to you fireblades.org, thank you in advance! Cheers!
polish projecti is offline
View polish projecti's Profile View polish projecti's Gallery Find More Posts by polish projecti
Old 04-12-2007, 12:38 PM
Bike(s): 01 929RR, 99 900RR, 01 600F4i
Rep: Atreyu will become famous soon enough (65)
Re: Chain problem
have you checked the wheel alignment and made sure that both sprockets are aligned properly
Atreyu is offline
View Atreyu's Profile View Atreyu's Gallery Find More Posts by Atreyu
Old 04-12-2007, 2:12 PM
Bike(s): f4i, f2, zx6r, gsxr
Rep: HiLi_Psyclez is on a distinguished road (12)
Re: Chain problem
sounds like your rear wheel isnt lined up straight check the lines on the swingarm or measure the distance on each side.
HiLi_Psyclez is offline
View HiLi_Psyclez's Profile View HiLi_Psyclez's Gallery Find More Posts by HiLi_Psyclez
Old 04-12-2007, 2:24 PM
Wish I had a fuel gauge
Bike(s): 1998 CBR 600F3
Rep: slorider18 is on a distinguished road (48)
Re: Chain problem
i was going to leave a useful post for once, but these guys beat me to it. Also make sure there no kinks or tight spots on any of the links. if it is not seatting properly around the sprokets it will shorten the chain as it rotates and cause the clicking noise. i had a kink a few weeks ago and had to replace the chain. mine was making the same noise. i could also feel it. in my left peg when it made the sound.
slorider18 is offline
View slorider18's Profile View slorider18's Gallery Visit slorider18's homepage! Find More Posts by slorider18 My Map Location
Old 04-12-2007, 2:32 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Re: Chain problem
How are you checking the alignment of the chain?
Red Rider is offline
Old 04-12-2007, 7:19 PM
Bike(s): Honda 929
Re: Chain problem
This i would also like to know
Old 04-12-2007, 7:45 PM
Bike(s): 1000 '06, 929 '00, KLX400SR '03
Rep: 2Wheels 2Feet is on a distinguished road (10)
Re: Chain problem
When I used to work at a local bike shop, the owner of PBI Sprockets gave me a good tip:
get the bike on a centerstand, take the chain guard off, and loosen the axle bolts a little bit so you can hand tighten/loosen the axle nut. Don't loosen the chain adjusters just yet.
you may need a flashlight or something but rotate the wheel and look closely at the rear sprocket/chain. Notice what side the small gap between the sprocket and chain is at.
if you push the chain slop in the opposite direction around the sprocket, rotate the tire, and after a few rotations that gap quickly returns to the original side, you're out of alignment.
Adjust the axle accordingly until the gap between the chain and sprocket doesn't want to immediately go to the left or right side after some rotations.
of course when you're done torque all bolts accordingly.
I've always found this technique helpfull to fine tune the alignment after using the chain block markers as guides. It can be a bit tedious, but after a few times knowing which way and how much to move the axle forward and back forward becomes easier...
2Wheels 2Feet is offline
View 2Wheels 2Feet's Profile View 2Wheels 2Feet's Gallery Find More Posts by 2Wheels 2Feet
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:30 AM.
