More F4 problems still wont start
Old 07-09-2007, 8:43 AM
Bike(s): 1999 Honda F4
Rep: F4bill is on a distinguished road (10)
Now it wont even click I had the battery charged...It cut on then right off again! if i hold the starter button the head light goes out and then nothing happens. I'm dying to get out and ride any help please let me know thanks again! This is a great site
F4bill is offline
View F4bill's Profile View F4bill's Gallery Find More Posts by F4bill
Old 07-09-2007, 9:02 AM
Re: More F4 problems still wont start
Where did you get this bike? Was it running when you got it? Did the owner show the starting sequence?
To start this bike, the emergency stop has to be out, kickstand up, clutch lever pulled in, transmission in neutral, and the start button pressed. All of those conditions have to be met before voltage will flow to the starter solenoid. That is...if your charging/battery system is working.
Other than that, the starting circuit is a simple trace through those locations. For example, if the small wire next to the kickstand is disconnected, the bike will not run.
dattaway is offline
Old 07-09-2007, 9:20 AM
Yeah it was running great for about a week... I'll give that a try but considering the light goes out that makes me question some kind of wiring problem or a bad starter.
F4bill is offline
Old 07-09-2007, 10:13 AM
Loose connectors where the hands or feet can be are the first to get knocked free. Check the clutch lever where there are two wires and the neutral switch. Chances are, there's a wire sticking out.
dattaway is offline
Old 07-09-2007, 5:35 PM
Bike(s): 954, 400R, VT250
Rep: soupnazi is on a distinguished road (11)
There are cut off sensors on all of the above mentioned controls. Gear, sidestand sensor, not to mention centrestand on the F4. To start off with wiggle each and every lever and make sure it's upright and tucked away.
Then the obvious, make sure the kill switch isn't off.
It could be a blown fuse, check any/all fuses and replace if necessary. They're easily accessible under the seat and very easily replaced.
soupnazi is offline
View soupnazi's Profile View soupnazi's Gallery Find More Posts by soupnazi
Old 07-10-2007, 8:16 AM
Red Rider's Avatar
Bike(s): '01 CBR929
Check the kill switch for corrosion or loose connections.
Red Rider is offline
Old 07-10-2007, 8:29 AM
hey thanks everyone who helped turned out after a charge the battery still wouldn't work. I replaced the battery and I'm running good...Thanks again everyone!
F4bill is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:54 AM.
