Honda Motorcycle Forum
Honda Motorcycles
Navigation » Honda Motorcycles - FireBlades.org > General Motorcycling > General Discussion » What Kind of Gas Do you put in your bike?
Old 09-23-2007, 4:12 PM   #1
Images: 4
Reputation Power: 7
RiotSauce is on a distinguished road
Send a message via AIM to RiotSauce
So, I was talking with my friend yesterday, and I mentioned that I put premium gas in my bike. He says that he puts regular in his bike, and we kind of had this argument about which is better for the bike, him arguing that premium dirties the engine faster and my argument being it lets you get the most out of your engine. Any thoughts?
RiotSauce is offline   Reply With Quote
Remove Ads
Old 09-23-2007, 4:56 PM   #2
Reputation Power: 9
dattaway will become famous soon enough
Re: What Kind of Gas Do you put in your bike?
Higher octane does burn slower. Think about that.
dattaway is offline   Reply With Quote
Old 09-23-2007, 4:59 PM   #3
Images: 4
Reputation Power: 7
adam001 will become famous soon enough
Send a message via MSN to adam001
i use 98 unleaded
adam001 is offline   Reply With Quote
Old 09-23-2007, 5:05 PM   #4
HondaGalToo's Avatar
Images: 16
Reputation Power: 25
HondaGalToo is a splendid one to beholdHondaGalToo is a splendid one to beholdHondaGalToo is a splendid one to beholdHondaGalToo is a splendid one to beholdHondaGalToo is a splendid one to beholdHondaGalToo is a splendid one to beholdHondaGalToo is a splendid one to behold
I use regular. I believe that's what the owner's manual states. I doubt putting in premium will hurt. I used to run premium in it, particularly on the track, but with gas prices what they are, I went back to regular and I can't tell a difference in performance.
HondaGalToo is offline   Reply With Quote
Old 09-23-2007, 5:08 PM   #5
Images: 3
Reputation Power: 6
Phadreus is on a distinguished road
Once you reach an octane level that allows the bike to run the maximum ignition advance curve without detination, then you're golden. Running any higher octane above that, is purely a waste of money. Premium running more "dirty" than regular is pure weapons grade BS.
"Political correctness is tyranny with manners."
Phadreus is offline   Reply With Quote
Old 09-23-2007, 5:24 PM   #6
Maholli's Avatar
Images: 5
Reputation Power: 30
Maholli has a reputation beyond reputeMaholli has a reputation beyond reputeMaholli has a reputation beyond reputeMaholli has a reputation beyond reputeMaholli has a reputation beyond reputeMaholli has a reputation beyond reputeMaholli has a reputation beyond reputeMaholli has a reputation beyond reputeMaholli has a reputation beyond reputeMaholli has a reputation beyond reputeMaholli has a reputation beyond repute
Phadreus couldn't of said it any better...
.. My bike says to use premium...
Maholli is offline   Reply With Quote
Old 09-23-2007, 6:11 PM   #7
07Repsol is an unknown quantity at this point
Chevron Super. Red, white and Blue. It's all my dad ever used.
07Repsol is offline   Reply With Quote
Old 09-23-2007, 6:13 PM   #8
Images: 8
Reputation Power: 11
rokitt51 has a spectacular aura aboutrokitt51 has a spectacular aura aboutrokitt51 has a spectacular aura about
I use reg in my bike. Sometimes i use premium, but when i had my bike on the dyno i tested with premium and with reg. There was a tad more power with the reg petrol.
rokitt51 is offline   Reply With Quote
Old 09-23-2007, 6:56 PM   #9
Images: 3
Reputation Power: 6
Now that is totally surprising to me. I would expect it to be the same at best or less with regular at worst. I wonder why you got less hp with Premium?
Old 09-23-2007, 7:03 PM   #10
bladerunner02 is on a distinguished road
unleaded
bladerunner02 is offline   Reply With Quote
Old 09-23-2007, 7:18 PM   #11
Reputation Power: 9
That's the way it should be. These are short stroke engines and that particular fuel is designed to burn slower.
If it burns cooler, deposits might build up as I discovered after a 45,000 mile teardown which had significantly increased compression due to nearly 1mm of deposits on the piston, head, and valves. From what I saw, it might be possible to create more horsepower with years of increased octane at an increased risk of detonation. Put that in your pipe and smoke it!
After cleaning that combustion chamber varnish, I'm back to using the cheap gasoline.
Old 09-23-2007, 7:24 PM   #12
boofawoof is on a distinguished road
Whichever it runs best with
boofawoof is offline   Reply With Quote
Old 09-23-2007, 7:30 PM   #13
Reputation Power: 6
Juggernaut is on a distinguished road
You can put crappy gas that is 93 (R+M)/2 rated octane and it'll gum up your engine the way dattaway describes. The new gasohol should help out if you use Premium premium. Shell and BP/Amoco are the two best formulations out there, the slightly higher price is warranted because of the amount of additives they use.
Using the lower octane is like running lean, the flame front propagates faster increasing power, but there is a tradeoff- more detonation in the high compression engines we're talking about.
Keep your gas fresh and buy premium brands.
Juggernaut is offline   Reply With Quote
Old 09-23-2007, 8:37 PM   #14
Reputation Power: 7
Gigolo Jason is on a distinguished road
Unleaded.
It's the only way to go.
Gigolo Jason is offline   Reply With Quote
Old 09-23-2007, 8:42 PM   #15
Images: 3
Reputation Power: 6
Originally Posted by Gigolo Jason View Post
Unleaded.
Excellent!
Search tags for this page
what kind of fuel do motorcycles use
what kind of gas do motorcycles use
what kind of gas do you put in a motorcycle
what kind of gas does my motorcycle use
what kind of gas for motorcycle
what kind of gas should i put in my motorcycle
what kind of gas should i use in my motorcycle
what kind of gas to put in motorcycle
what type of fuel do motorcycles use
what type of gas do motorcycles use
what type of gas do you put in motorcycles
what type of gas should i use in my dirt bike
You may not post new threads
You may not post replies
What kind of car/s do you drive? smoothrideronli Off-Topic 374 01-22-2010 9:49 PM
Where do you put your laptop? burnzone General Discussion 7 07-07-2007 11:49 AM
What do you carry in your pocket? nhfirefighter13 Off-Topic 42 01-24-2006 7:51 PM
What Type of Oil Do you use on your 954?? Robert3RR Honda FireBlade 35 08-24-2005 11:07 AM
What kind of music do you listen to? Mo Noyz Off-Topic 20 04-22-2004 5:19 PM
