Next performance upgrade?
04-08-2008, 9:50 PM
Bike(s): '94 900RR Posts: 13
| Next performance upgrade? so i was wondering what you guys think would be the best upgrade for me to do... it wont be anytime soon but im looking for ideas now so i can plan and get an idea of what im doing.
everything listed are things that i have not done myself, it was all on the bike before i got it.
- wiley full exhaust (btw, how would people rate this exhaust? just kinda curious)
- k&n filter
- a very nice port and polish job that i've seen first hand
- jet kit |
04-08-2008, 9:58 PM
Bike(s): 2003 CBR954RR Posts: 191
Rep:  (17) Rep Power: 2
| Re: Next performance upgrade? 520 kit w dropped tooth |
04-08-2008, 10:05 PM
#3 | | So easy a ...
Bike(s): 01 929 Age: 39 Posts: 1,280
Rep:  (73) Rep Power: 8
| Re: Next performance upgrade? Track school  (assuming you haven't already done so) |
04-08-2008, 10:35 PM
Bike(s): yellow and blue 06 1000rr, 01 blue/white gsxr750 Posts: 369
Rep:  (11) Rep Power: 1
| Re: Next performance upgrade? Quote:
Originally Posted by fl-929 Track school  (assuming you haven't already done so) |  best upgrade is one to the rider himself... unless your Valentino. other then that the 520 chain with the smaller sprocket is a good idea |
04-09-2008, 6:29 PM
Bike(s): 94 cbr900rr drag only...997 down but not out Age: 43 Posts: 144
Rep:  (10) Rep Power: 1
| Re: Next performance upgrade? If you can get your hands on one....Vance & Hines Powerpak makes a big difference, especially in upper rpm range. I don't know if they still make them or not, I got mine used. Back when mine was stock, it would peak around 11k and it would flatten out almost to 12k meaning the power didn't drop off, it kept making it. I'm anxious to see how it does after I get it back together again. |
04-09-2008, 7:52 PM
Bike(s): k6 GSXR750, 97 YZF1000, 05 600RR, 02 954 Posts: 1,216
Rep:  (29) Rep Power: 4
| Re: Next performance upgrade? Well are you in shape (weight)? That would be an excellent upgrade. I need to lose about 120 pounds myself. |
04-09-2008, 8:15 PM
Bike(s): Honda CB-1 Posts: 199
Rep:  (17) Rep Power: 1
| Re: Next performance upgrade? mach900rr,
What are your reasons for wanting to upgrade the performance? |
04-09-2008, 10:27 PM
Bike(s): honda cbr600rr & harley sportster 1200custom Posts: 23
| Re: Next performance upgrade? some nice rear sets, probably the favorite of all my aftermarket work. got a nice pair from vortex, nice looking, fully adjustable, i luv the new riding position.
and good windscreen, the gp or double buble type. i have a puig and it does make a difference on the highway |
04-09-2008, 10:30 PM
Originally Posted by fl-929 Track school  (assuming you haven't already done so) | yeah, i went last yr for the first time... by far the best thing i could of done for my bike. honestly, very few riders like myself will ever realixe the full potential of their machines, so the real challenge is too learn how to use ride the weels of ur bike, then 5 horsepower upgrades wont seem so imoportant. having said that, i do love the clip-ons and have spent some $$ on small upgrades; but they were all well researched and ithink they're all worth it |
04-09-2008, 10:37 PM
| Re: Next performance upgrade? ok, cool thanks for the ideas...
now is the 520 conversion where you drop 1 tooth in the front and go 2 up in the back or am i thinking of something else?
and i have thought about track school... would be a good idea to learn some of the technical stuff of riding since i just started.
