changing coolant??
Old 06-02-2008, 1:02 AM
Bike(s): 2006 CBR1000RR
Rep: Ninja95 is on a distinguished road (10)
changing coolant??
How hard is it to change your coolant on a 06 1000RR??
ive putting in water wetter, for a track day / school.
what kinda time and effort is it going to take??
Ninja95 is offline
View Ninja95's Profile View Ninja95's Gallery Find More Posts by Ninja95 My Map Location
Old 06-02-2008, 1:24 AM
lanbrown's Avatar
Rep: lanbrown is on a distinguished road (44)
Re: changing coolant??
Not hard, just a little messy. I won't give a time as it is eaiser for some than others. You could be done in less than an hour or as much as three.
lanbrown is online now
Old 06-02-2008, 7:59 PM
segiano's Avatar
Bike(s): 2007 Honda CBR1000RR & 1992 Honda CBR600F2
Rep: segiano is on a distinguished road (10)
Pull the right mid fairing and remove the radiator cap. Remove the drain bolt from the water pump on the lower left left side of the bike. Drain coolant into a pan. I always bump the motor over to get the remaining coolant out. You should also drain the reserve tank by pulling the siphon from the radiator. Replace the drain bolt and refill the radiator and reserve tank. Run the engine for a few minutes to open the thermostat. Shutdown and check the coolant level in the reserve tank. Careful where you dispose of the antifreeze. I recycle at the local Jiffy Lube (free).
segiano is offline
View segiano's Profile View segiano's Gallery Find More Posts by segiano
Old 06-03-2008, 5:30 AM
thanks guys! it wasn't too messy for me. And the track day / school was awesome!!
my tires are MELTED!!!
Ninja95 is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:43 AM.
