03-10-2008, 7:12 AM
Bike(s): 03 yellow&black 954 Posts: 12
| over heating cbr Hi guys been a while,my sons 250 has over heating problems have changed the radiator,thermo fan and switch do these models have a thermastat any where? it only overheats on warm days and are they prone to have head gasket problems any other suggestions or remedies would be a great help.  |
03-10-2008, 7:38 AM
Bike(s): CB750, GL1000,CBX, Blackbird, 2005 CBR 1000rr Posts: 374
Rep:  (21) Rep Power: 3
| Re: over heating cbr Does it overheat going slow in traffic or while running the back roads or both? More info on the bike would be helpful. Eg. year, model, miles etc. It would also have a stat located somewhere. |
03-10-2008, 10:50 AM
Bike(s): 2001 CBR929RE1 Age: 31 Posts: 1,147
Rep:  (63) Rep Power: 8
| Re: over heating cbr check the fuse for the fan. simple but you never know. |
03-10-2008, 5:33 PM
Bike(s): 94 cbr900rr drag only...997 down but not out Age: 43 Posts: 137
Rep:  (10) Rep Power: 1
| Re: over heating cbr Quote:
Originally Posted by MACI4LIFE check the fuse for the fan. simple but you never know. | absolutely...start with the simple stuff. There should be a switch on your radiator, pull the wire and ground it to the frame, fan should come on if your electrical is in order. Not familiar with the 250..Follow top radiator hose (normally on righthand side of bike), it should lead you to a thermostat. |
03-11-2008, 6:54 AM
| Re: over heating cbr the bike is what we call in oz land a grey import which is a refurbished 10 year old jap import, the fan comes on most times but every know and then it will not,over heats mainly in slow speeds but will over heat anytime i am leaning towards a head gasket as the main problem but not sure give me a 954 any time  |
03-11-2008, 7:56 AM
| Re: over heating cbr Sounds like you might be going in the right direction unfortunately assierunner, especially if it overheats cruising on the back roads. If a pocket of air (compression) gets in the cooling system, the temp senson cannot read hot air which will keep the fan from coming on when needed.
Still check the easy stuff like the others have said first, like your fan stat, thermostat and so on.
Other signs of head gasket failure could include.
-pressure in cooling system immediately after starting.
-bubbles or boiling look in cooling system.
-coolant level changes
-oily residue in coolant |
03-11-2008, 8:24 AM
| Re: over heating cbr thanks will try the thermostate next if i can find it |
03-11-2008, 8:49 AM
Bike(s): 2006 silver 1000RR Age: 29 Posts: 65
Rep:  (30) Rep Power: 2
| Re: over heating cbr flush the system and then run water wetter. it used to keep my old gsxr race bike from getting to hot on track days. |
