my rear tyre looks like its melting
06-16-2008, 2:36 PM
Bike(s): cbr900rrx (2000) Age: 30 Posts: 122
Rep:  (12) Rep Power: 1
| my rear tyre looks like its melting iv just got back from a ride and was looking round my bike when i noticed the rear tyre appears to have melted in places (not sure how else to describe it)about 15mm from the edge.you can scrape rubber off with your fingernail,is this normal as iv not seen it before,tyre is a meltzer rennsport.  |
06-16-2008, 3:03 PM
Bike(s): 2006 honda cbr 1000rr (candy blue/yellow) Posts: 32
| Re: my rear tyre looks like its melting how much tire pressure are you running and/or how hard do you ride? |
06-16-2008, 4:07 PM
| Re: my rear tyre looks like its melting not checked pressure since i got bike,i dont ride that hard ,last bike i had was 8 or 9 years ago so im still getting used to riding again,only had this bike a few months it is the biggest bike iv had though. |
06-16-2008, 4:40 PM
Bike(s): k6 GSXR750, 97 YZF1000, 05 600RR, 02 954 Posts: 1,242
Rep:  (29) Rep Power: 4
| Re: my rear tyre looks like its melting You got any pics to analyze? Prolly low pressures. |
06-16-2008, 5:13 PM
Bike(s): 2000 Honda CBR 929RR Posts: 45
| Re: my rear tyre looks like its melting I have to agree with the other comments, most likely to low of pressure. The lower the pressure the hotter your tire runs. |
06-16-2008, 5:18 PM
| Re: my rear tyre looks like its melting |
06-16-2008, 5:21 PM
| Re: my rear tyre looks like its melting sorry crap pic its dark outside,its about half way up on right hand side its come out like a grey patch in this photo. |
06-16-2008, 6:26 PM
#8 | | Team Visa Racing
Bike(s): 04 GL1800A,00 929RR,87 CR500R,81 CB900F,71 CB836K1 Age: 45 Posts: 3,809
| Re: my rear tyre looks like its melting It maybe blistering. Why are you using Renns for street use? My guess is that you are keeping them hot for too long at a time.
At first I was expecting to see balled up rubber attached to the tire (common on the race track), but that doesn't seem to be the case. But for what it's worth, I can gouge my old Renns with my fingernail.
Ride Red
06-17-2008, 3:21 AM
Bike(s): 2003 VFR, 2005 MV Agusta F4 1+1 Age: 27 Posts: 3,266
Rep:   (191) Rep Power: 11
| Re: my rear tyre looks like its melting Nedro - Are those Qualifiing tires? why so soft? |
06-17-2008, 7:19 AM
| Re: my rear tyre looks like its melting those tires look alright to me. Nedro arent the tires supposed to stay hot? What do you mean? |
06-17-2008, 11:46 AM
#11 | | Team Visa Racing
| Re: my rear tyre looks like its melting Are far as I know (which isn't much), Rennsports are DOT race tires. I didn't think they made a street version. Technically, you can use them on the street, but they are soft, wear out quickly, and you have to keep track of the heat cycles.
rokitt51, I said it wrong. There is more of an issue with constantly heating and cooling a race tire. Also, What I thing I'm seeing in the pic is the area that looks a bit white near the edge. If you look real close, it looks like the tire may have had a layer of rubber bubble up and then torn away.
Ride Red
06-17-2008, 11:52 AM
| Re: my rear tyre looks like its melting Quote:
Originally Posted by nedro Are far as I know (which isn't much), Rennsports are DOT race tires. I didn't think they made a street version. Technically, you can use them on the street, but they are soft, wear out quickly, and you have to keep track of the heat cycles.
rokitt51, I said it wrong. There is more of an issue with constantly heating and cooling a race tire. Also, What I thing I'm seeing in the pic is the area that looks a bit white near the edge. If you look real close, it looks like the tire may have had a layer of rubber bubble up and then torn away. | O i c what you were sayin. I figured that you meant somethin else. I used to run the 208 GPs ,on the street and the life was pretty good. i never had any problems with them. We did a lot of twisty stuff in north Ga in the mountains. |
06-17-2008, 12:31 PM
#13 | | Team Visa Racing
| Re: my rear tyre looks like its melting I'm going to be taking off my Marchesini wheels to get them ready for sale. I dug up a straight set of my old wheels that just happen to have some old Rennsports on them. I'll probably be using them up before I put some fresh rubber on them. It could get interesting out on the mountains with those old tires.
