fuel
Old 05-20-2007, 10:23 PM
Bike(s): I have a stock 929rr that maybe 3 to 5 inch off th
Rep: shortyt1418 is on a distinguished road (10)
Send a message via Yahoo to shortyt1418
fuel
My fuel pump quit working and now i'm not getting any power to the fuel pump any suggestions
shortyt1418 is offline
View shortyt1418's Profile View shortyt1418's Gallery Find More Posts by shortyt1418
Old 05-21-2007, 12:54 AM
Bike(s): 01 929RR Erion Racing
Rep: 1sterion is on a distinguished road (11)
Re: fuel
check fuse and or wiring for opens. make sure stop switch is set to run.
1sterion is offline
View 1sterion's Profile View 1sterion's Gallery Find More Posts by 1sterion
Old 05-21-2007, 12:59 AM
Re: fuel
I check all fuse is there a relay for the pump if so where is it
Old 05-21-2007, 1:32 AM
Re: fuel
There is a fuel cut relay and engine stop relay just in front of the ECU
1sterion is offline
Old 05-24-2007, 9:27 AM
Re: fuel
How can I fiind out if the relay is bad
Old 05-24-2007, 10:23 AM
Re: fuel
If you can get your hands on a volt or multi meter you can verifiy the 12v output. Put the meter leads in the connector that goes to the fuel pump under the tank. If you have 12v then your pump is bad, if there is not 12v then you have to trace it back further in the circuit. The fuel cut relay is energized by the ECU and voltage it passes through comes from the engine stop relay. Do a search on here for the service manual. I downloaded it and I'm just feeding you tiny bits from it.
1sterion is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:16 AM.
