'96 cr 125r - Honda Motorcycles - FireBlades.org
post #1 of 7 Old 11-13-2008, 2:10 AM Thread Starter
Images: 9
Reputation Power: 17
'96 cr 125r
my 96 cr 125r has a problem with leaking coolant into the transmission
how is this possible?its a 2 stroke.could it be the waterpump?
cbr1kfireblade is offline
post #2 of 7 Old 11-13-2008, 8:27 PM
Re: '96 cr 125r
yup defintly the water pump seals, easy to fix just take off the right hand side casing and remove the water pump shaft (the water pump impeller threads onto the shaft, possibly left hand thread). replace both seals and the bearing and good as new!
Bjorn is offline
post #3 of 7 Old 11-13-2008, 9:20 PM Thread Starter
Images: 9
Re: '96 cr 125r
thanks buddy,you ride dirtbikes too?
post #4 of 7 Old 11-13-2008, 11:40 PM
Re: '96 cr 125r
Yea they are the most fun!
Bjorn is offline
post #5 of 7 Old 11-13-2008, 11:50 PM Thread Starter
Images: 9
Re: '96 cr 125r
when you say right side casing, do you mean the clutch cover
post #6 of 7 Old 11-14-2008, 6:14 AM
Re: '96 cr 125r
Nah sorry not quite that simple, i mean the next layer behind the clutch cover, it covers the primary gear, power valve actuator, and houses the water pump and the kickstart gears. not too bad to remove, maybe 15 minute job. dont forget to drain trans oil first
Bjorn is offline
post #7 of 7 Old 11-14-2008, 1:16 PM Thread Starter
Images: 9
Re: '96 cr 125r
got ya thanks alot... rep for the help
Human Verification
Search tags for this page
1996 cr125 water pump
93 cr125 water pump seal replace
how do you take an empeller off a water pump on 99 125 cr honda
how to change water pump gasket on cr 125
how to change water pump seal in a cr125
how to change water pump seal on 1996 cr motorbike
how to remove water pump impeller 1984 cr125r
how to replace the water pump on a 1996 cr125
how to unscrew impeller on 91 cr 125
waterpump bearings and seals cr125 how to
Help With a 1984 CR 500 mreed79 Honda Off-Road 3 05-24-2011 7:12 PM
CR 250 Tear Down luvtolean Honda Off-Road 11 01-22-2004 6:58 PM
JenningsGP: CR T Shirts ccwilli3 Track Days / Riding Schools 12 05-13-2003 4:55 PM