Ride Red
06-17-2008, 12:38 PM
#14 |
Originally Posted by nedro It maybe blistering. Why are you using Renns for street use? My guess is that you are keeping them hot for too long at a time.
At first I was expecting to see balled up rubber attached to the tire (common on the race track), but that doesn't seem to be the case. But for what it's worth, I can gouge my old Renns with my fingernail. | tyres are what was fitted to bike when i bought it,would you reccommend i dont use them on the road ?,i only ride when its dry so grip in the wet doesnt matter,can some one explain what keeping track of the heat cycles is,thanks for the help.
Reason: add text
06-17-2008, 2:09 PM
#15 |
Bike(s): 01 R6. Soon to become a 1000RR BladeRunner Age: 39 Posts: 4
| Re: my rear tyre looks like its melting Hi Guys.
I used these tyres on my R6 and they are a very soft compound tyre. the dealer told me that the nick name for them is "Super stickies!!) they were great for grip but didn't last long as you can imagin. When i went to purchase some more i was told that there is a track and street version of this tyre and the track version heats up a lot quicker and holds the heat for a lot longer.
I found out that i was using the track version so i opted for the street version which lasted a lot longer. There a great tyre and i would deffinately use them again.
Mike |
06-17-2008, 4:06 PM
#16 |
Bike(s): '01 CBR929 Age: 49 Posts: 7,853
Originally Posted by nedro I'm going to be taking off my Marchesini wheels to get them ready for sale. |
06-17-2008, 4:21 PM
#17 | | Team Visa Racing
| Re: my rear tyre looks like its melting It was a REALLY hard decision to make. I considered it to be the pinical of aftermarket parts that I bought for the 929. They are the older style Forged Magnisium 5 spokers.
Ride Red
06-17-2008, 4:40 PM
#18 |
Bike(s): 01 R/B 929 Age: 27 Posts: 12,216
Originally Posted by Red Rider | Quote:
Originally Posted by nedro It was a REALLY hard decision to make. I considered it to be the pinical of aftermarket parts that I bought for the 929. They are the older style Forged Magnisium 5 spokers. |
Red you don't want them if they are the Mags since you aren't running on the track anymore and they won't be of any use watching whales
06-17-2008, 4:45 PM
#19 | | Team Visa Racing
Originally Posted by CBR929RE Red you don't want them if they are the Mags since you aren't running on the track anymore and they won't be of any use watching whales  | Actually, that's the reason I'm selling. No place to ride with them.
Ride Red
06-17-2008, 5:41 PM
#20 |
Originally Posted by CBR929RE Red you don't want them if they are the Mags since you aren't running on the track anymore and they won't be of any use watching whales  |  Just wait until next year... Quote: |
Originally Posted by nedro Actually, that's the reason I'm selling. No place to ride with them. | You not racing anymore?
06-17-2008, 7:30 PM
#21 |
Originally Posted by Red Rider  Just wait until next year...
You not racing anymore? |  you know we'll all miss you in 12 days.
06-17-2008, 9:39 PM
#22 |
| Re: my rear tyre looks like its melting Ditto...
06-18-2008, 1:38 PM
#23 | | Team Visa Racing
| Re: my rear tyre looks like its melting My two year old does a better job dispersing any extra income I may have had than any race weekend I ever did.
Ride Red
06-18-2008, 3:29 PM
#24 |
| Re: my rear tyre looks like its melting If you think it's bad now, wait until he gets to college!