i'd like to think im in good shape... im 5'7" and about 125 so im not overweight... if anything i could use a few more pounds lol... i started working out again about 2 months ago tho so i should be set there... hopefully
and as far as the reason of wanting to up the performance i just wanted to get an idea of what else i could do because it seems pretty topped out already... ill most likely end up doing the 520 conversion and riding for awhile because summer is on its way and i have more power than i need already
btw... if anyone around knows of a good track school around southern michigan/upper indiana please let me know
thanks |
04-10-2008, 7:57 AM
| Re: Next performance upgrade? if you just started riding i would do the 520 conversion but dont lower the gearing too much, it will make the bike very twitchy. if you want to experiment i would just drop one tooth in the front and keep the stock teeth on the rear. after you get used to that setup then i would start adding teeth to the rear sprocket. one down in the front is around a 7% gearing change and will bring you closer to a 3 to 1 ratio which puts most bikes in the ideal rev range.  on track school!! |
04-10-2008, 1:06 PM
thanks | the 520 conversion is taking the chain from a 530 to a 520. not worth it unless you are going to track the bike often. the chain will wear faster but will save weight. you might drop a tooth on the front sprocket but other then that i probably wouldnt touch it. |
04-10-2008, 3:11 PM
#13 |
| Re: Next performance upgrade? awesome, thanks everyone |
04-10-2008, 3:19 PM
#14 |
Originally Posted by blue1000rr the 520 conversion is taking the chain from a 530 to a 520. not worth it unless you are going to track the bike often. the chain will wear faster but will save weight. you might drop a tooth on the front sprocket but other then that i probably wouldnt touch it. | Why wouldnt it be worth it. Chain is just as strong. At least i think so with 16,000 miles out of a 520 on my old RC, and more than that out of it on an old YZF1000. Take care of the chian and ittl be alright. |
04-10-2008, 4:41 PM
#15 |
| Re: Next performance upgrade? i wouldn't have recommended it if i didnt think it was worth your while, def rates in the top 3 of mods ive done to mine |
04-10-2008, 4:51 PM
#16 |
| Re: Next performance upgrade? i guess it comes down to personal preference. i wont change my chain to a 520 on my street bike. no point to. i dont ride hard enough on the street to constitute it |
04-10-2008, 11:15 PM
#17 |
If you are in SW Michigan, you are not far from Grattan Race track. Sportbike Track Time has schools there, as well as Apex to Apex Riding School. The track is located just east of Grand Rapids, near Belding. Awesome track! I know as of Oct of last year, they re-paved have the track. Im sure, they paved the other have half by now. I was told, I you can ride well there, you can ride well anywhere... |
04-11-2008, 3:45 PM
#18 |
| Re: Next performance upgrade? yeah grand rapids is about an hour away from me so thats my best bet. i live in bridgman which is around the benton harbor/st joe area. its a really small town that no one knows of but if you take I-94 towards chicago you drive right though lol. blink and you'd miss it.
soon as spring gets here for sure im going to look into that.
thanks |
04-11-2008, 7:30 PM
#19 |
thanks | Hell if you could use a few more pounds, i got some that you can have. Bout 114 of em |
04-11-2008, 8:01 PM
#20 |
Bike(s): project blackblade 1200 (pb mag) bandit 900 Posts: 139
Rep:  (10) Rep Power: 2
Originally Posted by mach900rr so i was wondering what you guys think would be the best upgrade for me to do... it wont be anytime soon but im looking for ideas now so i can plan and get an idea of what im doing.
Akrapovic give great results so do hindle headers with almost any can on them
- k&n filter------always good but best with an ignition advancer
Too shiney just lowers compression so you will need to skim the head while its off (about .025mm) would do
- jet kit |
SS brake lines if not already there
And a good service make sure the shimes are done (valve clearance) |
04-11-2008, 8:28 PM
#21 |
| Re: Next performance upgrade? while on the topic of ignition advancers... what kind should i get and where would be the best place to get one?
also, would that give me more top end power or torque?
and wheres a good place to get stainless steel brake lines?
im good on pounds btw... if i need some ill just earn em myself  |
04-11-2008, 8:40 PM
#22 |
| Re: Next performance upgrade? Well dude im in Ireland but here it goes..
Ign advancer you will get one in the US the brand is factory This will only give you more power/torque from making the spark happen 4 degrees sooner therefore making the throttle response smoother and sharper. Dude its worth getting (a bit like running with race fuel but all the time) brake lines-look ub goodridge.co.uk its good stuff... best of look with it bro!! |
04-12-2008, 12:25 AM
#23 |
| Re: Next performance upgrade? awesome, thanks blackblade...
ill be looking into an ignition advancer tomorrow  |
